Mini ride report - Dnepr MT-11
Discussion in 'Classic Motorbikes' started by sean_q, Nov 3, 2010.
  1. sean_q
    sean_q Guest
    Decided to take it for a spin today -- without regular exercise
    it tends to get a bit flaky. In the best Soviet tradition
    I brought along a hammer (rubber with lead shot inside).
    As I expected, soon after I opened the petcock, gas started pouring
    out of each carb. So I flailed away on them with the rubber hammer,
    trying to agitate the floats and needle valves so they would
    activate to shut off the gas (er, petrol). Sure enough it worked.
    I was able to drive away with the usual clatter, commotion
    and jangling without leaving twin trails of dribbling gasoline.
    Life under Communism must have been... "different".
    SQ
    sean_q, Nov 3, 2010
  2. sean_q
    crn Guest
    Dont feel too bad about it, the 400/4 is famous for the same problem.
    A few taps with the handle of a screwdriver is usually enough to
    wake up the recalcitrant carbs.
    crn, Nov 3, 2010
  3. sean_q
    Rusty Hinge Guest
    The Hammer and the Motorsickle?
    Rusty Hinge, Nov 3, 2010
  4. sean_q
    sean_q Guest
    Brilliant!
    "I don't want a pickle,
    Just want my hammer and 'sickle." --Arlo Guthrovich
    refers to the WW2 T-34 tank transmission:
    "The makers of the T-34 were clever fellows. They knew
    the transmission in their tank was garbage, so they
    put it right where you could get to it easily, chuck
    a bad one away and shove in another. The location
    in the back had one drawback for the driver: it made
    the tank's gears tough to shift because of the long
    drive train running through the floor. Dimitri and
    the other Russian tank drivers learned to keep
    a hammer under their seats for the more stubborn
    moments of the T-34's transmission."
    --_Last Citadel: A Novel of the Battle of Kursk_
    By David L. Robbins
    SQ
    sean_q, Nov 3, 2010
  5. sean_q
    crn Guest
    No, a Bar Tangled Spanner.
    crn, Nov 3, 2010
  6. sean_q
    Rusty Hinge Guest
    For most Yanktanks, the Star-Spangled Banger?
  7. Wasn't the definition of the Golden Gate Bridge "The Car Strangled Spanner"?
    Dr Ivan D. Reid, Nov 3, 2010
