Wotcha. Here's an MZ mystery for you. Take one MZ 250/1 - very similar to the one I bought from TOG. Six volt electrics - mechanical cable drive rev counter - charge light in speedometer. All in all, a normal, 1980, MZ. No mystery there, I hear you say. Right. Every now and again, especially when you pull the bike onto the centre stand, the rev counter stops working, the charge light comes on ( and the bike doesn't charge and begins to misfire ) and there's a slight mechanical "ticking" from the region of the crankshaft. Now I can understand the rev counter failing - it's driven direct from the crank - could be cable / drive unit / rev counter head. . . but why does it stop charging at the same time ? The dynamo is at the other end of the crankshaft to the rev counter drive. What's making the ticking noise ? Stop the engine and restart, and all is fine. There doesn't appear to be any deifite way to make the fault occur. Anyone got a clue where to start looking ? Typical - I get an MZ, and all of a sudden folks turn up thinking I am the great MZ guru . . . . as if I ain't got enough problems with just the one I own ;-)
