Mikuni BS34 question
Discussion in 'Motorbike Technical Discussion' started by Mike W., Apr 28, 2008.
  1. Mike W.
    Mike W. Guest
    I just cleaned our a 4-stack of BS34's for one of my KZ1000Ps. There's a
    small, double-walled pipe that descends down from the carb body through the
    float-bowl gasket that fits into a gallery in the float bowl made just for
    it.
    Can someone tell me what that pipe goes to? I tried to remove it by gently
    twisting it with some pliers.. no joy. I cleaned it but the most I got was
    carb cleaner blowing out the little side vents in it... it didn't exit
    anyplace else. A tag wire bottoms out. Any insight greatly appreciated.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    71 KG 100 (Hodaka-powered)
  2. Mike W.
    lugnut Guest
    That is probably your cold start enrichment (choke for us
    old farts) tubes. They don't come out for normal service or
    cleaning.
    Lugnut
    lugnut, Apr 28, 2008
  3. Mike W.
    . Guest
    That's the fuel pickup tube/starter jet for the starting enrichener.
    It doesn't come out, but if you spray Berryman B12 through it and get
    a good stream, you'll have no problems.
    ., Apr 28, 2008
  4. Mike W.
    Mike W. Guest
    Thank you - Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
  5. Mike W.
    Mike W. Guest
    Thank you... Seems I did that with the enrichener off... I got a good
    stream out the little side holes in the thing but didn't touch the path
    from the tube to the enrichener... think I should abort the re-assembly of
    the bike and go back and hit that?
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
  6. Mike W.
    . Guest
    That sounds like a good idea.
    Somebody posted a link to a schematic drawing of the BS34 to this
    group about a year ago, You might want to Google for that.
    ., Apr 28, 2008
  7. Mike W.
    Mike W. Guest
    Thanks.. some bit flipped after the third failed rebuild... the bike ended
    up on it's left side with half of my wrenches scattered around the garage.
    I'm selling the 2KZP's, the XR and Beta off after making it 6 months and a
    day without riding and through 3 rebuilds of the carb stack in two days.
    Your help, and the others', was appreciated. Thanks.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    Mike W., Apr 29, 2008
  8. Mike W.
    Mike W. Guest
    I think I "get" most of this carb now... there are three ports that supply
    fuel/air at low rpm:
    1. Idle-mixture port - working back from port, you have the mixture screw
    fed by the pilot jet, which in turn is fed air from one of the little air
    feeds on the side of the intake bell, and is fed fuel by a passage to the
    main jet.
    2. A pair of transition ports just upsteam of the butterfly. They appear to
    connect back to the idle jet as well.
    There is also the feed from the enrichener, but I'm not feeling I
    understand this very well. The fuel pickup tube supplies fuel to
    XXXXXXXXXXXXXXXXXXXXX when the enrichener is "on". Where do it go??? I
    can't see carb cleaner pushing out of any of the ports with the enrichener
    open or closed. The path, as revealed by the outside of the carb goes up
    near the mixture screw but zero carb cleaner ever reveals up there when
    sprayed under pressure.
    I want to ensure this "starter circuit" is right be fore I button the damn
    thing up for the 4th time. Any help would be sincerely appreciated.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    Mike W., May 3, 2008
  9. Mike W.
    . Guest
    The outlet hole is large, and carb cleaner would just dribble out.
    When you move the "choke" lever to ON, the enrichener plunger is
    raised, allowing AIR to
    flow through a large hole in the inlet bell. The air passage comes out
    down stream of the
    throttle butterfly.
    The airflow through the enrichener passage sucks up gasoline like a
    kid sucking milk through a straw.
    ., May 3, 2008
  10. Mike W.
    Mike W. Guest
    AHHH!!!!! Once again I sabotage my understanding of something by not
    challenging my own assumptions. I see where this goes now... what I thought
    was merely a vacuum passage to the vacuum tap on top of the downstream part
    of the carb actually carries the enrichening stream too. THANKS. It looks,
    with only one coffee in me so far, as though this circuit actually picks
    it's airflow off the underside of the diaphragm rather than the inlet bell,
    but perhaps that connection will reveal too with another cup or two:)
    Thanks... I really appreciate your help getting out of my fog.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
  11. Mike W.
    . Guest
    It's possible. The location of the enrichener air inlet and the pilot
    air jet vary according to the carb model, and I have seen the inlets
    in either the inlet bell or under the diaphragm.
    ., May 3, 2008
