More B12 Questions
Discussion in 'UK Motorcycles' started by 'Hog, Sep 19, 2005.
  1. 'Hog
    'Hog Guest
    Around 90 mph, not sure if the gearing is standard, the vibes are an
    unpleasant buzz which kills headlight bulbs and numbs fingers. Is this
    par for the course?
    Is the Cam Chain adjuster automatic or manual adjustment?
    Any good tech resource sites for B12's on the Net?
    'Hog
    'Hog, Sep 19, 2005
  2. 'Hog
    Hah!
    6k - or 12 o'clock - being the ton on mine, you must be suffering the
    dreaded 5200rpm buzz. SFA to be done with it
    Google for SUKBOG
    Pip, Sep 19, 2005
  3. 'Hog
    Dr Zoidberg Guest
    The obvious solution would seem to be to go faster :0)
    Alex
    www.drzoidberg.co.uk www.ebayfaq.co.uk
    Dr Zoidberg, Sep 19, 2005
  4. 'Hog
    'Hog Guest
    Waaa Waaa
    It left me with no dip beams just south of Dublin after the dash back
    to Holyhead at said speeds :eek:/
    Bulbs are cheaper in RoI :eek:)
    I sent the crank/rods/pistons.flywheel of my R100 cafe racer to Basset
    Down Balancing in Swindon many years ago. They asked a few pertinant
    questions about where I wanted the unavoidable vibes to go but the end
    result was like no other BMW I've ridden.
    Time to do the shims then
    Ta, done
    'Hog
    'Hog, Sep 19, 2005
  5. 'Hog
    'Hog Guest
    Oh I did, believe me. Dun Loughaire to my door in Holywood, in the
    dark, in exactly 2 hours. That was having decided to go through Dublin
    centre and with one fuel stop.
    'Hog
    'Hog, Sep 19, 2005
  6. 'Hog
    Black Mike Guest
    The other suggestions are most valid, however, I am always suspicious
    of vibrations at 60mph and 90 mph. As these, quite often, are from the
    wheels being out of balance.
    If you've not had them checked lately, it worth getting them done.
    Black Mike, Sep 19, 2005
  7. 'Hog
    I thought the B12 was like the B6 and had screw and lock nuts. They need
    look at every three or four thousand miles.
    Just a thought, how up to the job is the Bandit 12s oil system when
    standing on its rear wheel at high rpm?
    Muck, Sep 19, 2005
  8. 'Hog
    'Hog Guest
    Stop that now!
    'Hog
    'Hog, Sep 19, 2005
  9. 'Hog
    'Hog Guest
    <paging lozzo on brakes>
    You reckoned that junking the Tokico six pots for 4 potters was the
    best bet.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7999108679
    I appear to have some.
    Now I need a couple of Uncle Nigel adaptor plates or a set of 996
    Showa/Ohlins USD forks ;o)
    'Hog
    'Hog, Sep 19, 2005
  10. Pip wrote
    steve auvache, Sep 19, 2005
  11. 'Hog
    5,2k mate - the burds love it.
    Pip, Sep 19, 2005
  12. Pip wrote
    I speet on your nasty squeaky high frequency 5.2k and I have zees to say
    to you, "(factory)Custom V Twin".
    And the bitches are *more* than welcome to come and feel for themselves.
  13. 'Hog
    Veggie Dave Guest
    Over fill it slightly and you'll have no problems
    Veggie Dave
    UKRMHRC#2 BOTAFOF#08
    IQ 18 FILMS http://www.iq18films.com
    Extreme Racing http://www.veggie-dave.co.uk
    Toxic Shock Syndrome Gets More Girls Than Me
    Veggie Dave, Sep 19, 2005
  14. 'Hog
    Muck says...
    B12 is shimmed and doesn't need doing with the same regularity as a B6.
    Lozzo, Sep 19, 2005
  15. 'Hog
    'Hog says...
    65mm is what the later Gixer brake centres are at, but the angle may put
    the pads at right angles to the discs. Making adapter plates is a piece
    of piss.
    Lozzo, Sep 19, 2005
  16. 'Hog
    'Hog says...
    Was that cute blonde working on the toll booth at Drogheda?
    Lozzo, Sep 19, 2005
  17. 'Hog
    That's strange, because it must have changed. In the 1995 to 1997
    Bandits, the 6 and 123 are both screw and lock nut. My 600 is screw and
    lock nuts, and it's a 1998 model.
    Muck, Sep 19, 2005
  18. 'Hog
    :eek:))
    Muck, Sep 19, 2005
  19. 'Hog
    Yeh, that'll make sense if the oil pickup is in the same sort of place
    as the B6s one.
    Muck, Sep 19, 2005
  20. 'Hog
    'Hog Guest
    Umm mine is a 1996, I'm confused now.
    'Hog
    'Hog, Sep 19, 2005
