Mirror
Discussion in 'Texas Bikers' started by Dusty, Jun 10, 2007.
  1. Dusty
    Dusty Guest
    I have a 1981 Gloldwing the mirror's are mounted on the faring. I have
    noticed on windy days that the mirror will move out of adjustment. How can I
    tighten up the mirror so it wont be so loose ?
    Thanks,
    Dusty
    Dusty, Jun 10, 2007
  2. Dusty
    Bill Walker Guest
    As I recall.. the fairing on that model were fabricated by someone other
    than
    Honda.. hmmm.. Don't remember exactly who that was.. In any event, Honda
    doesn't have access to the accessories that came with the fairing.. and it
    was
    necessary to order parts, like mirrors. from the fabricator.. Also, as I
    recall..
    the 1984 GoldWing was the first one that came with the Honda fabricated
    fair-
    ings, trunks and bags..
    The mirror problems on those models were a chronic situation and the later
    models could be tightened and/or adjusted.. The earlier models like yours
    wore pretty quickly and about the only recourse was to replace the mirrors..
    If you have access to a very helpful Honda parts guy.. maybe he can help
    you to locate a source for those pesky mirrors and you can replace them
    with something that appears original and not some bolt on type crap..
    I'm thinking that your mirrors are not too adjustable as far as tightening
    them
    very much.. Just not too much to work with, there.. Good luck and I hope
    you find what you need.. hmmm.. A little touch of clear epoxy might help
    some.. Regards
    Bill Walker
    Irving
    Bill Walker, Jun 10, 2007
  3. Dusty
    Brian Walker Guest
    Actually, if I remember correctly (and it's been a few years....about
    20 to be more precise) from my old Wing, if the fairing is a Hondaline
    fairing and not a Vetter you can remove the mirror from the fairing
    and tighten the mirror from the inside. Basic small movements were
    done by moving the head of the mirror. If the operator wanted more
    visability, there was a section at the base mount to loosen and make
    larger adjustments and then tighten back up before mounting.
    Again, this is assuming it's a Hondaline and not a Vetter.
    Brian Walker, Jun 14, 2007
