Makeover: Better than expected.
Discussion in 'UK Motorcycles' started by Molly, Feb 17, 2007.
  1. Molly
    Molly Guest
    The swingarm and other bits on my GSX600 were really rusty so I decided to
    strip down the back end and do a makeover. I was quite prepared to do battle
    with seized bolts and pivots. I also had Loz's number handy just in case
    everything went as expected. To my great surprise everything came off
    easily, nothing seized and the swingarm pivot bolts just slid out. I've
    spent the day with a wire brush and Mr. Hammerite.
    http://www.sportsbike.org/gsx600f/pictures/swingarm1.jpg
    http://www.sportsbike.org/gsx600f/pictures/swingarm2.jpg
    http://www.sportsbike.org/gsx600f/pictures/shock2s.jpg
    Molly, Feb 17, 2007
  2. Great job! Be sure to post pics post reassembly.
    Porridgewog SV1k, Feb 17, 2007
  3. Molly
    Tosspot Guest
    That was a nice job. What paint did you use on the swingarm, was it
    hammerite as well?
    Tosspot, Feb 18, 2007
  4. Molly
    Molly Guest
    Yes, I've used Hamerite before and it seems to last forever and doesn't look
    too bad.
    These are a before and after pictures of the swingarm/linkage/shock. All the
    bearings were cleaned and re-packed with grease.
    Before:
    http://www.sportsbike.org/makeover/pics/shock1.jpg
    After:
    http://www.sportsbike.org/makeover/pics/shock3.jpg
    http://www.sportsbike.org/makeover/pics/shock2.jpg
    Molly, Feb 18, 2007
  5. steve auvache, Feb 18, 2007
  6. Molly
    Molly Guest
    Indeed they are sir.
    Would that be pink then?
    Molly, Feb 18, 2007
  7. Molly wrote
    Do they do it in pink as well?
    I have always said that if I had the money I would turn up at the local
    gathering of R1's[1] at High Beech on a pink bike and dressed head to
    toe in pink.
    [1] A happy hunting ground for the likes of BGN and wessie.
  8. Molly
    Tosspot Guest
    Hmmmm...<fx:looks at Trophy>...you're not looking for work are you?
    Bloody nice job, I for one am impressed.
  9. Molly
    Molly Guest
    I always had you down as a black coat white shirt man.
    http://tinyurl.com/2hw2pq
    Molly, Feb 18, 2007
  10. Molly
    Molly Guest
    I'm not that good at it and really struggle if anything is heavy or if the
    fasteners are really tight. If the swingarm was tight I would have left it
    as it is or call someone with muscles.
    Molly, Feb 18, 2007
  11. Molly
    Hamerite (hay-mer-ite [ursine: haymer-never-right]) occurs in many
    colours - frequently black, rarely silver and occasionally in a deep
    red flush; similar in many respects to Hematite. It is, of course,
    the ore from which such useful minerals as nimbyismus and occasionally
    deep-rooted fuckwitterite can be extracted, as can the piss on a
    frequent basis.
    Its origins are apparently variable and not enough is known to give a
    conclusive answer, but it is generally accepted to be of Mancuvician
    or pseudo-Celtiferic origin.
    Hamerite is part of a complex solid solution oxyhydoxide system having
    various degrees of extractable water, hydroxyl group, and vacancy
    substitutions that affect the mineral's magnetic and crystal chemical
    properties.
    Hamerite is, in fact, the source of much of today's vacancy, a
    property cherished by the current chav population. Hamerite is most
    unusual in the properties attributed to its magnetic polarity in that
    it appears to repel all but a very small number of other minerals.
    Two other end-members are referred to as protohamerite and
    hydrohamerite. Fortunately due to hamerite rarely successfully
    getting its end away, protohamerite is unknown outside the laboratory
    and is only theoretical at present. Hydrohamerite is very common and
    the water is very easy to extract.
    The best-known use of hamerite is in the heat-resistant and
    drag-mimimising (due to ithe self-lubricating properties of its
    ever-present wetness) coating applied to the nosecones of all
    devastatingly quick cross-country missiles. These missiles, once
    common around the byways, have in recent years sadly fallen into
    disuse due to driveway seizures while idling and are now generally
    consigned to sad and lonley existences in the backs of garages,
    supported only by their substantial chicken strips.
    Pip, Feb 19, 2007
  12. Molly
    Nice work, though.
    Tight nuts are what high-heeled boots were made for - get the end of a
    big breaker bar wedged in the instep - and jump on the bastard.
    Pip, Feb 19, 2007
  13. Molly
    I tried that approach on the Corvette brake caliper mounting bolts.
    When my shin eventually stopped bleeding, I resorted to using a scissor
    jack betwixt breaker bar & chassis. Far more civilised.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Feb 19, 2007
  14. Molly
    You need to hike the height of your heels, or perhaps get a bigger
    better breaker bar. Spilling blood on the job, especially when
    combined with a good bit of pain, often makes tight nuts seem less
    relevant, somehow.
    Pip, Feb 19, 2007
  15. Molly
    Not an option in that case due to lack of space. As it was I was laying
    on my back trying to kick blind. I /almost/ got it right, but my foot
    shot off sidewards launching my shin into one of the exhaust U-bolts.
    Much ouchness.
    I'm amazed that's the only 'vette related incident I've had so far,
    give the fact that most of the bolts are so rusty you can barely see
    any signs of a thread. I wasn't so lucky when trying to straighten out
    the crunched front of SWMBO's son's CRX on Saturday. The combination of
    ripped, jagged metal & broken glass meant my hands didn't stand a
    chance.
    Krusty
  16. Molly
    Pete Fisher Guest
    An anecdote concerning the more commonly occurring 'double-emmed'
    surface treatment.
    The Rotarini featured a home modified Morini frame which had to be
    strengthened round the swingarm pivot area, as the power of the 250
    Rotax was flexing things somewhat. An arc welder and a variety of bits
    of scrap steel plate produced an attempt at strengthening braces. Being
    more interested in function than appearance the results were roughly
    ground clean of pigeon shit with a grinding wheel mounted on a drill
    flexible shaft (no cheap angle grinders in those days). A liberal coat
    of classic silver Hammerite was then applied.
    On presenting it for examination at Brands prior to its next outing in a
    Formula 50 club 250 single race the scrutineer took one look at it and
    said, "Hammerite - the paint that hides a multitude of sins."
    | Pete Fisher at Home: |
    Pete Fisher, Feb 19, 2007
  17. Molly
    Molly Guest
    I love it when you talk dirty.
    The story so far.
    http://sportsbike.org/makeover/makeover.htm
    Molly, Feb 19, 2007
  18. Molly
    Molly Guest
    That's what I do but in trainers usually.
    Molly, Feb 19, 2007
  19. Molly
    Tosspot Guest
    You're one to talk! "Stripped, laid bare and covered with Hammerite".
    Worse than Marmite and a Labrador.
    Tosspot, Feb 19, 2007
  20. Molly
    Ah, the old scissor jack twist: sweet, nothing resists that sort of
    force - although I have had to resort to using a crowbar in the eye of
    the jack occasionally.
    You clumsy ****. Kicking is not a good idea, the potential (as you
    proved) for pain is too gret. Not to mention the chance of kicking
    the bar off the socket, the socket off the nut or rounding the nut
    off. I meant that you should keep a steady pressure on the bar with
    one foot, stand up on it and then BOUNCE on it.
    With a long enough bar and some wiggling, even behind the suspension
    as you were, I've usually managed to get enough of the bar available
    to exert some pressure. In extremis, jack the car up high, get the
    bar on the nut and wedge the end of the bar on the floor - then let
    the jack down gradually. The weight of the car squeezing a metre of
    bar forces most fasteners to cry enough.
    That's the place of rounded-off nuts and sheared-off bolts, that is.
    Dremel and wire wheel/brush is the way forward, as is buying shares in
    Plus-Gas and a blowtorch.
    You're a fucking menace. An old pair of welder's gauntlets are the
    answer here, or even SWMBO's gardening gloves if you can get your
    manly mitts in 'em. Cor, the yoof of today. You'll be as scarred and
    crippled as me when you get old.
    Pip, Feb 19, 2007
