More Reviews...Throttlemeister
Discussion in 'Texas Bikers' started by Brian Walker, Mar 5, 2007.
  1. Brian Walker
    Brian Walker Guest
    Probably the best accessory for a motorcycle!
    The problem with this is when I installed it on my Blackbird, I did it
    tonight while the Bird was sitting in my hotel room. Not a good place
    to wrench something like this. Once I got the bar end off and the bar
    insert out, nothing seemed to fit. After quite a bit of pulling trying
    to get the new Throttlemeister insert out and put the bike back
    together with old parts (ie, ABORT!), I seemed to have lined
    everything up exactly as it needed to be. The Throttlemeister works
    well now. I haven't had it on the road, but I will in just a short
    bit.
    When installing these things, for whomever might want to order one and
    then pull their bike into their room to install after a night of non-
    sleep because they're too busy watching to make sure the paint doesn't
    fall off the bike, here's what I learned. Start with the non-throttle
    side first. Be prepared to use some of the old hardware until you get
    to Lowe's/HomeDepot to buy some more washers (first stop this
    morning). When going to the throttle side, and when you remove the bar
    insert, don't worry...the bolt isn't stripping no matter what you
    might think. When you put the bar grommet on, don't set it tightly to
    the bar's edge....leave a gap where the grip doesn't go over it. When
    installing the new insert, don't force it in until it stops....it's a
    bitch to pull back out and probably won't come back out all the way.
    If you happen to skip the last mentioned step, DON'T PRY THE INSERT
    BACK OUT USING YOUR LEG TO BRACE THE BIKE....it tends to cause a bike
    to get off balance and get in the bed with you (ask me how I know)! If
    you followed the before mentioned step, tighten the throttle side
    throttlemeister until tight and you'll see how it works. Then make
    your adjustments by forcing the insert in ever so slightly and making
    adjustments from there.
    It looks cool though! Especially the new character marks the Bird
    has.....DOH!!!!
    Nothing like having a 550lb Blackbird get into a bed with you @ 3:30am
    and try to make passionate love....GEEZ!!! I thought I was going to
    have to call louie to come get this big bitch off me....I heard he's
    quite versed in these sort of things..... :)
  2. Brian Walker
    redshad Guest
    That should be Big Eds new handle..The Throttlemeister.
    Redshad
    redshad, Mar 5, 2007
  3. Brian Walker
    louie Guest
    or better 'Throttlemiser'
    ....louie
    louie, Mar 5, 2007
  4. Brian Walker
    Ed Hart Guest
    I still get there before you guys
    Ed Hart, Mar 5, 2007
  5. Brian Walker
    BJayKana Guest
    Redshad
    Everyone needs a real motorsikel handle, this name is a good one, or
    ''bar grommet'. sounds good too.
    B. Jay Kana--
    NETexas
    03Valk-&-98 Magna
    Have a Dandy Day--
    BJayKana, Mar 5, 2007
