Mille R mini-review
Discussion in 'UK Motorcycles' started by simonk, May 30, 2005.
  1. simonk
    simonk Guest
    Not before time, but since I did *nearly* *two* *hundred* miles on the thing
    today I thought it was time to be stringing a few sentences together.
    Coming from the old Mille, the new model feels like a completely different
    bike, which is reassuring, cos it pretty much is. The old bike was
    physically big - the new one is tiny by comparison, feeling more like the
    GSXR750 I had a quick go on a few weeks ago. Whereas the old bike had a
    distinct top-heavy feel to it which meant that getting it round tight bends
    in town was a bit of a handful, this one feels much more eager to go where
    you point it, without having to wrestle the bars. You feel crouched closer
    to the road, very much "in" the bike, and at the risk of a wibble-flip-doo,
    closer to the centre of gravity
    The motor's very different too, seeming much more eager to rev, though
    noticeably more breathless low down. Still running in, of course, but I can
    definitely feel that it needs a bean or two more away from a standstill.
    Consensus on the Aprilia forums is that this is easily sorted with the fuel
    map from the 05 bike, or a chip-and-pipe job.
    Overall it feels much more Japanese than the last bike - and I mean that in a
    nice way - although there are still a couple of Italian "touches" such as the
    heavy Brembo hydraulic clutch and near-useless rear brake. The (non-radial)
    front brakes are even more mind-bending than on the 02 bike, by way of
    compensation. Fit and finish is a step-change up from the last model, and
    the battery-sapping Austin Montego clocks are now banished:
    http://www.simonk.org/bike/mille/
    Riding round Basingstoke and Alton today, with a minging cold and the
    expectation of just going for a potter at not-much-above-NSL speeds, I was
    repeatedly, pleasantly surprised at what the speedo was telling me - 80 felt
    like 50, though the muffled engine note and my bunged up head probably
    contributed to this.
    Probably the only thing I'm not too keen on is the rock-hard stock suspension
    settings[1], so I'll be having a tinker next weekend.
    In short, it rocks.
    [1] anyone with any ideas for a proper, methodical way to approach this,
    apart from "just **** around with it until it feels OK" ?
  2. simonk
    simonk Guest
    They're both based on the Gol<BANG>
  3. simonk
    simonk Guest
    There are some issues around the clutch master cylinder, and the fuel
    injection "hunting" on a trailing throttle at low speeds, but these are
    fixable by recall - replacement Brembo part for the clutch, new ignition map
    to fix the throttle problems (can't say I've noticed it, mind)
    Other than that, which isn't much more than a typical Jappo bike, that seems
    to be about it. My last one was mechanically fine, but let down by a crappy
    fuel pump connector, which gave me problems starting until I traced what it
    was (having completely shagged the battery in the process)
  4. My brother has one bonwicks seen it.
    http://simonb.zapik.com/swiz2004pics/DSCF0414.JPG
    Brov has sorted it already. And a re-map for race cans. Makes it go much
    better.
    Again brov has set his up much softer. It makes it very plush. But frame
    etc is so good it doesn't upset it at all.
    That's what my brother says. He's also fitted the higher bars from the
    tourno?
    You really need to speak to my brother.
    eric the brave, May 30, 2005
  5. simonk
    simonk Guest
    Does he weight about 75kg? Cos if he does, I'd love to know what he's set
    the suspension to ...
  6. He should be here soon...
  7. simonk
    Molly_Thai Guest
    Really? The size of it is one of the reasons I didn't buy one. Is it as low
    as say the 10R or new Gixxer Thou?
    Now that's a shame, I liked the old motor, tons of torque low down.
    IMO you buy a Mille R because it feels different to Japanese bike but lack
    their quality.
    Nice review
    CIHAGM
    Don't. Please don't
    If you must then just try setting the static sag first.
    http://www.bikegirl.co.uk/resources/racing/suspension.html
    If you're still not happy wait until everything losens up after say a couple
    of thousand miles. By then you may like the suspesion.
    Molly
    "Gower School" By Appointment".
    GSX-R1000
    GHPOTHUF#27
    TGF, UKRMFBC#7, Two#24, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://www.sportsbike.org
    Molly_Thai, May 31, 2005
  8. True enough. :)
    eric the brave, May 31, 2005
  9. Bro says he has now set his suspension back to standard. He had it on
    soft while it was running in.
  10. simonk
    Aethelred Guest
    Right then... I havn't eaten for two days and spent all yesterday out
    on the dirt bike without drinking any water. Managed to get out of bed
    this morning to weigh myself. Shit, still 15 stone.
    As for suspenion setup. I ran it in for a little while with everything
    set on the softest. Then increased the comp/rebound untill it felt
    right. I like very little compression. I told myself that I should
    check the sag. Maybe I will one day... I don't think it is far out.
    Mind you mine has not got the Ohlins kit.
    Done 9000 miles on mine. I just ride the thing...
    Joss.
    Aethelred, May 31, 2005
  11. simonk
    Note to Kenyon, check the indicators. They seem to stick on.
    ogden, May 31, 2005
  12. simonk
    Aethelred Guest
    -- ogden, zx7r
    Didn't seem to have much time to look down at indicator light on the
    French run. To busy trying to keep a Zx7r in sight...
    Joss
    Aethelred, Jun 1, 2005
  13. simonk
    Aethelred Guest
    really? The size of it is one of the reasons I didn't buy one. Is it as low
    I have ridden K3 and found the seat was high and sloping forward. Put a
    lot of weight on my rists. I found it uncomfortable. The height is
    pretty much the same.
    <snip>
    New engine revs to eleven grand...
    IMO the Japs don't finish a bike off. The always look laking in
    something. The Aprilia has top quality parts and finish. I don't think
    there are any reliability issues with the Aprilia.
    Just remember what was standard.
    Personally, I have never ridden a bike that handles as well and so easy
    to get in and out of a corner...
    I just rode it around for a while on the softest settings. You will
    probably need to replace the springs...
    Joss
  14. simonk
    Hear that simon? An '05 Mille R had trouble keeping up with a pissed
    bloke on a stone age pseudo-600. ;)
    ogden, Jun 1, 2005
  15. simonk
    Aethelred Guest
    It's an '04 RSVR. If that makes a difference. I need an outrider to
    remind me to do the more mundane things one needs to do on public
    roads. ( Like overtaking on right. Not using every inch of tarmac.
    Correct use of indicators. etc.)
  16. simonk
    Molly_Thai Guest
    < a full bags of snips>
    The K5 is tiny when compared to the K4. It's smaller that the CBR1000.
    I still fancy the 10R though.
    Molly_Thai, Jun 1, 2005
  17. simonk
    mups Guest
    Molly_Thai says...
    A whale on the pie and chips plan diet is smaller than a CBR1000
    Oh, *that* CBR1000...
    mups, Jun 1, 2005
  18. simonk
    DR Guest
    A co-worker of mine, known for her small stature, had a sit on a K5 at
    the weekend. She doesn't ride on roads any more, just track days, but
    she was sorely tempted due to being able to get both feet comfortably
    on the ground; she normally rides a ZX-6R track bike (with lowered
    seat & suspension).
    DR, Jun 2, 2005
  19. simonk
    DR says...
    Go on, tell her I think it'd be a good idea for her to buy one. How is
    her old man getting on now?
    Lozzo, Jun 2, 2005
  20. simonk
    DR Guest
    Will do. He seems to be okay now, itching to ride again but he's
    decided the Mille has to go, as it's tried to kill all the previous
    owners too...
    DR, Jun 2, 2005
