More carrying suggestions...
Discussion in 'UK Motorcycles' started by Ben, Jul 31, 2007.
  1. Ben
    Ben Guest
    I need to put a tent, sleeping bag and roll mat on the back of the
    bike.
    Bear in mind, I have twin underseat cans with no heat shielding and
    they stick out a little from under the seat.
    Renntec sportrack with everything bungied (or similar) on?
    Ben, Jul 31, 2007
  2. Ben
    ventura luggage system?
    darsy, Jul 31, 2007
  3. Ben
    Are you suggesting you don't want to bungee stuff to the pillion pad?
    If you are happy to do so then one of the big Oxford roll bags, or similar
    alternatives, will hold a tent, bag and matt with a few clothes easily
    enough. Mine is pretty waterproof. Bonners was promoting something similar
    recently if you google.
    Hog, Jul 31, 2007
  4. Ben
    the Tiger had it fitted when I bought it from Phil.
    no idea - see above.
    What impressed me was:
    * how easy it was to switch between touring and "sport" racks & in
    particular
    * just how fucking huge the amount of space that was available inside
    the double-sided bag system.
    darsy, Jul 31, 2007
  5. Ben
    You really are getting rather pipe-and-slippers in your old age, aren't
    you?
    ogden, Jul 31, 2007
  6. Ben
    if you say so.
    I haven't actually used the luggage other than to cart home the
    various bits and pieces that came with the bike.
    darsy, Jul 31, 2007
  7. Ben
    Ben Guest
    looks a bit pricey
    Ben, Jul 31, 2007
  8. Ben
    Ben Guest
    No objections to bungying to the pillion pad, except it curves.
    Ben, Jul 31, 2007
  9. Ben
    Ben Guest
    I'll make a note to get the issue.
    Though I doubt they'll be "Camping by ZX10R".
    Ben, Jul 31, 2007
  10. Ben
    I guess it is - though it's cheaper and more appropriate for a sports-
    bike than hard luggage.
    darsy, Jul 31, 2007
  11. Ben
    Ben Guest
    You mean this sort of thing?
    http://www.busters-accessories.co.uk/proddetail.asp?prod=GTT418
    Ben, Jul 31, 2007
  12. Take the car.
    Paul.
    CBR1100XX SuperBlackbird (Buen mueble de patio)
    And a pushbike of some sort.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Paul Carmichael, Jul 31, 2007
  13. Ben
    Hog, Jul 31, 2007
  14. Ben
    Thinking about it, for a sprotbike, a rack with side rails which could mount
    a pair of monster size soft panniers would work quite well.
    One might want the natty sprotbike ally subframe copied in steel first mind.
    Hog, Jul 31, 2007
  15. Ben
    Ben Guest
    That looks quite good then. Although I don't think it's long enough
    to get my tent in. Will have to measure.
    Yeah, already got some of them for my car bike rack.
    Ben, Jul 31, 2007
  16. Ben
    Ben Guest
    Not much cop for a motorcycle tour though.
    Ben, Jul 31, 2007
  17. Ben
    Ah with those tie down straps I put the tent on top of the bag and filled it
    with other stuff on the way back. Still ubber secure.
    Hog, Jul 31, 2007
  18. Ben
    dog Guest
    it'll probably say strap it to the handlebars.
    dog, Jul 31, 2007
  19. Ben
    I use a Givi tailpack (which is more compact than the Oxford
    equivalent) strapped down with a couple of Rocstraps. I then bungee
    anything else to either the back or the top of the tailpack and that's
    the job done. It's only if I'm away for a couple of weeks that I
    bother using panniers and a tankbag will give you a fair bit of extra
    capacity rather than resorting to the panniers.
    I don't find the bike suffers from stability issues at any speed and
    it's only when the tankbag is full and I have to sit up in the wind
    that 150mph + becomes a pain.
    I can't say what the new (to me) Fastbag luggage is like but if it'll
    fit your bike, you want to speed test it, you can collect and return
    it and you're not away when I'm at the Manx GP then you're welcome to
    borrow it. Apparently it hold up to 60 litres and that's a hell of a
    lot of tooth brushes.
    Andy Bonwick, Jul 31, 2007
  20. Ben
    I did an indicated 160 on a bike with both D207Rs and a tailpack fitted.
    Died instantly, of course.
    ogden, Jul 31, 2007
