MetzelerTourances ?
Discussion in 'UK Motorcycles' started by Nick, Dec 29, 2004.
  1. Nick
    Nick Guest
    What does the group think of these for a general all rounder for a V-Strom
    1000, tourer type riding style ?
    or alternatives ?
    Thanks,
    Nick
    Nick, Dec 29, 2004
  2. I'm very chuffed with the Tourances, which grip well in wet or dry, and last
    a long time. They're reckoned to be as good as any for big trailies, but
    there are others which are also rated ok (and maybe cheaper). ISTR people
    speaking well of Avon Distanzia and, er, I think Bridgestone Trailwings
    also, but I haven't tried them myself.
    Avoid Michelin T66's (assuming they still make them) like the plague, unless
    you never ride in the wet. Nasty!
    Rick (R1150GS/F650GS)
    Richard Sterry, Dec 29, 2004
  3. Nick
    entwisi Guest
    I have Anakees on my Varadero, very good in both dry and wet[1], Can't
    speak of mileage as they have only done 5K. Still loads left though. For
    my next tyres though I will be going BT 020 as they have brought out
    sizes suitable for Big Trailees. They are very smooth with more even drop
    into corners and seemed to grip very well[2]. I don't go off road at all
    so I'd be happy to go totally road biased but YMMMV.
    [1] Two up with SWMBO chasing sports bikes round Scotland getting both
    pegs down on numerous occasions.
    [2] Had a do on Wiks GS Adventure shod with them, Very impressed with
    the tyres.
    entwisi, Dec 30, 2004
  4. Nick
    entwisi says...
    Being diplomatic about your views of the bike itself, I see.
    Lozzo, Dec 30, 2004
  5. Nick
    Alan Guest
    They were OE on my Tiger and after 6000 miles the rear is down to about
    3mm tread depth. I'm limited in tyre choice because of spoked wheels on
    the Tiger but they have been fine to me - front can get a bit squirmy
    under heavy braking but I reckon that's more a feature of the bike than
    the tyres, 19inch wheel and long, soft suspension. The Tiger can be
    ridden quite enthusiastically and they have coped well enough that I
    will just go with new ones when the time comes.
    Alan, Dec 30, 2004
  6. Nick
    entwisi Guest
    Without wanting to upset anyone (after all he's bigger than me), I wasn't
    that impressed. I had wanted a do on a GS when I was buying the Varadero
    but SWMBO said it was 'Bloody Ugly, You're not having one of those' so
    when the opportunity arose I was looking forward to it. However it just
    didn't float my boat, the engine didn't have the grunt or noise of mine,
    the handling whilst good felt 'remote', I did like the lack of dive under
    braking from the front. I'm grateful to Wik for a go as I now no longer
    look at them wondering if I'd prefer it to the Varadero. I suppose its
    swings and roundabouts, I just prefer the Varadero. I'm planning on
    tweaking the front suspension with different springs/oil so it should
    bring it pretty much to what I want. I can't think of anything else I
    would want to do to it.
  7. Nick
    Alan Guest
    So, SWMBO reckons the GS is so ugly but not the Varadero? ALL of these
    big trailies (including the Tiger) are pretty challenged in the looks
    department I reckon. Having said that, the Tiger seems to turn more
    heads than the ZX9 does - maybe they're just astonished at the bigness
    and ugliness of it!
    Alan, Dec 30, 2004
  8. Nick
    Preston Kemp Guest
    The only limitation is the size - the spokes don't limit anything as
    it's got tubeless rims.
    Preston Kemp, Dec 30, 2004
  9. Nick
    Alan Guest
    Not so. The Tiger spoked wheels will NOT take tubeless tyres, nothing to
    do with size - they are just not air tight, which is why the latest
    model has non-spoked wheels so the tyre choice is increased.
    Alan, Dec 30, 2004
  10. Nick
    Alan Guest
    Bad form etc... Do you have an owners handbook for your Tiger? Page 64
    in mine says "This motorcycle is fitted with spoked wheels which
    require a tyre suitable for use with an inner tube"
    Are you using tubeless tyres on yours?
    Alan, Dec 30, 2004
  11. Nick
    Preston Kemp Guest
    You're confusing 'tubeless tyres' with 'tyres with tubes in' - big
    difference. The Tourance is a tubeless tyre, which has to be fitted
    with a tube when mounted on a spoked wheel (unless it's a BMW or
    Aprilia spoked wheel). Alternatively you can seal the rim with various
    types of gloop & run your tubeless tyres sans tube.
  12. Nick
    Preston Kemp Guest
    Which covers all Tiger-size tyres, & probably all tyres period, unless
    any manufacturers make them with spikes sticking out the inside!
    I did seal the rims when I rebuilt the wheels last year, but I kept the
    tubes fitted in case the spokes needed a tweak after bedding in, which
    may have broken the seal. I'll probably ditch the tubes at the next
    tyre change.
  13. Nick
    entwisi Guest
    Personally I don't see what all the issue is with the Varadero. OK its not
    a Sprots bike, we don't all want pocket rockets. The varadero has a large
    fairing with excellent protection and superb twin headlights. If the only
    thing that the journos can keep spouting is that it is ugly then it must
    be doing something right dynamically and after all thats what we buy these
    things for isn't it and I actually like its 'different' look.
    I could always pull the old 'You don't notice the mantlepiece whilst
    stoking the fire' one now couldn't I :eek:)
  14. Nick
    Alan Guest
    I had always believed it to be a bad idea to use a tube in a tyre meant
    to run tubeless(dunno why really - something about making the tyre run
    too hot, but I could be talking bollocks). My point was that Triumph say
    that because it has spokes you should use a tube, so yes, the spokes do
    limit your choice of manufacturer recommended tyres.
    What would be the benefit? Sure, you can fit other makes of tyre but if
    you had an insurance claim and the assessor spotted a tyre not on the
    manufacturers recommended list where would you stand? Personally I'll
    stick to Tourances with tubes - the Tiger doesn't need expensive sticky
    rubber and it would be a waste of money buying it (IMHO). Having said
    that Tourances aren't exactly cheap, the rear 150x17 is only about £15
    cheaper than the 190x17 BT01 on my ZX9, but they do last a bit longer :)
    Alan, Dec 30, 2004
  15. Nick
    Alan Guest
    Agreed. The looks do grow on you too. I'm more likely to use the Tiger
    for everyday routine and it's a great tourer - the ZX9 has become very
    much a Sunday toy. This last year, I only did 2k miles on it as against
    nearly 5k on the Tiger. The Tiger is an excellent bike, good fun and I'm
    less likely to lose my licence on it!
    Alan, Dec 30, 2004
  16. Nick
    Preston Kemp Guest
    I think we'll have to agree to disagree. But as a parting shot, the rim
    on Tigers is designed for tubeless tyres, not tubed - the area where
    the bead sits is different between the two. The Tourance is a tubeless
    tyre, & it doesn't say on the Michelin website that it's suitable for
    use with a tube - ditto the Anakee, & the T66 before it, & probably the
    various flavours of trailwing too but I can't be arsed to look. Anyway
    it's neither here nor there really as Tourances rock so why look
    elsewhere.
    IMHO it wouldn't make a blind bit of difference to which tyres you can
    fit, for the reasons I've already stated. The 19" front rim limits you
    to big trailie tyres and BT020s, with a few more options if you don't
    mind reverting to crossply.
    Most people's reason for going tubeless, and one of mine, is the
    thought of trying to break the bead at the side of the road if you get
    a puncture in the middle of nowhere. It's obviously a lot easier to
    plug a tubeless tyre than change/patch a tube, & you don't have to
    carry spare tubes, levers etc. OK it may not be a problem in the UK if
    you've got breakdown cover, but if you're on a by-way 10 miles from the
    nearest road it's still a hell of a push! Or if you're touring on the
    continent & don't want to lose a day faffing around.
    The other reason, which only applies to those of us mad enough to
    venture off-road on such behemoths, is compression punctures. Putting
    it simply, you don't get compression punctures if you haven't got tubes.
  17. Nick
    Alan Guest
    I'm not disagreeing as I freely admit I don't know a lot about the
    subject. I find it most odd that if, as you say, the wheels are designed
    for tubeless but Triumph say fit tubes. Also Triumph have now ditched
    spoked wheels on the Tiger and the reason given was to increase the
    choice of tyres, according to my local dealer anyway.
    That makes very good sense, but I'd be tempted to ride the bloody thing
    on the rims for ten miles rather than push it!
    I'm not mad enough to off-road mine, is it fun or terrifying?
    Alan, Dec 30, 2004
  18. Nick
    Preston Kemp Guest
    If you pick your trails carefully, it's a complete hoot. Fast gravel
    tracks like the ones criss-crossing Salisbury Plain are perfect Tiger
    country. I suppose some people might find it terrifying to do 90+
    standing on the pegs with the back wheel sliding from side to side, but
    if you've got the confidence to do it it's stupidly good fun!
    I took a bunch of people from the Yahoo group in my sig out on the
    Plain this year. Most of them had never ridden off-road on anything,
    never mind a gurt great beastie, and they all absolutely loved it -
    even the ones who fell off. The pic on the group homepage is from that
    trip.
    I'll be doing another one this summer if you want to come along.
    Details will go on the Yahoo group as & when if you want to subscribe
    to it. We do loads of other Tiger runs throughout the year too.
  19. Nick
    I use tubeless tyres (BT45s) with tubes on my Guzzi's conventionally
    spoked wheels. I always have done; even with the cast alloy wheels.
    I've not had any problems and none of the tyre fitters have said anything
    in the past.
    sweller, Dec 30, 2004
  20. Nick
    That's good, because I've got a part worn BT45 for my Bandit that I had
    to use a temp plug for. The bike shop I took it to wouldn't plug it[1],
    because I'd used a get you home plug. This means I can use a tube
    instead. :)
    [1]I dunno if they're talking BS.
    Muck, Dec 30, 2004
Similar Threads
Loading...
