Me and batteries fall out again
Discussion in 'UK Motorcycles' started by Topper.Doggle, Jan 25, 2010.
  1. So I've been putting the NC30's battery on the Optimate every few
    weeks. This morning, green light, put it in the bike and tried to
    start it. Turned over, didn't catch, probably due to old fuel although
    it had been treated with stabilizer. Only lasted a couple of minutes
    or so of this intermittent abuse before the battery gave up. FFS,
    isn't that a bit pants? Is it worth getting a new battery or is a
    green light on an Optimate an indicator that the battery is tip-top?
    Will bad things happen if I try to jump-start it from a cage? I don't
    fancy the charge, fail, charge, fail for the foreseeable future.
  2. Topper.Doggle
    TD Guest
    Battery is only a couple of years old. Bike was in a relatively cold place -
    on the street and it's not warm out. I can't speak for all NC30s but mine has
    always been fussy after months of disuse, it always seems to get there in the
    end though. I thought the fuel stabilizer would help this time, but
    apparently not.
    Then I'm going back later with some jump leads.
    TD, Jan 25, 2010
  3. Topper.Doggle
    Pete Fisher Guest
    Had the carbs been drained before leaving the bike?
    There is no substitute for spinning a motor over very smartly. My hill
    climb tuned Nordwest would often require the jump lead treatment for the
    first start of the season.
    Even so, if you don't get at least a few encouraging coughs after a
    short time it's always worth going through the usual checks for signs of
    life.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 25, 2010
  4. Topper.Doggle
    TD Guest
    No, FFS. I perhaps foolishly assumed that the fuel stabilizer would stop
    things gumming up, hence left the fuel tap on. At this particular juncture,
    on this particular machine, I would almost rather leave it to rot in the
    street, as opposed to drain the carbs (I assume they have to come off to drain
    them).
    It was coughing, it was so nearly there, it wasn't quite, how you say...
    catching.
    I'll charge the battery again, and go back with some jump leads and fresher
    fuel in a can. If that fails, I'll push it into a canal and claim theft off
    the insurance[1].
    [1] Note to watching law enforcement - the previous sentence was not true.
    TD
    2000 GSX1300RX (red and black)
    1991 VFR400R NC30 (black and red)
    1993 Eunos Roadster (supercharged)
    Missing: SOB, Unreliable Italian exotica
    TD, Jan 25, 2010
  5. Topper.Doggle
    Geo Guest
    I had similar problems with my bike; I ended up charging the battery, trying
    to start, running out, recharging etc for 4-5 times before I decided to just
    use jump cables and a car; worked a treat - twice.
    Not sure if it applies in your case, but unlike my "stupid" charger which
    gets the battery to ca. 13.3 Volts, the "intelligent" one from Lidl only
    charges up to 12.7 so the battery runs low more quickly[1]. I now charge
    with the intelligent first and then plug the other one in for a final boost.
    My intelligent charger has a desulfation mode which kicks in when the
    battery is between 7.5 and 10 Volts. My battery is half-shagged due to age
    so I deliberately discharged it to that level and it seems to be working a
    bit better now, after it got fully recharged. Of course YMMV.
    [1] Volts doesn't equal AmpereHours but there seems to be a difference in
    the stamina.
    Geo, Jan 25, 2010
  6. Topper.Doggle
    Geo Guest
    This may be of help (love the name):
    http://www.startyabastard.com/
    Geo, Jan 25, 2010
  7. Topper.Doggle
    TD Guest
    Can you not go five minutes without going on about the Good Old Days when
    Batteries were Batteries etc yadda...
    "Get an Optimate," they said.
    "Optimates aren't the nuts," they said.
    Nah, it says not to remove the cap and I'm a bit of a poof.
    TD
    TD, Jan 25, 2010
  8. Topper.Doggle
    TD Guest
    That's a bit interesting. I just checked the voltages. It's currently on the
    "charge maintenance" stage, which is the stage after the initial charge. The
    manual says that this stage holds it at 13.6V for 30 minutes. However on the
    meter, it was around 13.1. The meter is an Ebay cheapy, and the charger is a
    Heinz Gherkin Optimate 4. I'm not sure what to believe.
    TD
    TD, Jan 25, 2010
  9. Topper.Doggle
    crn Guest
    The battery is fucked.
    Jumpstarting should not be a problem but how are you going to restart
    it to get home.
    Stop farting about and buy a new battery, preferably Varta or Yuasa
    and dont let it get ruined by going flat again.
    crn, Jan 25, 2010
  10. Topper.Doggle
    If I was going to bother with draining carbs, I'd just turn off the fuel and
    let the thing run till it died.
    platypus, Jan 25, 2010
  11. Topper.Doggle
    Pete Fisher Guest
    True, but on some bikes it is a bigger faff to open up an orifice to
    give it a whiff of the hard stuff than to do a quick drain and refill.
    I've never had that great success with it anyway. The hardest beast to
    coax in to life I've ever had was the high compression, big bore, trick
    carbed Nordwest. When it was in a sulky mood even a touch of the vapours
    wouldn't provoke it when stone cold.
    A good rogering with jump leads from a battery with lots of cold
    starting amps would do it, or, if not in a rush, careful checking of the
    ignition sensor clearance and/or a softer plug.
  12. Topper.Doggle
    Simon Wilson Guest
    It's (EasyStart) saved me on a number of occasions. The most memorable
    one recently was driving back from France with a very sick diesel
    Scenic[1].
    I used it yesterday too. Bandit was a bit reluctant to start after
    having been stood for a few weeks.
    [1] The injection pump was on the way out, low pressure.
    Simon Wilson, Jan 25, 2010
  13. Topper.Doggle
    Pete Fisher Guest
    The only thing it used to produce on the reluctant Nordie was FOAD KSB
    effect when the mixture accumulated in the exhaust system ignited.
    Certainly worth a try before having to engage in serious spanner work in
    brass monkey weather though.
    I'm a great proponent of trick plugs for persuading recalcitrant engines
    to fire reliably. NGK EVs would keep a Morini starting OK for a while
    longer once the ignition charging coil resistance began to drop.
    Having emasculated the alarm on the MX5 I was confident that the Westco
    battery would crank it over OK the other week despite having stood
    outside for a month, but I was pleasantly surprised by just how quickly
    it fired up. I reckon the small premium for the modern equivalent of EVs
    that I put in it was worth it.
  14. I've done it many times on many bikes. I've been told you shouldn't do
    it with the car engine running because the charge rate of a car at low
    revs can be more than a bike's syetem can handle, but I'm not sure I
    believe that.
    Just don't do it from a truck's 24v system, eh, Hog?
    The Older Gentleman, Jan 25, 2010
  15. I do that with the 400 Four.
  16. Topper.Doggle
    TD Guest
    I did, and eventually coaxed it into life. Took a good ten minutes of
    intermittent starter-prodding. Let it splutter for a bit, then we were firing
    on all cylinders. It would appear that every time I don't ride for a couple
    of months, I forget how great it is.
    Tomorrow's six-million dollar question: Will today's exploits be repeated if I
    try to start it any time in the next few days? Past experience would indicate
    that it will be fine, but always with that little "squeaky bum time" feeling
    that only an aging V4 can give. I blame Lozzo.
    But mainly I'm fucked off that the fuse holder is broken on the wires I added
    so the bike can be charged without having to remove the fricking seat.
    TD, Jan 25, 2010
  17. Topper.Doggle
    Simon Wilson Guest
    I thought that was a slight case of mixing up the red and the black?
  18. No, that was a later episode.
    A few years ago, Hog accepted a jump start on his old R100RS from a
    friendly trucker, not realising that the truck was 24v.
    The starter motor on the Beemer spun amazingly quickly :)
    Almost as amazing, IIRC, the only casualty was the quartz clock.
    Thinking about it, I don't ever want to accept a jump-start from Hog.
