I could use a little help with some items on my '75 CB360. I have a Clymer's manual that recommends greasing the front bearings at 6K but it doesn't provide any insight as to the proper dissembly/assembly of the axle. I also have a few questions that the manual doesn't address well in regards to the oil changes. The manual specifies that you have to remove the side cover, which I assume means replacing the gasket, but it doesn't sound reasonable that you would have to replace a gasket every time you clean the centrifical "filter". Also, the manual doesn't address whether or not there are any other gaskets that are likely to need replacing as a result of cleaning the oil screen. Any other tips and tricks relating to maintaining this bike would be appreciated as well. tia
