Melting Ice?
Discussion in 'UK Motorcycles' started by Hog, Jan 23, 2007.
  1. Hog
    Yep, first thing that entered my head when I saw the comment.
    I'm fairly sure that the level would remain static once the
    temperatures had settled.
    Apparently the thermal expansion of the sea could account for quite a
    significant proportion of any sea level rise. Presumably this takes
    into account the thermal expansion of the land as well.
    Pip Luscher, Jan 24, 2007
    #41
  2. Hog
    Beav Guest
    It fucking is and don't you forget it.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 24, 2007
    #42
  3. Hog
    Krusty, Jan 25, 2007
    #43
  4. If you look at the link I posted then yes - it does..
    Phil
    Phil Launchbury, Jan 25, 2007
    #44
  5. Hog
    But it would raise sea levels anyway, given that a portion of it is
    currently above sea level. The density thing is clearly also true -
    it's fairly basic physics - but I very much doubt if it would be in
    the least bit significant.
    _______
    Ace, Jan 25, 2007
    #45
  6. Hog
    Hog, Jan 25, 2007
    #46
  7. Hog
    Good point well made.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    #47
  8. Hog
    Jeremy Guest
    Doesn't a floating object (e.g. an iceberg) displace its mass in water? If
    so, it wouldn't raise sea levels when it melted, would it?
    Jeremy, Jan 25, 2007
    #48
  9. Hog
    Ah, missed your footnote.
    Pip Luscher, Jan 25, 2007
    #49
  10. Hog
    Not at all: it was specifically about a certain phenomenon, not global
    sea levels per se.
    And I was wrong.
    Bollocks.
    #50
  11. Hog
    I thought that, but thinking about it further, I suspect that the
    issue is that the ice is all stacked up in one place, whereas the
    fresh water will flow and spread across the entire ocean, in time.
    You could probably find a solution by comparing the total density of
    the ice+brine divided by the mean sea level (*including* the mean
    height of the ice) with the total density of freshwater and brine
    divided by the mean sea levels of the latter two mixed.
    Or something. ICBA.
    #51
  12. It always amuses me how the Merkin gummint does this Big Reassurance thing.
    And states the bleeding obvious, too. Some years back, I went to where the
    big sequoias grow. There's one you can drive through, so we did. Go figure.
    When you get to the other side, there is a BIG sign, saying "STOP! Did you
    notice that the tree you just drove through is hollow?" Well, no shit,
    Sherlock, I thought it was a remake of The Philadelphia Experiment.
    And then, there was the sign seen over a roller towel in a burd bog in LA.
    "WARNING! This is only for drying your hands. Do NOT place neck in this
    roller towel. Death by hanging may result." I swear to the gods of ukrm that
    this is True.
    Ali
    Alison Hopkins, Jan 25, 2007
    #52
  13. Hog
    That's a harsh penalty for misusing a towel.
    #53
  14. Well, you know what that US judicial system is like.
    Ali
    #54
  15. I'd have been more than impressed if they'd had one by the hand drying
    machine, warning you not to poke your fingers in it or "Death by
    electrocution may result".
    The Older Gentleman, Jan 25, 2007
    #55
  16. In the leaflet accompanying a circuit tester I bought this morning was a
    strict injunction to not touch bare current-carrying wires, as there was
    a "danger of injury or death by electrocution". No shit, I thought.
    That was understandable in a way, but one was also discouraged from
    inserting the batteries incorrectly for the same reason. FFS.
    Grimly Curmudgeon, Jan 26, 2007
    #56
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    Entirely reasonable.
    <inserts batteries wrong way round>
    <tests circuit>
    "Jolly good, no volts there!"
    <grabs wire>
    KZZZZZARRK-KZZZZZZZZZARK-KZZZZZZZZZZARK
    "Ow!"
    <dies>
    See? And *all* because the batteries were the wrong way round, you
    reckless fool!
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Jan 26, 2007
    #57
  18. Hog
    Owen Guest
    On Thu, 25 Jan 2007 21:34:49 -0000, "Alison Hopkins"
    snip
    One wonders (in merkinlkand) what warnings come on a boxed handgun...
    Anyone?
    Owen, Jan 26, 2007
    #58
  19. Hog
    DR Guest
    Don't be silly. Handguns carry the legend "This is your birthright.
    Enjoy it!"
    DR, Jan 26, 2007
    #59
  20. Hog
    frag Guest
    Ace banged the rocks together and said:
    But ice is less dense than water (hence a glass bottle of water when
    frozen sometimes cracks the glass bottle).
    So the increase in density will offset the rise in sea levels. (by a
    fraction of a percent)
    frag, Feb 1, 2007
    #60
