More odd behaviour from my ZZR1200
Discussion in 'Australian Motorcycles' started by Rural QLD CC, Sep 13, 2004.
  1. Rural QLD CC
    Rural QLD CC Guest
    Greetings,
    Recently I've experienced something strange when slowing down
    from highway speed on my ZZR1200. If I change down to either 5th or 4th and
    let the engine brake, occasionally the bike will jump out of gear and into a
    'false' neutral. The first time it happened, it almost felt like it was
    misfiring as it jumped rapidly in and out of gear. It didn't drop out of
    gear though. But the last couple of times, it's dropped out altogether. I
    know it's changing down cleanly, because I've been concious of that since
    the first time it happened. I thought maybe I hadn't pushed the lever down
    hard enough or something, resulting in an 'incomplete' change, if such a
    thing is possible.
    Anyone else had this happen? If so, what was the cause/solution. I've got
    the local dealer to call Kawasaki to find out if it's a 'known' issue, but
    I'd like some other input as well.
    Thanks,
    MrBonk
    www.mrbonk.com
  2. Rural QLD CC
    atec Guest
    split the cases ?
    atec, Sep 13, 2004
  3. typical kawasaki
    Frugal monster, Sep 13, 2004
  4. Rural QLD CC
    Conehead Guest
    How long since you changed the oil?
    Conehead, Sep 13, 2004
  5. Rural QLD CC
    Rural QLD CC Guest
    It was changed at the first service, approx 1500kms ago.
    MrBonk
    www.mrbonk.com
  6. Rural QLD CC
    Conehead Guest
    Then I'd be saying, "Dealer, fix my bike".
  7. Rural QLD CC
    Nev.. Guest
    You're probably just changed gear too lazily.
    Nev..
    '03 ZX12R
    Nev.., Sep 13, 2004
  8. checked the operation of the gear lever? is it loose?
    Just dump it on your dealer - demand a VN800 to cruise around on in the
    meantime. They are interesting experience - so take the opportunity to
    ride one.
    Baron Von Rotter, Sep 13, 2004
  9. Rural QLD CC
    GB Guest
    What Nev said. Lazy gear changes.
    Whilst admittedly the tyre valve stems are probably the
    only common component, I had similar 'false neutral' and
    jumping out of gear problems on my 03 zzr250, but it always
    seemed to happen to me on the upchanges whilst pottering
    around slowly in traffic, etc. Solution for me was to keep
    lifting the pedal until the clutch was all the way out
    again - once the load is back on it, it's happy to stay
    in gear and never gives any grief. Still happens to me
    when I get lazy, the box seems to have enough space in
    it for a 'false' neutral between a few gears.
    If that doesn't work, try splitting the cases.
    G
    GB, Sep 13, 2004
  10. Rural QLD CC
    MrBonk Guest
    No no.....this only happens on deceleration. I'm riding along in top gear
    at 100kmh, I roll off the throttle and almost immediately it starts to drop
    in and out of gear. Its happened once in 6th gear, twice in 5th and once in
    4th now. The last 2 times (in 5th and 4th), it dropped totally out of gear
    (having briefly engaged upon change-down), leaving me coasting along on an
    idling bike stuck somewhere in limbo between gears. I've yet to discover
    the false neutral thing on the upchanges.
    Either way, the bike shop wants it to have a look at it. They mentioned
    something about a 'selector drum' (can't remember exactly the terminology
    used) and being able to look at it by removing the clutch cover? Hopefully
    it's as simple as that to diagnose.....I don't fancy having a bike with less
    than 4000kms on it totally pulled apart :-(
    MrBonk
    www.mrbonk.com
    MrBonk, Sep 13, 2004
