Motorbikes + Back Pain
Discussion in 'UK Motorcycles' started by Nick, Feb 5, 2005.
  1. Nick
    Preston Kemp Guest
    Me too, hence it only gets used for long motorway runs. Mine converts
    into a rucksack, so I just stick it on my back when I get to the
    twisties.
    Steady on now, you don't want to be making any rash decisions in your
    current state of mind.
    Preston Kemp, Feb 6, 2005
  2. Nick
    dwb Guest
    Reason #2 - I can't see the clocks.
    <awaits debunking answer>
    dwb, Feb 6, 2005
  3. Nick
    dwb Guest
    I'm still this >< close to just buying a VStrom 1000 with the lowered
    seat...
    if it's shit, well I'll still ride it the same amount as the GSX-R ;-)
    dwb, Feb 6, 2005
  4. Nick
    Preston Kemp Guest
    It depends on the bike & your riding style. It doesn't interfere at all
    for me on the Tiger, but the MV 'encourages' you to move around a lot
    more & lean your body into the corners, at which point I find the
    tankbag interferes with my upper arms.
  5. Nick
    Preston Kemp Guest
    Is this a specific V-Strom that's been modified, or just a V-Strom in
    general? If the latter, my dad's thinking of selling his if you're
    interested.
  6. Nick
    dwb Guest
    The one ones come with different seat heights (apparently).
    Why is he selling (I'm still in two minds as to whether or not it's a bike i
    will keep for the long term, which is really what I want in the next bike I
    purchase)?
    It's ugly as f*ck, which is one 'issue', but it's got a stonking motor :)
    I'm just not sure about how it'll handle once you get down to 'making
    progress'.
    dwb, Feb 6, 2005
  7. Nick
    porl Guest
    No, fair play. I like my half loaded tankbag for resting on in town and on
    motorways giving my back a reprieve (and I can see the clocks) and it
    doesn't cause problems on twisties, although I wouldn't want it on a track.
    And at full capacity it's a different proposition. But It's always a
    compromise: With panniers you have filtering issues- I've ripped a wing
    mirror off before accidentally- and you get weave at certain speeds.
    Rucksacks aren't much fun at speed either and they can feel restrictive.
    porl, Feb 6, 2005
  8. Nick
    Preston Kemp Guest
    Mainly because of its weight. He ideally wanted a 650 V-Strom, but all
    the dealers told him Suzuki weren't going to make one, so he got the
    1000. The 650 was announced a couple of weeks later IIRC.
    He used it a few times, then went back to the Vincents & Guzzis like he
    always does. So the V-Strom's been sat in the workshop doing nothing.
    I've not ridden one, but I'm sure it'll be similar to all the big
    trailies - brilliant on tight & twisty stuff, but a bit weavy on 90mph+
    sweepers. Not dangerously so, but a little disconcerting until you're
    used to it.
  9. Nick
    porl Guest
    Well it certainly would if you were hanging off but then panniers restrict
    you in that respect as well. And I probably cba to move around on a bike if
    I had a heavy rucksack on either.
    porl, Feb 6, 2005
  10. Nick
    porl Guest
    No, it's impossible for me to hang off with panniers as well. And there
    really is only one position where the panniers sit securely.
    I'll bet. My first back protector interefered with my helmet when looking
    anywhere above road level.
    porl, Feb 6, 2005
  11. Nick
    Verdigris Guest
    On Sat, 05 Feb 2005 21:30:08 +0000, Bear wrote:
    I find it *dreadful*, unless I'm going extremely fast. Being taller when
    I crouch down I end up with my shoulders above or even in front of the
    bars, which means there's a lot of weight on my wrists. It's particularly
    bad on today's miniscule sports bikes.
    Verdigris, Feb 6, 2005
  12. Nick
    dwb Guest
    About 20kg in it... 190 for the 650, 210 for the 1000. Now personally I'm
    not sure I'd notice the difference of 20kg except maybe when it falls over
    and I'm struggling to pick it up!
    And the increase in power is rather impressive for those 20kg...
    Hmm - how tall is your dad as a matter of interest (inside leg ...fnarr) ?
    Yes - this was mentioned when I chatted to the dearler "it kind of gets a
    mind of it's own over 100mph but on the twisty stuff and general riding it's
    fantastic"
    Very much in two minds - ho hum.
    dwb, Feb 6, 2005
  13. Nick
    Preston Kemp Guest
    About 6' (height, not inside leg). His legs don't appear to be
    freakishly disproportionate, so 'average'. He is however 67ish, & 50
    years of kick-starting Vincents have taken their toll, as did a
    particularly horrific crash a few years ago. So his idea of heavy won't
    necessarily match yours.
    It's the only way to be when deciding on a new toy :)
  14. Nick
    Slider Guest
    [snip]
    On the other hand, the Duc 999 has an adjustable seat, allegedly...
    Slider, Feb 6, 2005
  15. Nick
    dwb emerged from their own little world to say
    The GS is very much like that. You can cruise quite happily at an
    indicated 105. Go any higher and the steering becomes vague [1] and the
    windblast/noise becomes intolerable. I've wussed out from finding the
    top speed.
    Take a test ride but don't limit yourself to the Suzuki. I'm only 5'8"
    and found the Caponord and GS[2] had low enough seats for me. Only the
    Tiger felt too high & top heavy[3] for me
    [1] the beak probably starts to generate lift
    [2] has an adjustable seat
    [3] I've found other Triumph triples top heavy due to the way the engine
    carries its weight
    wessie, Feb 6, 2005
  16. Nick
    Verdigris Guest
    I found it quite stable in high-speed sweepers: better than the Tiger.
    Not quite as good in the really tight stuff.
  17. Nick
    Verdigris Guest
    I've been using a rucksack a lot lately - because I've been using the Zed
    so much - and it's not at all bad. It's a padded one to take a laptop,
    which I originally bought to use for work, with my push bike.[1] I really
    don't notice it much at all, although I suspect that would be different on
    a faired bike: my speed is already restricted by lack of a fairing so the
    extra drag of the rucksack isn't really significant to either speed or
    comfort.
    I do find that I notice its *absence* if I go out again after taking it
    off.
    [1] Just a cheap thing from Black's.
  18. Nick
    dwb Guest
    GS is £3500 more expensive (if buying new) - and that's just too much to
    justify for what I intend to use the bike for, plus the insurance would be a
    killer[1].
    At approx £6000 (if buying new) the V-Strom seems to be a lot of bike for
    not a lot of dosh - similar to the SV1000, but I don't really want an SV1000
    The other thing is servicing etc - I literally have a very good (to me!)
    Suzuki dealership within a 5 minute walk. That's quite important in terms of
    servicing, not to mention haggling a good deal out of them - they know I'll
    be back.
    Seat height wise, I sat on the DL650 and could flat foot that on both
    sides - the 1000 is 2cm higher - not sure how much difference that really
    makes, but they do have a lower seat option.
    [1] Seems the base cost currently has more bearing on my quotes than the
    grouping - no idea why.
    dwb, Feb 7, 2005
  19. Nick
    dwb Guest
    Heh! Great, I'm thinking about a bike that 67 year olds buy. Mind you, his
    insurance quote must have been good ("It appears we owe you £10 sir")
    I sat on the 650 - apparently that's 2cm lower and I could comfortably reach
    the ground with both feet (at 5'6).
    Yes - Expensive mistake to make if it doesn't work out though...
    dwb, Feb 7, 2005
  20. Nick
    Ginge Guest
    Find a dealer that will let you test-ride one.
    Ginge, Feb 7, 2005
