More adice on value of bikes!
Discussion in 'UK Motorcycles' started by elziko, Feb 9, 2004.
  1. elziko
    elziko Guest
    I've pretty much settled on buying a low mileage Ninja 6 (B1H - the new one
    with upside down forks, radial mounted calipers etc.) since I rode one the
    other day and I'm smitten!
    Anyway, after looking around I have found one with a Remus Titanium Exaust,
    double bubble and single seat cover thingie in mint condition and has only
    done 350 miles!
    He's wanting £5000 for it. This seems like a pretty good price to me... is
    it? I've looked on MCN and AutoTrader websites and they all seem at least
    500 more expensive and with a few more miles.
    And can you give me any advice on what checks I can do to ensure its not
    stolen and has no outstanding finance on it?
    Thanks for all your help!
    elziko, Feb 9, 2004
  2. elziko wrote
    try googling for this:
    "Basic vehicle info for free"
    No probs.
    steve auvache, Feb 9, 2004
  3. elziko
    AndrewR Guest
    Lloyd Coopers, experts on all thing Kwaky, advised me against fitting an
    after-market can until after the bike's first service ... which a 350 mile
    bike shouldn't have had yet.
    The again, I believe the engine is pretty robust (well mine managed 20,000
    miles between services without going "sproing!") and you'd probably have to
    be going some to shag it in that sort of distance :)
    First question then - is it a UK bike or a parallel import? If the latter
    you might have to actually pay for the first service, but as it's basically
    an oil change and checking that the wheels haven't fallen off it shouldn't
    be too much.
    HPI check, I guess.
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, Keeper of the TFSTR#
    The speccy Geordie twat.
    AndrewR, Feb 9, 2004
  4. elziko
    elziko Guest
    Thanks for the reply!
    Hadnt thought of that, do you know if they generally need to be popped on a
    Dyno or anything after having something like the Remus fitted?
    elziko, Feb 9, 2004
  5. elziko
    elziko Guest
    Thanks! It honestly wasn't available on my server when I posted! Otherwise I
    wouldnt have asked!
    elziko, Feb 9, 2004
  6. elziko
    AndrewR Guest
    Dunno - if it's a new bike it will be FI, whereas mine is good ol' carbs -
    might be totally different.
    OTOH, my tame mechanic reckons that, with most modern bikes, you're wasting
    your time putting an end-can on - they might give a tiny increase in top end
    power, but they'll almost certainly **** up something else, somewhere in the
    rev range.
    Kawasaki ZX-6R J1
  7. elziko
    Ben Guest
    But if you're serious about buying, fork out for a proper HPI check.
    Ben, Feb 9, 2004
  8. He's probably right, unless the bike is fuel injected.
    Mind you, old 1200 Bandits used to benefit immensely from a simple end
    can change.
    The Older Gentleman, Feb 9, 2004
  9. (The Older Gentleman) burbled:
    Hypothetically speaking, just out of interest you understand, what
    about the newer versions, like for example a K3, which has the older
    style exhaust system (bolt-on can, the K4 has a different arrangement)
    but the newer style ignition/throttle position sensor and PAIR system?
    While I'm on the subject, I've found that it really doesn't like low
    revs, say under 2k rpm - between 1.5k and 2k rpm it spits back into
    the airbox quite a bit, and at town manoeuvring speeds even in first I
    have to slip the clutch more than I'd have expected. It's due its
    first service by the end of the week (600 miles/1000 km), so I'll
    report it to the spannerer anyway.
    Darren Robinson, Feb 9, 2004
