monster clutch rattle ?
Discussion in 'Australian Motorcycles' started by isaac_the_blind, Aug 17, 2006.
  1. Well, the associate bought the Ducati Monster. It's got a half cover
    over the clutch ( supposedly genuine D part). at idle the clutch RATTLES
    but when clutch lever is pulled in rattle goes BUT high pitch noise
    appears, sound like dry/failed bearing.
    Is this normal ???
    Isaac.
  2. isaac_the_blind
    atec77 Guest
    Tine to split some things ?
    atec77, Aug 17, 2006
  3. isaac_the_blind
    David Guest
    Sounds like it needs a clean out to me, you local bike dealer can do this
    our you can do it yourself.
    Lushy
    ST2 Owner
    David, Aug 17, 2006
  4. isaac_the_blind
    David Guest
    Second thoughts it may just need a bit of a run to clear out the dust.
    Lushy
    David, Aug 17, 2006
  5. I have a dry clutch Ducati and my clutch rattles in neutral with the clutch
    out, rattle disappears when the clutch is pulled in, as is your associates
    experience
    I do not however hear a high pitch noise with the clutch in but I have the
    original "full" cover which may have the effect of masking this noise
    Capt A. L.
    Capt.about lunchtime, Aug 18, 2006
  6. isaac_the_blind
    Nev.. Guest
    some Ducati owner you are!!! keep that up and you'll be refused entry to
    Tourismo...
    Nev..
    '04 CBR1100XX
    Nev.., Aug 18, 2006
  7. isaac_the_blind
    David Guest
    No way mate, moneys in and the motels are booked ;)>
    David, Aug 20, 2006
  8. isaac_the_blind
    melchizedek Guest
    cant see how riding around with half the clutch exposed to dust,
    small birds etc is a good idea :-(
    M.
    melchizedek, Aug 21, 2006
  9. isaac_the_blind
    john doe Guest
    lets the oil out...
    john doe, Aug 21, 2006
  10. Think of the weight saving, I know it's sprung weight, but still a great way
    to improve performance by as much as 0.00379%
    And it looks Horn
    Capt. A. L.
    Capt.about lunchtime, Aug 22, 2006
