This is about a 1993 CBR600 F2. So after putting in a new battery and riding the bike around for the last week or so, I invested in a battery charger. I actually bought a tender, but the stupid seller sent me the wrong, bigass charger with clamps, etc. I hooked up the charger up to my old, dead battery. It charged up real quick and was stated to be full fast. Surface charge, I guess. I ran it down with a turn signal connected to the battery. Reconnect the charger. This time it takes a long time to charge back up. Good. I set it aside and go to the bike, get to the new battery, and top off the charge. I notice a loose quick-connector (yay!) and squeeze it closed. So I'm wondering how the old battery would do.... I throw it in the bike, turn the kill switch to on, and crank it up to see how well it cranks for 10 cycles or so. It cranks up strong with the old, recharged battery... lights look strong. I turn the kill switch off and start up the bike. I stare at the neutral light... no flickering, good. Next, I bring down the laptop with the Honda PDF. I do the current leak test. 0.00amps. Then I check the voltage at the battery across the RPM range. It looks like at <1300rpm the voltage drops below battery voltage (12.7V). At >1700, the voltages stay within specced range (13.3V-15.5V). So regulator/rectifier should be okay, right? I find the RR and check the continuity where it should be. However, I check the red/white and ground voltage, which should match battery voltage, and it doesn't work. I get 0V. Not sure if this is okay, but the RR does have the words CBR 95 chalked on it. I'm wondering if this was a replaced RR because the original one went bad. So all in all, I gave myself an electrics lesson and was able to check some electrics on the bike. Any thoughts on what I've revealed?
