More Cibie headlights
Discussion in 'Classic Motorbikes' started by Hog, Mar 18, 2006.
  1. Hog
    5-3/4 inch Cibie in a cheapo Bates style shell. 1st run down some back
    roads this evening. "Oh Yes" most illuminating. I shall buy the second
    one now. Cheap solution, about £50 all in per side. Just need to run
    some heavy duty wire up and splice in a relay.
    What are regarded as the best focussed 60/55W H4 bulbs available now?
    It is still tempting to add a couple of small H2 spots under the main
    units for truly horrible wet dark journeys. Would a Bandit genny cope
    with 240 watts of high beam?? IIRC the output is around 400w total but
    not sure.
    Hog, Mar 18, 2006
  2. Hog
    JB Guest
    Osram Silverstar or Philips Vision Plus. Accept *no* alternatives.
    It's not the alternator's output that matters unless you leave them on for
    hours. The battery will deliver enough current; it will just lose 'charge'
    the longer you leave them on. Don't forget your coils (especially) and other
    lights use a fair bit of current too.
    JB
    JB, Mar 18, 2006
  3. Hog
    Ok, TVM
    Well my question was whether the alternator is beefy enough to feed them
    full time as well as all the other electronics plus battery charging
    Hog, Mar 18, 2006
  4. Philips Silver Star or somesuch. I've got a pair of them in and they
    really do put out extra light for the wattage, unlike the blue-tinted
    bollocks. I'd say they are on a par with the 100/80s I've got in the
    van.
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
    Grimly Curmudgeon, Mar 18, 2006
  5. Hog
    Scraggy Guest
    Scraggy, Mar 18, 2006
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Hog
    On a related topic, is it just me or are there more wankers driving
    around with overbright and / or badly adjusted dip beams these days?
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Mar 18, 2006
  7. I was thinking both these thoughts not so long ago. The Audi has Xenons
    which are almost offensively bright - there surely has to come a point
    where lights are too bright for road use?
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Mar 18, 2006
  8. Even worse just side lights
    Steve Robinson, Mar 18, 2006
  9. I've found the Philips "Vision Plus" to be good. Other makers are also
    selling bulbs with similar claims. I don't know whether the VP are indeed
    50% brighter (than what?) but they make a nice light.
    Austin Shackles, Mar 18, 2006
  10. Hog
    SteveH Guest
    Not just you. Fuckers are everywhere.
    I think, however, that it's just that you notice it more now headlamps
    are better designed, IYSWIM.
    I saw some twat the other day with 'rainbow' sidelights (they must have
    had some LED cluster that changed colour in them), blue washer jets and
    yellow tint fogs driving around in pitch black, snowy conditions the
    other day.
    SteveH, Mar 18, 2006
  11. Hog
    JB Guest
    They actually are indeed 50% brighter than the standard halogens they
    replace.
    Check out http://www.danielsternlighting.com/
    JB
    JB, Mar 18, 2006
  12. Hog
    Wot 'e said. I used to use 100/80W bulbs until I melted the RF's
    headlight plug. I got more and better focused light from a 60/55
    Osram Silverstar. Elly was astonished at the difference in light
    output when I slipped a couple of Silverstars into her Clio.
    Stay well away from anything with a 'blue tint'.
    Pip, Mar 18, 2006
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Oh, that's OK then.
    But it was! Z1's for goalposts...
  14. Hog
    deadmail Guest
    Yeah, too right. It wasn't like that five or ten years ago.
    deadmail, Mar 18, 2006
  15. Hog
    zymurgy Guest
    I manfully resisted a similar comment here. I hope you appreciate .. !
    P.
    zymurgy, Mar 19, 2006
  16. Hog
    Nicknoxx Guest
    I've been thinking this for some time and have come to three conclusions:-
    1. 30 years ago cars had useless headlights
    2. Too many twats fit over bright lights
    3. Age reduces light sensitivity making it harder to see in the dark.
    Conclusion: It's your age.
    Nicknoxx, Mar 19, 2006
  17. Hog
    I'm not sure my lights can be too bright for me but they need to be
    correctly adjusted and have good focus. The porker has projector HID's
    which are utterly amazing with perfect cut off but they self level every
    ignition key cycle. I've seen several Omega/Ford type things which were
    high and "somewhat" distracting
    Hog, Mar 19, 2006
  18. Hog
    I choked on my Earl Grey reading that one!
    Hog, Mar 19, 2006
    well no, I love the Audi Xenons, and hate getting back into the missus's
    Pug306 in the dark for this reason alone.
    Yup, same on the audi, but you can imagine the roads over here. Local
    roads are littered with speed bumps and drempels, major roads whilst not
    hilly, are far from flat with ripples and crests all over the shop.
    Dnc
    DoetNietComputeren, Mar 19, 2006
  20. Hog
    Pete Fisher Guest
    Unfortunately so true see:
    http://www.escrs.org/eurotimes/April2003/high.asp
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Mar 19, 2006
