more 82 750 seca electric problems
Discussion in 'Motorbike Technical Discussion' started by zoot, May 19, 2008.
  1. zoot
    zoot Guest
    well i got a new battery and have been riding it for a few days and it
    still starts [ hope this doesn't jinx it]. it starts out o k sometimes
    but usually with no lo beam. after a while the high beam and aux light
    cut out but i can get them back on while i tip the bike to the left
    and off to the right. after a while that doesn't work either. haven't
    tried an exorcist yet. HELP!!!
    zoot, May 19, 2008
  2. zoot
    Who Me? Guest
    Stop typing messages and get a meter and a flashlight and start LOOKING for
    the problem.
    The web cam that you have provided for US to look at is too grainy. ;-)
    There is a wiring problem.....<gasp>
    "WE" cannot really help YOU find it.
    Good luck!
    Who Me?, May 19, 2008
  3. zoot
    . Guest
    Wiggle on the wires going from the headlight switch on the left
    handlebar to see if there is a bad wire inside the plastic tubing.
    Massage the tubing all the way from the switch to the headlight
    bucket.
    Also, the headlight switch might be corroded inside. There are
    chemical cleaners like Deoxit (sp?) available, but I use Tarn-X, a
    silverware tarnish remover found in supermarkets and drugstrores.
    If you take your headlight switch apart, be careful not to lose any
    little screws or break any parts, as you will have to find another
    switch if that happens, the Yamahahahaha $tealer$hip doesn't have
    stuff like that.
    ., May 19, 2008
  4. Had you considered the possibility of a loose wire ?
    If you can't find and fix it, pay somebody who can.
    Rob Kleinschmidt, May 19, 2008
  5. Have you had a good look at the fuse box? Some old Yamahas have fuse
    holders which turn totally brittle over time. Take out each fuse and
    try to pinch the springs a little closer so the fuses fit tighter. If
    the fuse holder breaks (quite likely), replace the fuse box.
    Robert Roland, May 19, 2008
  6. zoot
    zoot Guest
    good suggestions. i did try disconnecting all connectors cleaning ,
    greasing, and reconnecting them.also got switches and controls from e
    bay and will try that soon. loose fuse? wouldn't that be a hoot? never
    would of thought of that.
    zoot, May 19, 2008
  7. zoot
    tylernt Guest
    Yeah, that's a good thing to check, but the fuse holder itself likes
    to go bad. Common fix is to replace it with inline blade fuse
    holders... in fact mine had already been done when I got the bike.
    tylernt, May 20, 2008
  8. zoot
    zoot Guest
    it was a rotor brush worn down to a nub.
    thanks folks
    zoot, Jun 16, 2008
  9. A worn rotor brush caused an intermittant failure
    of the low beam and later the high beam ????
    And the problem got better when you tipped the
    bike left and right ????
    Rob Kleinschmidt, Jun 17, 2008
  10. zoot
    zoot Guest
    yep!!!
    these things happen to someone who doesn't want to be a motorhead and
    just wants to ride. oh well!! at least now all my wires and
    connections have been well cared for.
    i don't know what part the warm up played but i think there was enough
    slop in the rotor that a hard lean to the left let it go to the
    brush.lo beam was another problem [broken wire].
    zoot, Jun 17, 2008
