Motorcycle GPS
Discussion in 'Australian Motorcycles' started by Andrew Hatcher, Oct 21, 2003.
  1. I would like to hear of people's experiences with GPS (Global Positioning
    System) units on motorcycles, including the type of unit, software used and
    the cost. Having recently made the mistake of taking a wrong turn-off on a
    country NSW back-road and running out of fuel (and finding that mobile
    phones - even CDMA aren't much use out in the sticks), I'm considering a GPS
    unit to help my (poor) navigation.
    Thanks,
    Andrew
  2. Andrew Hatcher
    Burnie M Guest
    A mapping GPSR is great both Garmin and Magellan have mapping products
    with excellent metropolitain and good rural area mapping.
    The mapping CD adds about $240 to the cost of the unit.
    On a bike you need a good mount and RAM mounts are great, about $90.
    You also need a power cable (about $25) as running from internal
    batteries you will have a problem with vibration turnig the unit off.
    Cheers,
    Burnie M
    http://www.gpsriders.net/
    Burnie M, Oct 21, 2003
  3. Andrew Hatcher
    sharkey Guest
    They work. They work well. Me, I'd ignore all the mapping database
    rubbish and go unto a hiking store and buy the smallest, cheapest,
    longest-battery-life one they've got, and with the money left
    over you can buy an awful lot of paper maps with lat and long
    scales up the sides.
    -----sharks
    sharkey, Oct 21, 2003
  4. Andrew Hatcher
    Burnie M Guest
    You can and it will be a lot cheaper, but if you use a mapping GPSR
    once then you will be convinced. They are very useful.
    Expect about $900-1200 for GPSR, maps and mount.
  5. Andrew Hatcher
    Nev.. Guest
    You don't need a GPS. You need to stop for fuel occasionally. GPS can be
    handy for navigating in areas you're not familiar with.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Oct 21, 2003
  6. Andrew Hatcher
    Burnie M Guest
    Nev,
    You don't need a bike either but live is much more fun with one.
    GPSRs are better than swiss army knives !
    Burnie M
    Yes, I am on a crusade
  7. I'm using an iPaq and oziexplorer with a GPS sleeve. I was initially
    concerned about vibration damage, as the iPaq isn't the most rugged PDA around,
    but appears quite stable and works fine.
    Whatever you pick will have pros and cons, so you need to do some homework
    and evaluate those pros and cons before laying out any money, because once you
    do, it could be lots of it, depending on what you need. It's in your best
    interest to get it right the first time.
    John Tserkezis, Oct 21, 2003
  8. Andrew Hatcher
    Skipper Guest
    Andrew, The Garmin StreetPilot III is generally regarded as being ideal for the job,
    it can give you voice directions via helmet mounted speakers (including through your
    intercom) or external speakers, not cheap but very good.
    Doug.
    Skipper, Oct 21, 2003
  9. Andrew Hatcher
    Burnie M Guest
    SPIII comes with the City Navigator Australia, an auto-routing mapping
    CD. This gives you great turn by turn directions and has excelllent
    mapping IN THE MAIN CITIES. In rural areas it has only main roads.
    An SPIII with this mapping is $1710.
    Garmin also makes another mapset called Metroguide Australia. This
    mapset has MUCH better rural mapping but does not do turn by turn
    auto-routing.
    Many people who have bought Garmin SPIII (or BMW Navigators - same
    with different badges) have also bought Metroguide ($235) plus a 128MB
    data card ($341) and then loaded both mapsets to the larger card and
    manually switched between the 2 mapsets when they need to.
    If you are considering this model then in Australia you really need
    Metroguide as well.
    Note there is a new model (out in November?) called the SP2610 which
    does screen re-draws and off-route recalculations much faster and also
    uses standard CF memory cards and has a USB interface. No pricing is
    yet available.
  10. Andrew Hatcher
    Nev.. Guest
    Yes, I know, I've got a GPS too, but it won't tell you when to fuel up. :)
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Oct 21, 2003
  11. I've used both mapping and non-mapping, and to be honest the semi mapping
    ones like the Magellan 330 are about the best compromise, near the price of
    the non mapping ones, and offer enough info that you don't need to carry
    heaps of detailed maps, just a small motorcycle style road atlas. And
    almost always you don't need that.
    Geoff and Jodie YMMV (it depends where you are located I expect!)
    Geoff and Jodie, Oct 21, 2003
  12. Andrew Hatcher
    Mark Hammond Guest
    Are you happy with it? I've been toying with the idea of doing the same
    for my e740. What receiver did you end up using? I see some very
    cheap ones on EBay, but I haven't dug into exactly what they are.
    Do you wish you had a "real" GPS?
    Mark.
    Mark Hammond, Oct 22, 2003
  13. Andrew Hatcher
    Skipper Guest
    Burnie M wrote:
    ---snipped---
    Thanks Burnie, I know to wait until the end of November and either buy the SP III
    cheaper or buy the new model.
    Doug.
    Skipper, Oct 22, 2003
  14. Andrew Hatcher
    Burnie M Guest
    Not sure that the SPIII will drop a lot more as it was been steadily
    dropping from $2200 for the last few months.
    Expect the SP2610 to be approx $2200.
    Probably worth it as it is noticably faster with several updates
    including touch screen.
    Does not look like Garmin will update the Australian mapping so you
    still have the same mapping issues.
    Cheers,
    Burnie M
    Burnie M, Oct 22, 2003
  15. I've seen it for $1700 at a couple of places. Can you expand on the mapping
    issues? I have been told that the Garmin Aussie maps are all 150 metres out
    due to incorrect maps being supplied by the Aus government, but the Magellan
    maps are accurate.
    Pegasus
    Andrew Hatcher, Oct 23, 2003
  16. Andrew Hatcher
    Burnie M Guest
    Read my previous posts.
    Yes, a few places have the SP111 at $1710.
    I have both Garmins Metroguide Australia and Magellans DiscoverAus on
    my PC and have used both products in the field. No noticable errors in
    either product in the NSW coastal areas that I have used them.
    Mapping relates to Garmins auto-routing product having less rural
    coverage than their non-routing product (Metroguide).
    Cheers,
    Burnie M
    Burnie M, Oct 23, 2003
  17. Andrew Hatcher
    Skipper Guest
    Yep, that's around the standard pricing for it atm here in Bris, the southern states
    may get it cheaper of course.
    As for quality of the
    garmin maps, nope, I've used a Garmin belonging to a friend a few times and it has
    been spot on, so I would doubt if that would be correct.
    Doug.
    Skipper, Oct 24, 2003
  18. Andrew Hatcher
    Docko Guest
    GPS is excelent. If you can't read a map though it will be useless to try
    and use paper maps. Personally I would prefer paper maps.
    GPS is better that a Swiss Army Knife but you can strip and clean a carb
    with a Leatherman.
    Docko, Oct 25, 2003
  19. Andrew Hatcher
    Burnie M Guest
    I have a Leatherman Wave too :)
    Burnie M, Oct 25, 2003
  20. Don't they usually do that from the float?
    YMCA Pat
    Pat Heslewood, Oct 27, 2003
