Hey, chaps. Long time no post. I'm getting my two SOBs (1980 Can Am Bombardier, 1976 Suzuki TS185) ready for participation in this year's Ryedale Rally, and there are a couple of things I'm unsure about before I take them in for MoT. 1) Can a bike fail for indicators flashing too quickly? The indicators on the TS are flashing double time, though all the bulbs are working and match (6V, 8W.) What else might make them flash double time? It came with an MoT, and I've not changed the flasher or the bulbs since. 2) Can a bike fail for having no front brake switch? Again, the TS appears to have no front brake switch, though it was purchased a few years back with an MoT, and I've certainly not removed the brake switch. It's not like there even a lead lying around that looks like it should connect to the switch. I know this might sound like a very stupid question, but my old VW keeps passing MoT with a broken reverse light because reverse lights weren't mandatory when the vehicle was approved, so you never know. The bike has a rear brake switch and it works just fine. 3) Neither the Can Am nor the Suzuki can flash the indicators with any sort of regularity at tickover. They flash fine (excepting the period of the Suzuki's flash as mentioned above) on the move. Also, you have to have a feel for the indicator switch, they're both a bit worn. Are either of these likely to be a problem? Many thanks for any wisdom wafted my way, Chris.
