Mate asked about a Sprint ST....
Discussion in 'UK Motorcycles' started by The Older Gentleman, Feb 21, 2009.
  1. Very nice, old 1999 model, in red with full three-piece Triumph luggage
    and only 27k on the clock. Seller, in Yorkshire, wanted £2k for it,
    which I thought was a tad strong, but....
    I asked him to check if it had had the recall for the fuel connectors,
    and also if it had had the major 24k mile service done, because that is
    the expensive one.
    "How expensive?"
    "At least £600, and could be as much as £800."
    So he asked the buyer, who confirmed that it hadn't been serviced for
    two years-plus, and that the last place that serviced it was a Benelli
    dealer. Right, so it won't have had the 24k valves and FI checks, then.
    But buyer would take £1800 - but definitely no less.
    I advised him to call Carl Rosner and ask for a price simply on the
    valves and the FI service, and nothing else (except, obviously the
    necessary fuel and air filters). Brakes and fluids and stuff he can cope
    with himself. That'll be £420, then.
    So he left it. Watch out for the major service intervals when buying
    used bikes, kiddies, because a lot of people flog the bikes just before
    they're due and they can come as a serious wallet-masher.
  2. The Older Gentleman
    SteveH Guest
    That was always the reason why you could pick up Fiat 20v Coupes for
    reasonable money a few years back - they were almost all due a cambelt
    service, which was the thick end of a grand from a Fiat dealer at the
    time.
    SteveH, Feb 21, 2009
  3. The Older Gentleman
    ginge Guest
    Same applies to most of the Fiat / GM TDI's at 40K.
    ginge, Feb 21, 2009
  4. The Older Gentleman
    SteveH Guest
    Rubbish.
    They're not due a belt at that age, so the only thing that could be
    expensive on them is glow plugs. Which are pretty much a given on a
    diesel. (Even belts are cheap to do on those - specialists will do it
    for around £200.
    Other than that, I can't see why that service would be expensive. It
    certainly isn't at an Alfa dealer - are GM dealers making up some
    extra requirement to bump up costs?
    (Just checked - Alfa Workshop want £220 for a 48k service on a JTD, or
    £155 for a 36k service, even a cambelt service at 72k is under 500
    quid)
  5. The Older Gentleman
    ginge Guest
    Due or not, lots have failed.
    See above, a lot of people are now recommending new belt + water pump
    around 40K, as a preventative measure.
    ginge, Feb 21, 2009
  6. The Older Gentleman
    SteveH Guest
    1 link!?
    I tend to trust the advice of Jamie at Alfa Workshop [1] - if he changes
    his intervals, you can be sure that's when you need to do it.
    If he reckons they're good for the mileage, then I'd trust that it's the
    case, at least for the engines built by Fiat Powertrain. Can't comment
    on those built by GM, which do appear to have a poor reputation.
    [1] Not used him myself, but he has a good reputation, and Catman speaks
    highly of him.
  7. The Older Gentleman
    ginge Guest
    No there are plenty over the following pages, lots of vauxhalls have
    suffered from it too.
    I'd lumped all of them together as it's the same engine, so a flaw in
    the design.
    ginge, Feb 21, 2009
  8. The Older Gentleman
    SteveH Guest
    I had a look, most of them only come up because of the search terms and
    are nothing to do with the 1.9JTD - many of them are links to 2.2TiD
    issues.
    Or shite parts being fitted by GM to the engines built in their plants,
    given that the ones bolted together by Fiat Powertrain don't have such
    issues.
  9. The Older Gentleman
    ginge Guest
    I think most of it is down to shite water pumps to be fair.
    ginge, Feb 21, 2009
  10. The Older Gentleman
    SteveH Guest
    Probably different suppliers.
    What's the odds that it's a Bosch pump causing the issues.....
  11. The Older Gentleman
    ginge Guest
    ginge, Feb 21, 2009
