Mods and Rockers
Discussion in 'UK Motorcycles' started by Alan.T.Gower, Dec 9, 2003.
  1. Alan.T.Gower
    K Olley Guest
    Tassles are designed for a practical reason, this reason has now been
    superceeded by the use of modern waterproofing techniques:)
    Kevin - Basildon
    XV535
    GPZ305 (her's)
    BOTAFOT#67 BOTAFOF#23
    OSOS#29
    K Olley, Dec 9, 2003
    #41
  2. Alan.T.Gower
    Salad Dodger Guest
    No way, with all that lot it's still less than a UK spec Wing would
    have been.
    UK spec (i.e. shite) £16750,
    Canadian (wiv lots of shiny bits, and extra lights) £13000.
    Easy decision, even 7 years ago.
    Salad Dodger, Dec 10, 2003
    #42
  3. Alan.T.Gower
    Salad Dodger Guest
    You bolted the clutch to the chassis, and you still wonder why the
    gearbox went AWOL? :)
    #43
  4. Divvy 600 and 900
    Givi Wingrack,box and paniers.
    Why? Usual reasons that I didn't have to wear a haversack, use
    throwovers etc.
    Worthwhile buy. As well as the above, keeps luggage dry and more
    secure. Plus has saved the 900 from more expensive damage after one
    drop and one lowside.
    Richard Alexander, Dec 10, 2003
    #44
  5. Alan.T.Gower
    Sean Doherty Guest
    B12: luggage. Yes is was worth it.
    F650: came with luggage and heated grips and were well worth it.
    Sean Doherty, Dec 10, 2003
    #45
  6. Alan.T.Gower
    there's a good farmer's market there at the weekend.
    darsy, Dec 10, 2003
    #46
  7. Alan.T.Gower
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, darsy
    Do they sell eggs?
    Nigel Eaton, Dec 10, 2003
    #47
  8. Alan.T.Gower
    dwb Guest
    Mmm, I did mine twice in the space of two weeks like a complete twit.
    First time "hmm bike isn't moving... push a bit.. CRACK.. bugger" which took
    out a half-circle from the disc lock.
    Second time something similar, only it just cracked, which you can't
    actually see, so it's not that bad.
    When I sell the bike I'll probably superglue the bit that snapped off on in
    the carpark of the dealer :-O
    dwb, Dec 10, 2003
    #48
  9. Alan.T.Gower
    I believe they do.
    (very good, BTW).
    darsy, Dec 10, 2003
    #49
  10. Alan.T.Gower
    Ben Blaney Guest
    I don't own a disk lock. That's the safest way.
    Ben Blaney, Dec 10, 2003
    #50
  11. Alan.T.Gower
    you're correct in your assertion. However, I'm less than keen on
    parking my Fireblade in central London without one.
    darsy, Dec 10, 2003
    #51
  12. Alan.T.Gower
    Ben Blaney Guest
    Of course your fireblade is more desirable than any of my bikes, but
    I've never used any kind of lock while parking in central London.
    #52
  13. Alan.T.Gower
    don't get me wrong - I'm not saying the disklock stops the bike
    getting stolen, but I'm paranoid enough to want to use it.
    darsy, Dec 10, 2003
    #53
  14. Alan.T.Gower
    Nigel Eaton Guest
    How often do you go back to check you actually put it on?
    #54
  15. Alan.T.Gower
    Linger Guest
    I leave a big pink girly hairband on my throttle when I use my disk lock.
    So far I haven't forgotten it.
    Linger, Dec 10, 2003
    #55
  16. Alan.T.Gower
    I've never done that.
    My OCD problems lie in other areas.
    darsy, Dec 10, 2003
    #56
  17. Alan.T.Gower
    Ginge Guest
    You did switch the lights off before leaving for work, didn't you?
    Ginge, Dec 10, 2003
    #57
  18. Alan.T.Gower
    darsy, Dec 10, 2003
    #58
  19. Alan.T.Gower
    Robb Edge Guest
    ME: VTR1000F
    1: Hugger: 55ukp from NEC 'tother year
    yep, keeps the penske looking like new2: Revolution revalved forks.
    Why? cos stock storm forks are cack, dive to much under braking, skip about
    on bumpy bits.
    Now, nice and plush. Can get away with panick braking hard into a corner.
    3: Revolution spec Penske shock
    Why? cos stock storm shock is cack. Back end gets all squirmy in fast
    sweepers.
    Now, sorted back end. Lets the tyres do there stuff
    4:Dunlop 207RRs
    Why? Cos the Macrapam M90's were cack.
    sticks like a sticky thing
    5:High level Mig Cans.
    Why? cos they were cheap and sound good.
    Whats next?
    Possible flat bar conversion, black powder coat finish to wheels, swing-arm
    and frame, or a Honda Prelude 2.2Vtec
    Robb Edge, Dec 10, 2003
    #59
  20. Alan.T.Gower
    dwb Guest
    I'm confused... have you purchased _another_ 7R?
    dwb, Dec 10, 2003
    #60
