motorcycle helmet link
Discussion in 'Australian Motorcycles' started by netmotorcycles3, Dec 13, 2005.
  1. netmotorcycles3, Dec 13, 2005
  2. Sorry, can't see any helmets at all there. All I can see is a bevy of links
    to crapware sites.
    - Bob.
    Bob Milutinovic, Dec 13, 2005
  3. I think you misspelt "**** off spammer bitch!" there, Bob...
    big
    Iain Chalmers, Dec 13, 2005
  4. netmotorcycles3
    DJ Guest
    There is an article about the safety of Helmets in the current edition of
    Roadrider Magazine, a bit of food for thought but will probably make no
    difference.
    DJ
    DJ, Dec 13, 2005
  5. In aus.motorcycles on Tue, 13 Dec 2005 07:33:29 GMT
    What is the article's main point?
    Recently a bunch of Snell rated pushbike helmets were tested. Not one
    passed the Snell testing.
    A bunch of AS rated pushbike helmets were tested to AS standards. They
    all passed bar one, which was found to not be in the list of tested lids
    - that is the AS sticker was fraudulent.
    I wonder what the results would be if done on motorcycle helmets...
    I believe that Snell testing is done by the manufacturer sending Snell a
    sample of 5 helmets they say are typical of the model. And every batch
    of that model gets a sticker.
    AS1698 requires helmets from every batch to be tested, and for them all
    to pass before that batch gets a sticker.
    Which is one of the reasons helmets here are more expensive.
    Zebee
    Zebee Johnstone, Dec 13, 2005
  6. Basically said things like:
    - Aus Standards and euro standards are more indicative that the helmet does
    pass rules compared to Snell and DOT standards
    -The helmet material makes little difference in helmet performance, in fact
    plastic helmets were more consistent
    -Dropping your helmet does not mean it needs replacement
    -Open face helmets have no worse record for injuries than Full face helmets
    Basically it shattered a lot of common myths.
    Al
    Alan Pennykid, Dec 13, 2005
  7. In aus.motorcycles on Tue, 13 Dec 2005 21:53:43 +1100
    Sounds like what I've been told.
    THe bod who does the testing for AS1698 is scathing about Snell. He has
    also seen no difference in helmet materials as to how well they pass the
    AS1698 tests.
    He did try a bunch of old helmets, the oldest 12 years old, of varying
    amounts of wear, and they all passed AS1698.
    I don't think he's tested dropped ones. I seem to recall something like "as
    long as your head's not in it and you don't throw it at the concrete"
    but that might have been someone else.
    THe only stats I've seen for full vs open were on the ATSB website from
    a paper that was a bit dodgy in methodology. They covered a bunch of
    crashes where someone went to hospital, and looked at the kit, and they
    also interviewed people who reported crashing.
    They found very few who had hit their heads, and so didn't have enough
    numbers to draw any conclusion about open vs full.
    AS1698 doesn't test chinbars or any part of the lid below (I think) the
    eyebrows.
    Zebee
  8. netmotorcycles3
    DJ Guest
    Another interesting bit was there was no real evidence that those in the USA
    who don't wear helmets are no worse off than those that do. As the article
    stated something to the tune of ; there is no guarantee that having a
    helmet will save your life. You might have the best helmet that money can
    buy but that doesn't save you from internal or spinal injuries.Not the exact
    words but this is how I interept it.
    DJ
    DJ, Dec 14, 2005
  9. netmotorcycles3
    Nev.. Guest
    I don't know whether it's more stupid to state something that obvious,
    or to quote it.
    Nev..
    Nev.., Dec 14, 2005
  10. netmotorcycles3
    DJ Guest
    I'm kinda hoping it is the former.......and not the latter!!
    DJ
    DJ, Dec 14, 2005
  11. netmotorcycles3
    CrazyCam Guest
    ....and this one too, Theo.
    regards,
    CrazyCam
    CrazyCam, Dec 14, 2005
  12. netmotorcycles3
    Theo Bekkers Guest
    I believe more than 30 States in the US have so far repealed the helmet law.
    AS1698 is, as I understand it, a test of an object being dropped on top of
    the helmet at about 20 km/h. That has never happened to me, or to anyone I
    know. I suspect it may be of some use if you fall off a bar stool, while
    your feet are entangled in the foot bar so that your head strikes the ground
    vertically. This would be an impact of that velocity. In my expreience a
    helmet will save you from the impact of the dreaded 'large green bug' that
    probably would have missed your head had you not been wearing said helmet.
    Theo
    Theo Bekkers, Dec 14, 2005
  13. netmotorcycles3
    Errm... that's too many negatives for me to follow:
    Does that mean that non-helmet-wearers are not less likely to suffer less
    injuries or more?
    Knobdoodle, Dec 14, 2005
  14. netmotorcycles3
    A friend of mine (actually my then cousin-in-law) once tried to ride his
    Suzuki GT250 when he was pissed-as-a-newt and he put his Arai full-face on
    and then slipped and went completely arse-before-tit backwards onto his
    concrete garage-floor.
    When his wife finally convinced him to give it up he took his helmet off to
    find that an area the size of a beer-coaster had caved in like an eggshell.
    His is the only case where I can genuinely, hand-on-heart say that wearing
    a helmet saved his life.
  15. netmotorcycles3
    sharkey Guest
    When I pranged the CX, my helmet ended up with all the polystyrene
    in the forehead area compressed wafer-thin ... and me with mild
    concussion. So I figure it's probably just as well I was wearing it.
    ----sharks (PS: The shell was only lightly scratched ...)
    sharkey, Dec 14, 2005
  16. netmotorcycles3
    ck Guest
    My daughter had a fairly big off when racing an enduro and split the outer
    shell from the opening for about 5 inches in line with the right temple. She
    also cracked the chin piece in 2 places.
    Mild concussion and whiplash - back at school on
    Wednesday...............................
    ck
    ck, Dec 14, 2005
  17. In aus.motorcycles on Wed, 14 Dec 2005 21:17:12 GMT
    When I pranged and spent a week in hospital with brain damage[1] the
    helmet was scraped a bit but no obvious damage to the polystyrene.
    So I have no idea if it helped at all...
    Zebee
    [1] with permanent consequences... but that doesn't explain the Guzzis,
    I had them already.
    Zebee Johnstone, Dec 14, 2005
  18. netmotorcycles3
    Boxer Guest
    Perhaps you should repeat the procedure without the helmet for a valid
    comparison.
    Boxer
    Boxer, Dec 15, 2005
  19. In aus.motorcycles on Thu, 15 Dec 2005 00:44:28 GMT
    I can't - I can't remember how I crashed!
    So hitting the ground at the same angle would be too difficult.
    A new use for speed cameras! Footage of spills for later
    re-enactment...
    Zebee
    Zebee Johnstone, Dec 15, 2005
  20. netmotorcycles3
    Mad-Biker Guest
    Your head although you need it to live is only a small part of your body.
    Its like wearing a bullet proof vest and rushing a machine gun emplacement
    and wondering why your legs got shot from under you.
    As for the AS test ive seen it on tv I think its the helmet upside down on
    an 300 degree angle at 25 something clicks into something resembling an
    anvel. If I recall it appeared the front top section took the impact.
    I think the theory behind it is that no matter how fast horizontally you are
    traveling you will only fall at 9.8 newtons of gravity vertically which was
    around 25kph from a personf alling from a bike, basically there saying that
    you could be standing still or riding would have the same physics. But I
    recon that would be ok unless you hit the ground at 100kph and then slide
    head first into a wall.
    Its a long time since i done physics, or english for that matter so dont put
    me on the AS testing machine if i got it wrong.
    Mad-Biker, Dec 16, 2005
