Morning bike won't start
Discussion in 'Bay Area Bikers' started by hofooman, Sep 20, 2006.
  1. hofooman
    hofooman Guest
    I have a suzuki bandit 400 with about 23k miles on it. I've had the
    bike since january 06 and for the pass week i've have been able to
    start the bike in the morning. During the afternoon the bike starts up
    with no problems at all. I live in socal so the temperature doesn't
    change all that much. in january i got the battery changed, carbs
    cleaned, and spark plugs changed. also tires, brakes and a couple of
    other things that probably have nothing to do with starting the bike.
    the choke works fine (well in the afternoon with the bike starts up).
    does anyone have any advice on why the bike wouldn't start up in the
    morning.
  2. How -old- is that battery?
    They don't last forever, and tend to work less effectively at lower
    temps. (Yes even by California standards)
    I had a similar problem with my bike, until I finally decided to suck
    it up and get a new battery (Hawker Odyssey AGM, btw..they rock) -
    problem solved.
    cds
    C. Deforrest Smith, Sep 20, 2006
  3. Even if it's a new battery it might not get a chance to charge
    up very well. Check your battery voltage and clean the
    terminals and battery wires.
    If the voltage is low, buy a small charger like a Battery Tender.
    These are useful to have so you might buy one anyway and
    see if it makes things better.
    My bet is that if you took the bike for a long ride at freeway speeds
    it might start more happily the next morning. Same thing if it was in
    a warm space overnight. Cold makes the oil thicker and also makes
    the battery less effective.
    Rob Kleinschmidt, Sep 20, 2006
  4. hofooman
    Rich Guest
    what's the problem? I don't start up in the morning either. ;-}
    Rich, Sep 20, 2006
  5. hofooman
    jstinnett Guest
    Sounds like case of English Bike Syndrome, where the machine actually
    believes it's a BSA or similar.
    Have you been using Castrol?
    Just a thought.
    but seriously, I think it's your battery or related.
    Jim Stinnett
    R1100RS
    YZF R1
    NX 250
    jstinnett, Sep 21, 2006
  6. hofooman
    Timberwoof Guest
    You need to be a little more specific about the symptoms: This is the
    classic example I use when I describe a good bug report to new software
    QA engineers. "The bike won't start" could mean a lot of things, so many
    things that without more information it's meaningless.
    You gave the environment very well:
    Suzuki Bandit 400 cc with ~ 23k miles on it
    Southern California
    In the morning
    Now we go on to Steps To Reproduce, Expected Results, and Actual
    Results:
    Steps to Reproduce:
    1. Checklist:
    Fuel petcock on MAIN
    Choke ON
    Sidestand UP
    Centerstand UP (if fitted)
    Transmission in Neutral
    Clutch IN (squeezed)
    Ignition ON
    Kill-switch ON (RUN)
    Verify:
    headlight is on, nice and bright
    oil light is on
    alternator light is on
    2. Press the starter for a second or two.
    Expected Results: Headlight goes out, engine spins and catches;
    when starter button is released, headlight comes on again;
    engine runs at ~2000 RPM;
    alternator light goes out.
    Actual results:
    € nothing happens?
    € headlight goes out?
    € headlight goes out and it makes click-click-click noise?
    € headlight goes out and engine spins but does not catch?
    So what happens at Actual Results?
    Timberwoof, Sep 21, 2006
  7. hofooman
    hofooman Guest
    yea i should give more information sorry...
    well it starts up in the afternoon and later. in the morning it turns
    the engine and is trying to start but nothing happens. the battery
    seems to be just fine because the lights come up and can turn the
    engine easily. i'm thinking maybe the oil or the carbs are the
    problem. i'm also thinking of getting the bike moving in gear and
    releasing the clutch to get it started. but actually i think that may
    not work because the battery isn't the problem.
    hofooman, Sep 21, 2006
  8. hofooman
    Timberwoof Guest
    The oil is not the problem. But the carbs are the right direction to
    investigate.
    No, don't do that. That won't solve anything.
    The single thing that changes between you being able to start the bike
    and not is outside air temperature. That has a very big effect on how
    well gasoline vaporizes. When it's cold, fuel doesn't vaporize as
    easily; that's why you have to turn on the choke. Is the choke cable
    actuating the choke properly? That's where you should look.
  9. hofooman
    Andy Burnett Guest
    wrote in @b28g2000cwb.googlegroups.com:
    I wouldn't totally rule the battery out. It may have enough to crank but
    not enough to give a strong spark. You could try jump starting off a car
    battery *without the car running* and see if that'll start the bike in the
    morning. If it does, your spark may be weak enough that it doesn't fire
    right away and the plugs wet foul.
    Most of the other directions people are mentioning don't seem to account
    for why the bike may start in the afternoon. Even a few degrees difference
    could improve the battery's condition and may account for the bike starting
    later in the day. Remember, in the morning, the battery has been cold all
    night, whereas in the afternoon it has had a chance to warm up during the
    day.
    ab
    Andy Burnett, Sep 21, 2006
