Man seeks forgiving bike
Discussion in 'UK Motorcycles' started by David Thomas, May 20, 2004.
  1. David Thomas
    David Thomas Guest
    Hi All
    I'm after recommendations for my next bike but with a few complications
    I presently have a Bandit 600N (96) and have been using this since passing
    my DAS in Sept 03, trouble is I am finding it a bit of a handful, by this I
    mean heavy to move around and hard work at low speed and not quite upright
    enough (by about an inch) also a little tall, by about the same amount.
    For those that don't know me I am a bit disabled or as some on here put it
    "a bit of a spaz". (got an iffy back, had loads of operations but still well
    iffy)
    So my questions are:
    What bike is lighter, slightly more upright, slightly lower and easier to
    ride? (maybe a parallel or V twin)
    Would a 250 (CB250) be worth considering or would that be hard work because
    it is too small.
    Also would prefer to avoid a full on cruiser, not my thing, some Virago's
    looks ok... ish though!
    Any help would be great, don't want to stop riding so I need to start
    thinking about something a little more manageable.
    Cheers all, David
  2. David Thomas
    flashgorman Guest
    CB400 (modern 4 cylinder one, not a twin, not a CBR400) or hornet 250.
    flashgorman, May 20, 2004
  3. David Thomas
    HooDooWitch Guest
    Wot he says. I had one as a loan bike for a day while mine was being
    serviced. It was Jap grey import, nekkid thing and it was a hoot, once
    you'd got the engine over 6k.
    The brakes were shit though, but this thing had done a billion miles.
    HooDooWitch, May 20, 2004
  4. David Thomas
    dwb Guest
    What about an SV650?
    Similar power to the Bandit, but weighs less - not sure about it having a
    more upright riding position though.
    dwb, May 20, 2004
  5. David Thomas
    Bandits *are* heavy.
    I'm not sure how you'll reconcile "more upright" and "slightly lower".
    If you weren't /that/ concerned about the latter, I'd maybe recommend
    a supermoto, because you're sat *straight* up on one - they're also
    very light compared to a bandit (i.e. GSF600S : 206kg -v- CCM 404 DS :
    126 kg) and even if you're too short to put both feet down (like me)
    it's not a problem, as the lightness means you can just flick it from
    side to side - also a piece of piss to move around - I could actually
    lift the front of my CCM R30 off the ground and swivvle the bike round
    on it's back wheel.
    I know nothing about these.
    ugh - you don't want to be spaz *and* hom.
    darsy, May 20, 2004
  6. David Thomas
    Rexx Guest
    Heh, certainly not the cbr, 400 sprotbikes are a bit too hunched over. :)
    By far the most upright bikes that I've ridden have been trailies, but
    depending on your leg length, getting one with a lowish seat is quite
    difficult. Didn't find the DT125 too bad though - the seat height looks
    *very* high, but once I was on it, I could touch the floor with both feet
    (I'm about 5'9").
    Rexx, May 20, 2004
  7. David Thomas
    HooDooWitch Guest
    I would have thought that the seat height was slightly higher than the
    Bindit. One of Dave's requirements.
    ICBW though. It's been a while since I've sat on one.
  8. David Thomas
    HooDooWitch Guest
    .... err about the 400 - no idea about the 250.
  9. David Thomas
    David Thomas Guest
    What made me think of a 250 was seeing Bezza's CB250RS, which look real
    nice!
    D
  10. David Thomas
    flashgorman Guest
    The hornet 250 looks like the 600 but is smaller and lighter.
    http://www.honda.co.jp/ACCESS/motorcycles/HORNET250/image/model_photo.jpg
    They are grey imports but there are a lot around. Lots of people fit
    renthals which make them even more sit up and beg. They rev like buggery and
    are great fun to ride.
  11. David Thomas
    Mash Guest
    suzuki sv650
    very low seat
    upright riding
    quite light
    peice of piss to ride, it was my first bike and loved it...Im
    considering getting another, or maybe the 1000 version or whatever their
    super sports equiv is.
    Mash, May 20, 2004
  12. David Thomas
    Shane Guest
    CB500? I've never ridden one but it seems to fit the bill. It's certainly
    lower and lighter and I would imagine it's more upright too.
    Shane, May 20, 2004
  13. David Thomas
    Preston Kemp Guest
    Can't think of anything to suggest, but I also suffer from back problems
    after a few hours on the Tiger without a break, & that's a pretty
    upright position. I discovered by accident that a well stuffed rucksack
    strapped on the pillion seat makes a great backrest, & so far I've done
    trips of up to 16 hours like that without any back problems.
    I doubt my back's anywhere near as bad as yours by the sound of it, but
    it might be worth trying if you haven't already.
    Preston Kemp, May 20, 2004
  14. David Thomas
    dwb Guest
    I find the GSX-R crouch quite comfortable for my back - it's just the
    stopping/getting on/getting off/not moving around
    that causes the problems.
    Having had lots of postural stuff explained to me recently, it's actually
    easier to sit in an extremely bad (for my[1] back) way on an upright bike.
    Much harder in fact on something like the GSX-R - mainly to do with the way
    the (upper) spine curves.
    [1] I say mine specifically because everyone is different and I don't think
    taking a generalisation about backs is a good thing.
    dwb, May 20, 2004
  15. In uk.rec.motorcycles, David Thomas said:
    A set of Renthals will sort all that, and maybe some platform heels.
    A set of platforms it is then.
    Whinging Courier, May 20, 2004
  16. David Thomas
    David Thomas Guest
    Don't you have to get all the control cables and wiring extended to put
    higher bars on?
    I remember platforms the first time round... Bowie was in the charts with
    "Drive in Saturday" I was about 13, oh and I had a Puch Maxi to ride over
    the fields... aah great days and my back didn't bloody hurt. Can I go back
    please?
    D
  17. David Thomas
    usenet Guest
    Im pretty sure that's what my (diminutive) sister-in-law got and she's
    very happy with it. She's only about 4'4" or something and needed the
    seat lowering by about an inch but that was all.
    usenet, May 20, 2004
  18. In uk.rec.motorcycles, David Thomas said:
    Nope. Not unless you're thinking of going /really/ high, of course.
    You're older than me then. I just about remember the laughing gnome and
    I think I was about 4.
  19. David Thomas
    David Thomas Guest
    Great song the laughing gnome, still got it somewhere... oh yeah on mp3, "ha
    ha ha he he he" yep still make me smile :)
    A bit later came Aladin Sane and loads of geezers started wearing rather
    fetching make up... anyone spring to mind?
    D
  20. David Thomas
    Molly Guest
    Good choice.
    Molly, May 20, 2004
