Majesty saga
Discussion in 'Classic Motorbikes' started by crn, Sep 5, 2010.
  1. crn
    crn Guest
    As told, I picked up a 98 Majesty 250 superscoot last weekend for
    under 500 quid, bargain I thought.
    The fork seals were badly fucked so I ordered new seals online and
    started pulling it apart. Every damn piece of front end plastic has
    to come off, the umpteen fastners submitted eventually.
    OK, so open up the forks and change the seals - how hard can it be.
    Impossible is the answer because you need a special Yamaha tool to
    hold the inner plunger to undo the bottom bolt. So off the forks go
    to the local dealer, another 110 quid and 2 days later I get to
    start reassembly and blast the online seller for sending the wrong
    seals.
    Finally got it back together today, only 3 panel screws left over,
    no more pannel rattles, engine sounds good and it rides nicely, plenty
    of performance for scoot duties.
    In it goes for an MOT next week. What can possibly go wrong ?.
    crn, Sep 5, 2010
  2. Whaaat? £110 just to pull a pair of forks apart (and you supplied the
    forks ready for the pulling apart) and fit new seals? You've been ripped
    off.
    30 minutes to separate each leg, fit new seal, reassemble and add new
    fork oil. That's an hour, Add 50% for luck. That's an hour and a half's
    labour.
    The Older Gentleman, Sep 5, 2010
  3. crn
    crn Guest
    Yamaha main dealer rate. 1 1/2 hours at £60.00 plus parts and oil.
    If you think that is bad try the Renault dealer who charges £75 ph to
    work on the Master.
    Main dealers all take the piss but the special tool is a main dealer
    workshop item. Grrrrrr.
    crn, Sep 5, 2010
  4. Oh well. At least I got the time factor right ;-)
  5. crn
    Salad Dodger Guest
    A sharpened broom handle is equally effective.
    Salad Dodger, Sep 6, 2010
  6. crn
    Pete Fisher Guest
    Indeed it can be.
    I assumed at first these forks might be UD ones requiring a slide hammer
    tool to insert the seals. I've not found anyway of codging up something
    to do that job, though I've wondered whether split plastic pipe and zip
    ties might just do the trick.
    Nordwests are becoming the subject of restoration these days, so not all
    'SOBs' have conventional forks.
    | Pete Fisher at Home: |
    Pete Fisher, Sep 6, 2010
  7. crn
    Jeremy Guest
    Why?
    Jeremy, Sep 13, 2010
  8. crn
    crn Guest
    There was a baggie containing 7 panel screws under the seat, so I found
    homes for 4 of them. I have not yet removed anything rear of the
    footboards so more sins will doubtless be discovered.
    it might even stop clattering when everything it nailed down.
    crn, Sep 13, 2010
  9. crn
    Steve Parry wrote:
    I take the forks out and hold them in the vice by the sliders and get
    someone else to compress the forks while I undo the bolts. Never had
    one beat me yet.
    Lozzo
    they churn out)
    Lozzo, Nov 6, 2010
