Maintenance for beginners
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jun 6, 2004.
  1. Lesson 1: oil level windows
    For some reason a few bikes have ones that are a bit small and really
    difficult to see. It's trickier at oil change time because the new clean
    oil doesn't show up as well as the old dirty stuff.
    When peering at the little window, and tipping in the oil, and
    wpondering why the oil isn't showing in the window yet, keep your ears
    wagging, because that odd trickling noise is the sound of ten quids'
    worth of fully synthetic oil pouring out of the bottom of the engine,
    into the drain tray, because you forgot to put the drain plug back in.
    Stand by for Lesson Two: disc pads
  2. The Older Gentleman
    Klaatu Guest
    Look at it this way - you're engine has had a nice clean out.
    Klaatu, Jun 6, 2004
  3. The Older Gentleman
    Andy Hewitt Guest
    LOL, can't say I've ever seen that happen before........ yeah right!
    Andy Hewitt, Jun 6, 2004
  4. Lesson 1.1
    a: If you observe lots of oil dripping from the front engine sprocket.
    b: don't clean it all of with paraffin, hose it down, then think "that
    chain will go rusty if I don't oil it" because you will end up at a:.
    HTH.
    SimonB - South Wales. BOF#32
    email
    http://simonb.zapik.com
    Triumph Sprint ST, ZXR750L2 Wazimbaki. Kawasaki Z1R *Still For Sale*
    CON of the month http://zapik.com/simonb/fiddle.html
    eric the brave, Jun 6, 2004
  5. The Older Gentleman
    Buzby Guest
    This should be good . . . . . . .
    Buzby, Jun 6, 2004
  6. The Older Gentleman
    Cit Guest
    says...
    Oil change? bwahahahahahahaha wos one of them?
    Cit, Jun 6, 2004
  7. The Older Gentleman
    flashgorman Guest
    I hope you remembered to start the engine and rev it hard to get the last of
    the old oil out before refilling it.
    flashgorman, Jun 6, 2004
  8. Heh. Nearly, nearly.
  9. The Older Gentleman
    Sarah noticed this afternoon that the Trophy's discs were a bit rusty. She
    suggested, entirely seriously, WD-40...
    platypus, Jun 6, 2004
  10. The Older Gentleman
    flashgorman Guest
    That's just stupid. You want a proper oil like 3in1 rather than a water
    dispersant like Wd40.
  11. The Older Gentleman
    CampinGazz Guest
    Thought copper grease was the thing for brakes.. higher melting point of
    something.. you don't want the oil burning off the disc when you yank on the
    lever.
    CampinGazz, Jun 7, 2004
  12. The Older Gentleman
    flash@work Guest
    Good point. Personally I've just put a scott oilier on the front disk so its
    maintenance free now.
    flash@work, Jun 7, 2004
  13. The Older Gentleman
    Big Tony Guest
    <worried>
    I'm not totally convinced this reply was intended to be as humourous as it
    appears.
    </worried>
    Big Tony, Jun 7, 2004
  14. The Older Gentleman
    Owen Guest
    She really should get her licence... ;-)
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Jun 7, 2004
  15. The Older Gentleman
    Don't be. In the end, I used Vaseline.
    platypus, Jun 7, 2004
  16. The Older Gentleman
    <needle on Probability Counter goes past zero into Surreal>
  17. The Older Gentleman
    Owen Guest
    O
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Jun 8, 2004
