Measuring Radiator Flow
Discussion in 'Motorbike Technical Discussion' started by Manjo, Jan 21, 2008.
  1. Manjo
    Manjo Guest
    Is there a DIY method to measure the flow-rate of coolant through a
    motorcycle radiator? My bike is 12 years old and I'm wondering if
    there's been enough scale build-up in the radiator fins to reduce flow-
    rate and the water-cooling efficiency of the radiator. I've looked in
    the bike service manual and it gives no information on how to test for
    flow rate. TIA for any tips or suggestions.
    Manjo
    Manjo, Jan 21, 2008
  2. Manjo
    oldgeezer Guest
    What kind of unforeseen, mysterious problems does your
    bike surprises you with?
    Temp needle in red zone?
    You get hot knees?
    It steams all the way?
    It burbs when you switch it off?
    In other words, if there aren't any problems,
    why do you search for a cause?
    Just think for a second. Why would the manual
    not define a flow rate, let alone how many miles
    you may ride before you need to check it.
    Rob.
    oldgeezer, Jan 21, 2008
  3. Probably also be OK to do a radiator flush
    and throw in new coolant if in doubt. Might
    be way less trouble than trying to measure it.
    Never owned one of those newfangled water
    cooled bikes myself, so take it as pure speculation.
    Rob Kleinschmidt, Jan 22, 2008
  4. Manjo
    Manjo Guest
    Hi Rob,
    Thanks for your thoughts. Perhaps you could help if I give you more
    information.
    I ride a V-twin with 125k miles (117k miles are mine). In warm
    weather (above 80 degrees F) the bike will stall out at stops while
    the rpm's fall under 800 rpm.
    I've rejetted the carbs, sync'd the carbs, set and reset the idle
    speed, cleaned the air filters, confirmed the cam settings, changed
    the fuel filter, checked the fuel pump flow, etc. I'm pulling the
    engine this winter and checking the bore and heads. I have to
    disconnect the radiator again and can easily test it standalone. I'm
    looking to eliminate as many heat causing and heat dissipating
    possiblilities as I can while I have the engine out and apart. Low or
    slow coolant flow could cause an overheating problem. What are the
    other possibilites to check?
    Thanks, Manjo
    Manjo, Jan 22, 2008
  5. I'd check the compression, ignition timing, and make
    sure the head gaskets were not leaking.
    I normally set my idle above 1000 RPM. 800 sounds
    low and I'd expect mine to stall at 800 too.
    Can you check the oil and water temps ?
    Are you certain it's overheating ? Onboard
    temperature guages are something I really
    appreciate.
  6. Manjo
    Ken Abrams Guest
    If you are gonna pull the engine, pull the radiator too and have it boiled
    out.
    That should set your mind at ease.....about the radiator anyway.
    Ken Abrams, Jan 23, 2008
  7. Manjo
    oldgeezer Guest
    Rob Kleinschmidt wrote that he never owned a water cooled bike
    thus 'speculates' it would be good to flush the radiator.
    Well, this is sound advise, no matter what state the radiator
    is in.
    Myself, besides a couple of air cooled, I only have owned 3 water
    cooled bikes. The first was 18 years old, second bike was 20, and
    my current one is almost 25 years.
    None of them ever showed any scaling of the radiator.
    You now describe your problem as: at warm weather, bike
    drops below 800 revs, then stalls.
    Idle at 800 revs is pretty low. Is that what your manual says?
    The bikes I have had all were around 1100-1300 revs.
    The on-board 'revcounter' (if any) usually is crude
    and should not be used to adjust idle.
    I think the radiator has nothing to do with your problem.
    If the bike has a temp-gauge, it should read between
    the red lines, also in warm weather. If it does not,
    then the thermostat could be defective, and there should be
    a description on how to test it in your manual, or
    the fan, or thermo contact, or wiring, or even the water pump
    could be defective.
    To set your mind at ease, check the piping for scaling. Easy
    to check visually. I bet you won't find it.
    Your idea is: "Engine stalls because engine gets too warm"
    But, if warm weather really is the cause, then every air cooled
    engine would have the same problem.
    Personally, I'd search in the fuel/carburettor area for the cause
    of your problem.
    And, since you're unmount the radiator anyway, take
    Rob Kleinschmidt's advise. Flush the thing. If it does not
    help, it will not harm anyway.
    Rob.
    oldgeezer, Jan 23, 2008
  8. Manjo
    Manjo Guest
    Rob and Rob,
    Thanks for the ideas and logic.
    I will have the radiator flushed boiled out.
    I mislead on 800 rpm. I have the idle set at 1,000 rpm and as the
    outside temperature approaches 80 degrees F, the bike's idle speed
    decreases and the bike runs rough at stops and as the heat increases,
    the engine will stall. I have never had a problem re-starting the
    bike. When this happens in stop and go traffic, I'm especially
    careful to down shift so that at just before a full stop, I have run
    the bike in 1st gear for several yards. This tends to reduce the
    stalling some. This has led me to also consider the fuel system as
    the possible source of the stalling problem (vapor lock??).
    I ran a leak down test on the bike myself and had less than 2% overall
    compression loss. This was after I had the cylinders honed and
    installed new rings and checked/lapped-in the valves.
    NOTE: Last spring I installed and broke in new rings/honed cylinders
    "easy" by riding under 50 mph over 500 miles. I'm thinking now I
    should have broken them in hard varying the speed between 40-60 mph
    over 500 miles to better seat the new rings. I say this because I see
    a lot of carbon build-up on the cylinder heads that I remove once in a
    while with Sea Foam end. The carbon has also been a concern in that
    it may be causing pre-ignition at idle enough to cause stalling? END
    NOTE.
    When I get the heads and cylinders off, I'm borrowing a bore gauge to
    check the cylinders for out-of-round that may be allowing oil to seep
    around the rings at high speed and burn-off on the piston crowns
    leaving the carbon build-up. I'm also going to ask the machine shop
    guys to check the heads/ valves just in case oil is leaking around the
    valve guides (I installed new valve seals last spring).
    I feel I'm intimately familiar with engine by having taken it apart
    and refurbishing/replacing many parts, but I lack the real shop
    experience of having fixing many different bikes with the same
    problem. I also have no fear of pulling the bike/engine apart and
    trying proposed solutions.
    Thanks, Manjo
    Manjo, Jan 23, 2008
  9. That symptom has me really baffled. Normally my idle will
    increase as the engine gets hot. I suppose vapor lock might
    be worth checking for. I'd also wonder if you might be running
    way too rich at idle, causing it to bog down. When it gets to
    this state, you might shut it down and check the plug color.
    Rob Kleinschmidt, Jan 23, 2008
  10. Manjo
    Ken Abrams Guest
    WHAT, AGAIN........?????
    You do have a one track mind, don't you?
    Here's my take: You are running RICH, causing the carbon buildup (how
    paranoid does one have to be to actually MONITOR the carbon buildup in the
    chamber ;-) ...).
    As the engine heats up, it "likes" to be a little leaner. If you are way
    rich, it will do exactly as you describe. Engines do not like to be rich
    when hot.
    I think you need to check your mixture......with an exhaust gas
    analyzer....and then fix the carbs. or intake restriction or whatever it is
    causing the rich mixture.
    I cannot in my wildest imagination see how taking the heads off yet again
    will help anything.
  11. Manjo
    . Guest
    Indications are that your idle mixture is incorrect.
    Check your carbs to be sure that the throttle butterflies are covering
    the idle mixture ports when the idle screw is initially set.
    This will require a 'bench synch' with the carbs off the bike. When
    you look at the butterflies from the engine side they should be
    covering the transition holes.
    Also, check your float height. The float height measurement should be
    within plus or minus 1mm of specification. A smaller measurement means
    that the fuel level is too high and the engine runs "soggy" at idle.
    Float level measurements are taken from the bottom of the float (which
    is on top when the carb is upside down on the bench) to the aluminum
    gasket surface, not the gasket (or o-ring, in case of a Kawasaki).
    Furthermore, check the brass needle jet (the tube that the main jet
    screws into) to see it the needle has banged against it and made it
    egg-shaped.
    This can happen in as little as 5000 miles on semi-downdraft carbs
    mounted on motorcycles that vibrate a lot.
    Lastly, when the engine is warmed up, put your finger over each
    enrichener inlet hole in the carburetor mouth to see if that makes the
    RPM
    change. The enrichener hole is the larger of two holes in the inlet
    mouth.
    If the enrichener plunger is leaking air, the engine will act like
    it's on the choke all the time.
    ., Jan 24, 2008
  12. Manjo
    ottguit Guest
    I hate to be too simplistic, but I hope you're in Neutral when you're
    at a complete stop, if not, maybe the Clutch is dragging a bit to make
    it stall?
    Bg
    ottguit, Jan 24, 2008
  13. Manjo
    Manjo Guest
    I will check this shortly, although the symptoms only appears at
    temperatures over 80 degrees F. I've taken the clutch apart several
    times and I'm careful for undue wear and to torque everything to
    spec. But I will go over it more carefully to be sure. Thanks.
    Manjo
    Manjo, Feb 9, 2008
  14. Manjo
    Manjo Guest
    Jack: I am loosing oil at the rate of about a quart every 800 miles.
    The compression test bumps up fine. A leak down showed less than 2%
    loss compression loss. It may be a valve guide problem that I intend
    to check shortly.
    Jack: No smoking, but when I'm leading my wife says she does smell
    oil burning from time to time.
    JACK: Extensive changes to both. I've taken out the EPS duct work
    and surge tank and have K&N filters mounted directly on each carb
    intake port. The exhaust system is a Jardine set that's nearly
    straight pipes. I've rejetted with larger main and idle jets to
    enrichen the air-fuel mixture to match the higher air volume.
    Manjo
    Manjo, Feb 9, 2008
  15. Manjo
    Manjo Guest
    KEN: (sigh)
    KEN: I'll take a shot at that. Manjo
    Manjo, Feb 9, 2008
  16. Manjo
    Ken Abrams Guest
    OK, so how many times are you going to take the clutch apart before you
    realize that it is NOT the problem???
    In addition to the already mentioned potential fuel system problems, you
    could also have a vacuum leak that is showing up when "parts" expand as they
    get hot. Pay particular attention to the boots between the carb(s) and the
    engine intake.
    Ken Abrams, Feb 9, 2008
  17. Manjo
    Ken Abrams Guest
    Grrrrr......It never occurred to you to mention ALL THAT when you first
    posted the symptoms of your problem?? Crap.
  18. Manjo
    Manjo Guest
    Thanks. I'll be sure to check the boots, again.
    Manjo
    Manjo, Feb 10, 2008
  19. Manjo
    Manjo Guest
    Sorry about the crap. This thread started out as a radiator flow
    measurement question and evolved into a list of very helpful
    suggestions and identification of other possibly contributing
    elements. I've tried to provide as many details as possible at any
    one time without distracting the reader.
    I have everyone's suggestions gathered into one document that I will
    use as a guide as I work through the bike.
    Thanks.
    Manjo
    Manjo, Feb 10, 2008
  20. And just for laughs, check the compression in each
    cylinder. You can spend lots of time fiddling with carbs
    and ignition when the real problem is one cylinder
    pumping way better than the other.
    If one cylinder's pumping poorly and you try to compensate
    for it with tuning, you can confuse yourself pretty thoroughly
    and induce some very odd behavior.
    Rob Kleinschmidt, Feb 11, 2008
