Magnetic fuel "conditioner"
Discussion in 'Motorbike Technical Discussion' started by Chris, Jan 20, 2009.
  1. Every time my son drives a car into a repair
    shop, a pretty good milking usually follows.
    Rob Kleinschmidt, Jan 22, 2009
    #41
  2. Chris
    . Guest
    The pentane rings in the gasoline in our tanks were broken in the
    refinery...
    It just seems to me that there might be some similiarity between
    magnetism and heat energy that a layman might understand before
    coffeee in the morning...
    ., Jan 22, 2009
    #42
  3. Chris
    S'mee Guest
    huh... I would have thought an orgone generator more appropriate.
    <shrugs> oh well, wrong again...<meat splat>
    S'mee, Jan 22, 2009
    #43
  4. Chris
    S'mee Guest
    I dunno, wouldn't Henry be a better conversationalist AND less likely
    to steal your money, ID etc.
    S'mee, Jan 22, 2009
    #44
  5. That's the "and stay alive..." clause. ;-)
    People used to think I had a hard-on when I was climbing over my
    5.1-Tesla solenoid to refill the liquid helium. It was actually just my
    Swiss Army Knife trying to escape down the magnet's bore.
    Dr Ivan D. Reid, Jan 22, 2009
    #45
  6. I understand it's all in hand. Different days see different GANTT
    charts, but it seems like September is a safe enough bet. Bit of a pity,
    as we almost certainly won't get enough Higgs-discovery data before _next_
    winter's shutdown. But with a bit of luck and a following wind, 2010 should
    be a good year for data taking.
    Like it, though the ecologists here would probably prefer it to be
    grey squirrels[1]. Geneva still has a fair population of red squirrels.
    luckily.
    [1] Major potato chip/crisp manufacturer here recently had a competition
    to suggest new flavours; IIRC the winners get 1% of the takings from their
    flavours. One of the six winners was "Cajun squirrel"!
    #46
  7. Ah, but have you ever pressed them into service as Boot Magnets,
    guaranteed to trigger inductive loops when the traffic lights just _won't_
    change for a mere motorcycle?
    #47
  8. Oh, come on! Are you really going to go up against at least
    eighteen years of rec.motorcycles wisdom?
    #48
  9. Chris
    Jack Hunt Guest
    Magnetism, at least the sort you can safely carry around with you, won't affect
    those loops. Strapping an equal size block of any other metal to your boot
    would do just as well. Putting the side stand down on the loop works well, if
    you can see the cuts in the road surface.
    One of my campground guests installs these loops in Canada and he explained the
    whole thing to me. I have it somewhere in an email. I can post it here if
    anybody is interested but this is one of those things that get hashed to death
    here frequently.
    Jack Hunt, Jan 22, 2009
    #49
  10. Chris
    Jack Hunt Guest
    Only when you're headed north and south at the same time.
    Jack Hunt, Jan 23, 2009
    #50
  11. Chris
    TOG@Toil Guest
    <VVBG>
    TOG@Toil, Jan 23, 2009
    #51
  12. Chris
    . Guest
    ., Jan 23, 2009
    #52
  13. Chris
    TOG@Toil Guest
    So what? Magnets on fuel lines are a waste of time. Fraud. Snake oil.
    Junk. Throwing money away. They do nothing. Acheve nothing. Improve
    nothing. They have *absolutely no effect* and deliver *absolutely no
    benefit*.
    Trying to argue that they do *something* is stupid.
    #53
  14. Chris
    . Guest
    So now you're trying to stay on the topic of magnetic fuel
    conditioners, instead of going off in all nitpicking directions?
    I'm trying to explore the effects of *magnetism in general*, to see
    what it would take to for a magnet to break up a hydrocarbon molecule.
    While there doesn't seem to be much data about the dangerous of
    constant exposure to *static* magnetic fields, the US Congress and WHO
    Recommended limit for constant human exposure is 2 mG (200
    nanotesla).
    One site recommended that people with pacemakers avoid being around
    intense magnetic fields.
    One site said that the recommended limit for humans exposed to
    *electrostatic* fields as 25kv/m^2.
    The old standby Wikipedia (which you despise so much), says:
    "The Earth's magnetic field measures about 0.5 gauss, a small iron
    magnet has a field of about 100 gauss, a small neodymium-iron-boron
    (NIB) magnet has a field of about 2,000 gauss, a big electromagnet has
    a field of about 15,000 gauss, and the surface of a neutron star has a
    field of about 1012 gauss."
    I'm reasonably certain that a neutron star could cause long-chain
    hydrocarbon fuel molecules to break up, but if a 6 tesla supermagnet
    in a physics lab doesn't kill a frog, what *would it take* to disrupt
    its molecules?
    ., Jan 23, 2009
    #54
  15. Chris
    TOG@Toil Guest
    <snip>
    You don't have the brainpower to assimilate it. Ivan does.
    #55
  16. Chris
    . Guest
    Then let *Ivan* do the talking, so you can figure out if you're
    impressed enough to
    give him a blowie afterwards.
    ., Jan 23, 2009
    #56
  17. Chris
    TOG@Toil Guest
    <Shakes head>
    How can generations of breeding produce something as stupid as you?
    #57
  18.
    Dr Ivan D. Reid, Jan 23, 2009
    #58
  19. You'd need O(5 eV) energy over O(0.2 nm) to break a hydrocarbon
    bond. Not sure how you propose to generate this with a magnetic field...
    #59
  20. Chris
    Jeff Guest
    (Hans-Christian Becker) wrote in
    It is not a legend. A friend told me that having metal in your body (pins
    in the spine in his case) is very painful when they turn up the magnetic
    field too high.
    Jeff, Jan 23, 2009
    #60
