Mental note
Discussion in 'UK Motorcycles' started by TD, Mar 22, 2009.
  1. TD
    zymurgy Guest
    More than 1,725.00 apparently ...
    Paul.
    zymurgy, Mar 23, 2009
    #41
  2. TD
    Eddie Guest
    It doesn't take long to get from one end of the country to another on a
    9R, you know.
    It's like this:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260376499765
    (Two different people suggested a fix for the temperature gauge issue,
    so that may well be resolved this evening.)
    I certainly want more than it finished at that time around, but I may
    have to reconsider the figure I have in mind.
    Eddie, Mar 23, 2009
    #42
  3. TD
    Eddie Guest
    Shush, you'll scare away the punters.
    Eddie, Mar 23, 2009
    #43
  4. TD
    Dan L Guest
    I tend to look at anything over 20K as leggy, although bthat's prolly
    just me.
    Dan L
    Too much time to think, too little to do.
    http://thebikeshed.spaces.live.com/
    2002 Triumph Sprint RS 955i (It's big, and it's black)
    1996 Kawasaki ZR1100 Zephyr (Gone, but not forgotten)
    BOTAFOT #140 (KotL 2005/6/7/8)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 23, 2009
    #44
  5. TD
    zymurgy Guest
    <Ozzy mode>
    You're all fucking mad.
    </O>
    Maybe i'm in a minority of 3 [1] who own a (still functioning) 68K+
    mile bike.
    Paul.
    [1] Me, SD, YTC
    #45
  6. TD
    Dan L Guest
    As I said, it's prolly me.
    I expect I'd think differently if I had racked up the majority of the
    miles though.
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 23, 2009
    #46
  7. TD
    You're deliberately missing the point, so I won't bother any more.
    Champ, Mar 23, 2009
    #47
  8. TD
    Simes Guest
    <waves from seat of 86k mile Pan>
    Simes, Mar 23, 2009
    #48
  9. TD
    SD Guest
    The Wing's currently up on blocks. It only needs some brakes.
    | ___ Salad Dodger
    _/_____\_ GL1500SEV/CB1300SA-9/CBX1000Z
    |_\_____/_| ..99843../..00312.../..32117.
    SD, Mar 23, 2009
    #49
  10. TD
    Ahem.
    platypus, Mar 23, 2009
    #50
  11. TD
    zymurgy Guest
    Throwing in the towel so soon ? :)
    I understand the POV that a 30-plus K bike might be less than
    desirable, but you'd not blink an eye at the same mileage on a car
    engine.
    I know bike engines are highly (or higher) tuned, but that doesn't
    stop them and the bike covering 80K miles plus easily.
    So where's the prejudice crept in that a 30K bike suddenly becomes an
    old nail/unreliable ?
    As someone else has pointed out, every self respecting tourer will
    have this on it after 2/3 years.
    P.
    zymurgy, Mar 24, 2009
    #51
  12. TD
    You _are_ missing the point (although it sounds to me like you may be
    just being thick, rather than deliberately awkward). Which is simply
    that however little effect mileage has on the actual condition of a
    bike, it will always be seen in a negative light when there are ten
    low-milers for every high-miler out there.
    Ace, Mar 24, 2009
    #52
  13. TD
    zymurgy Guest
    What, me ? :)
    Oh sure, but then the price would reflect that on the high milers
    against the low milers shorely ..
    Paul.
    #53
  14. TD
    Yes, the desirability of a high-mileage bike is very much lower than a
    low-mileage one. If you agree with that what exactly is it you're
    arguing against?
    Ace, Mar 24, 2009
    #54
  15. TD
    zymurgy Guest
    Me, i'm not arguing at all, merely passing comment that the prejudice
    against 30K (or 20K miles) plus bikes is unwarranted and unfathomable,
    considering that given proper servicing, there's no longevity issues.
    P.
    #55
  16. TD
    Unfathomable? Now you're just contradicting yourself. You actually
    agree that a higher mileage bike is less attractive than a low-miler.
    Unfathomable means that it can't be understood, or that it flies in
    the face of logic, whereas even you clearly do understand the logic
    involved, and appear to accept it.
    YY,SW.
    Ace, Mar 24, 2009
    #56
  17. TD
    TD Guest
    I know what you mean about the wheel paint - mine was like that - pretty
    shoddy and annoying.
    I think the main reason it didn't go for a little more is the mileage, which
    as has been alluded to in another thread, would be nothing for a Pan, but for
    sprotsbikes it's just a bit high compared to others.
    TD
    1991 VFR400R NC30 (black and red)
    1993 Eunos Roadster (supercharged)
    Could want: something more comfy, sprots or not
    Missing: SOB, Unreliable Italian exotica, Lardy tourer
    TD, Mar 24, 2009
    #57
  18. TD
    Eddie Guest
    'Snot a sprotsbike, it's a sprotstourer. Barely run in, it is.
    Eddie, Mar 24, 2009
    #58
  19. TD
    zymurgy Guest
    But since the price of the high miler is adjusted accordingly, it's a
    level playing field. So, attractiveness is irrelevant.
    I said I could /understand/ why someone would choose not to look at a
    high mileage bike (due to some sort of innate prejudice), but couldn't
    fathom the logic (as the bike is no less reliable).
    Sure, agreed, but for myself, for a particular model, if I had the
    money i'd go for a low miler, but if money was tight, i'd have a high
    miler. I wouldn't choose a different model with lower miles.
    huh?
    P.
    #59
  20. TD
    Adrian Guest
    But, of course, they won't be the same price. The 30k bike is going to be
    a lot cheaper.
    You want to do 20k on the bike over the next couple of years. You know
    the bike'll do 50k easily. Which d'you buy?
    Adrian, Mar 24, 2009
    #60
