Mixture 2stroker versus4
Discussion in 'Australian Motorcycles' started by Matblack, Jul 15, 2003.
  1. Matblack
    Matblack Guest
    A question for all you tech heads out there.
    Why if you open up the airbox on a two stroke will you get detonation
    (without rejetting). When a four stroke will not detonate when you do the
    same thing. I know that to achieve the most potential from the mod a four
    stroke will need rejetting or a remap if fuel injected, but you won't burn
    holes in the pistons if you don't either, but with the two stroke you will
    or could. I know this from experience, but what makes it so?
  2. Matblack
    Daron Guest
    You will get detonation on both 2 & 4 strokes
    Reason is that the bike is running too lean as it is getting too much air in
    the air/fuel mix.
    As 2 stokes are in a greater stage of tune, they will detonate faster than
    the 4 stroke.
    If you run the 4 stroke long enough, you will get a holed piston as well
    Daron
    Daron, Jul 15, 2003
  3. Matblack
    Johnnie5 Guest
    what bike, what mods ??
    some bikes are jetted rich from the factory
    if worried get it on a dyno with a mixture probe
    not much dollars to find out
    Johnnie5, Jul 15, 2003
