Mild front end wobble
Discussion in 'Motorbike Technical Discussion' started by Ted Bennett, Jun 16, 2004.
  1. Ted Bennett
    Ted Bennett Guest
    My bike exhibits a mild wobble of the forks and bars almost any time I
    remove my hands from the grips. It is present at any speed and never
    increases in amplitude so it's not too scary. It immediately damps down
    to zero when I grip the bars again. Because I can't accelerate without
    grabbing the bar, I don't know if that would stop it.
    Still, I would prefer not to have this situation. Anybody have
    suggestions on what causes this and what will stop it?
    So far I have checked the rear swingarm bearings, the head bearings, the
    front wheel balance, and the tire pressures. All OK. There is no
    uneven wear on either tire.
    All motorcycles are single tracked, front steered vehicles, so I don't
    think the make matters much, but it's a Royal Enfield, an old Brit.
  2. I wouldn't.
    Brinnelling. Nothing to do with old Isambard at all.
    Except that a notchy set of head races produces a different effect. A
    sort of gentle rolling motion. So I'm afraid you are wrong here.
    <snip>
    Worn tyres, mismatch between front and rear in terms of wear, heavy
    luggage on the back, or just unsuitable tyres.
    Lots of bikes do this to a greater or lesser extent. Don't ride
    hands-off.
    The Older Gentleman, Jun 16, 2004
  3. Ted Bennett
    Pete Guest
    This is probably the phenomenon that Bruce was referring to....
    http://www.tribology.co.uk/services/investigate/rb03-4.htm
    I've heard of this before. An example I can think of was a story about a
    bunch of Japanese cars that were cinched down to the deck of the freighter
    by their frames. The vibration of the ship during the voyage caused the
    stationary wheel bearings to "Brinnell" (or "false brinnell" as this site
    calls it) and as a result they failed prematurely in the cars.
    Point contact of the balls on the race makes it almost impossible to keep
    the stresses below a fatigue limit, that's why they publish the L10 life for
    bearings, the load at which 90% of them are still OK after a standard # of
    cycles (10^9 ? can't remember ). But they are supposed to fail eventually
    under any load because of this.
    Seems fork crown bearings would be a good candidate for this. Especially if
    the owner is fond of wheelies and lands hard.
    I know people who have had to have these bearings replaced.
    But this may not be the problem. Just so you don't think I'm picking a fight
    :) *** my bike will also do this wobble thing at certain speeds if I take
    my hands off the bars, it has done so since it was new***.
    There's my 2 one hundredth's of a buck. :)
    D.
    Pete, Jun 17, 2004
  4. That's interesting. Oh, head races brinnell all right - it's just that
    notchy head races show up with different symptoms.
    The Older Gentleman, Jun 17, 2004
  5. Ted Bennett
    Mark Hickey Guest
    The notches that show up in head races are "false brinnelling". This
    is common in bicycles as well as motorcycles, and for the same reason.
    On a bicycle (or a motorcycle for that matter), the impact loads never
    come close to that necessary to actually brinnell the headset. The
    phenomenon is caused by displacement of the lubricant, and the
    resultant metal-to-metal contact (actually "welding") that takes place
    at a microscopic level.
    Mark Hickey
    Mark Hickey, Jun 17, 2004
  6. Ted Bennett
    Ted Bennett Guest
    [Jobst Brandt is a cantankerous, and usually correct, bicyclist who
    points out (convincingly) that headset "brinelling" is actually
    fretting.]
    Ted Bennett, Jun 18, 2004
  7. Ted Bennett
    Battleax Guest
    Indeed, the correct term is "fretting". Brinell refers to metal hardness
    testing procedures and has nothing to do with wear in any form.
    B
    Battleax, Jun 20, 2004
