lucas rita ignition.
Discussion in 'Classic Motorbikes' started by hubert, Jun 17, 2005.
  1. hubert
    hubert Guest
    Hi,
    i think the lucas rita ignition on my 1980 ducati 900ss died.
    does anybody knows where i can find the diagram for the rita ignition?
    online would be nice, but as long as i can get one i can try to repair the
    unit.
    Has anybody got any luck getting the amplifier repaired?
    cheers,
    Hubert
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, hubert
    A very swift Google showed up:
    http://www.ducatimeccanica.com/rita.html
    You lazy sod... ;^)
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Jun 17, 2005
  3. hubert
    AFAIR, Lucas used to do a check and replace.
    They have quite a few branches:
    http://www.lsuk.co.uk/
    sweller, Jun 18, 2005
  4. hubert
    hubert Guest
    ">>Hi,
    the website seems to be down,
    but i am looking for the electrical diagram of the printed circuit board.
    i've obviously already got the wiring diagram, as the unit is already on the
    bike.......
    the diagram for the pirhana and the original morini ignition is on the web
    http://www.italoclassicbikes.de/downl/fs_downl.htm
    i hoped to find the diagram for the lucas.
    cheers,
    Hubert
    hubert, Jun 18, 2005
  5. hubert
    Indeed it is, just when I needed it...
    Just as an aside - the Morini V-twin ignition is a completely different
    beast, but then again I assume you already knew that.
    Timo Geusch, Jun 18, 2005
  6. hubert
    hubert Guest
    i noticed they are different , i've got a couple of them in the shed.
    i used the morini just as a example of the type of docs i was looking for.
    I dont think we have lucas branches over here (netherlands), i will try TRW,
    the parent company, but i doubt they will be very helpfull
    cheers
    Hubert
  7. hubert
    Iggy Guest
    As far as I know they are not made anymore. Someone in the US is thinking of
    making some for Norton Commandos but no idea if the box would be the same,
    probably not. They are, however, extremely reliable & most faults are with
    the wiring. Particularly the wires from the little coil where the points
    would normally be. This is a very low voltage & doesn't need much of a bad
    connection not to work.
    As for repairing them, don't know anyone who does it. Maybe worth asking
    Norton Owners Club as they are the most popular ignition on Commandos. Doing
    it yourself might be difficult because I think the box is "potted".
    Iggy
    Iggy, Jun 18, 2005
  8. hubert
    Fair enough.
    Probably not...
    Maybe we could organise it such that provided the UK Lucas agents still
    service them, you'll send it to someone in the UK who'll drop it off at
    a local Lucas agent?
    Just a thought, like.
  9. hubert
    hubert Guest
    thanks for the info, i had good results repairing pirhana and morini
    ignitions, so hoped to do the same with the lucas.
    the wiring is ok, unfortunately it is the unit that died, probably because
    of a faulty battery.
    so far for the reliability.
    without the diagram i will have to find another ignition,
    cheers,
    Hubert
