More RD madness
Discussion in 'Classic Motorbikes' started by Hog, Apr 15, 2006.
  1. Hog
    Hog, Apr 15, 2006
  2. Hog
    Lozzo, Apr 15, 2006
  3. Hog
    Number plate too big.
    No crash damage.
    Nasty yellow colour.
    No melted cheese and jalapeños on the taco.
    platypus, Apr 15, 2006
  4. Hog
    They've grafted an XS750 clocks, indicators and front master cylinder
    onto it?
    Pip Luscher, Apr 15, 2006
  5. Hog
    Pip Luscher said...
    RD clocks, RD and XS share the same indicators, but well done for
    spotting the master cylinder resevoir is wrong. That one belongs to a
    twin disc bike.
    Anything else?
    Lozzo, Apr 15, 2006
  6. Hog
    Paul - xxx Guest
    Lozzo came up with the following;:
    Weren't the Speed blocks on the tank different, with the yamaha name being
    integral within the blocks at the front and the side panels shouldn't have
    speed blocks on them at all?
    ISTR it should also have black wheel centress with polished rim edges.
    Unless I'm thinking of later ones ... ;)
    Paul - xxx, Apr 16, 2006
  7. funnily enough, I was thinking thoughts like that when I read it.
    Austin Shackles, Apr 16, 2006
  8. Hog
    Paul - xxx said...
    Wroong on all counts.
    You are. You described an E or F model back there, this one's a D.
    Lozzo, Apr 16, 2006
  9. Hog
    Actually, the clocks would be right for an early XS750 if the tacho
    redlined at 7500 rpm.
    Sheer fluke: it was just familiar!
    Nah.
    Pip Luscher, Apr 16, 2006
  10. Hog
    Pip Luscher said...
    Didn't all XS750 speedos read 140mph?
    OK, here goes.
    The 'Yamaha' decal on the tailpiece is wrong, it shouldn't be there at
    all.
    The shocks should have black painted bodies with chrome springs, not all
    chrome.
    The shock springs are upside down, closer wound at the bottom, not top.
    Both calipers are wrong, those are from an early model, D models had no
    Yamaha badges.
    The handlebar clamp tops should be painted satin black.
    The seat cover is wrong, the original pattern was made of squares, not
    single lines going across the seat.
    Twin disc master cylinder resevoir.
    Wrong bolts holding handlebar clamps, originals were chromed and had
    smooth very slightly domed heads.
    Master cylinder cap screws were green or black anodised on originals,
    not zinc or chromed.
    Handlebar cable ties were clear plastic but same style as those ones.
    Rear mudguard is from an E or F model, the D model only had one rubber
    bung behind the number plate, this one has two.
    The satin finish on the engine cases is wrong. The D model was done
    gloss black and the satin finish appeared on E and F models.
    However, I don't want to appear to be a complete 'Originality nobber'
    and I think this is one of the nicest RD400Ds I have ever seen. It's not
    that often people restore the D model as the E and F were far more
    popular bikes and it's nice to see someone make the effort and spend the
    money to make a bike as good as this. I'd be very proud to own it, but
    I'd just have to put a few things right. Everything bar the seat cover
    would be a doddle to do.
    Lozzo, Apr 16, 2006
  11. out of interest, why? (apart from "'cos they are") Seems to me that the
    other way up probably (slightly) reduces the unsprung weight.
    [snippage]
    anyone ever tell you that you're obsessed?
  12. Hog
    Austin Shackles said...
    Umm, because on standard shocks they are always closer wound at the
    bottom. I haven't a clue what difference it makes to the handling, but
    as far as originality goes those chrome ones are wrong on two counts.
    Frequently
    Lozzo, Apr 16, 2006
  13. Hog
    Sounds about right, but I can't really remember.
    <speechless>
  14. Hog
    Paul - xxx Guest
    Bugger. Wasn't sure about how early the different decals came in.
