Hi kaybear.... I have a 79 honda cb750 L (same as a K but 10yr anniversary), and I acquired this from my neighbor in late summer... he had the carbs off, the exhaust, tank seat...there were some problems with it which i have fixed.... ie front calipers and master cylinder, speedo cable, no spark to coils, but here is my problem.... The bike is hard to start... and when it does, it seem like it is misfiring. I have spark to all cylinders, the carbs i put on I bought from someone that said he took them off a running bike (same carbs as the ones i have with bike). I have checked the timing. I did this without a light.... I made sure the high point of the cam was even with the electronic breaker on and looked at the timing mark. I did this with both breakers and timing was right on mark. I have been told to rebuild the carbs and put them back on, but I believe it to be more of a sticky or stuck valve. One other thing is the oil light stays on all the time.... I have checked that oil is getting to the top of the engine, and it is.....what could that be?? a clogged screen or filter?? I put a new oil filter on when I did the oil, but I didn't replace the other filter or screen under the motor ( I think thats where its located). So, I guess my question is, how can I check to see if I have a stuck valve without having to tear the enigne apart very much?? Can I take the exhaust pipes off and check thru the exhaust ports to make sure they are operational? Each cylinder gets hot when it runs rough.... the number one cylinder is the hottest. Can I run a compression check without having the bike running? Or... should I rebuild the carbs first and then check the engine? Its expensive to rebuild the carbs, and I have to assume the carbs are ok since the guy told me they came off a running bike.... any advise you can give me would be much appreciated.... thanks in advance.. Fwed
