Lubriplate products
Discussion in 'Motorbike Technical Discussion' started by R. Pierce Butler, Oct 13, 2005.
  1. Krusty,
    Have you tried any of the Lubriplate chain lubricants?
    LUBRIPLATE® Chain & Cable Fluid is a lubricating, penetrating and cleansing
    fluid designed for a multitude of applications. This product will not produce
    a dry surface; it will maintain a moist film. This unique film, however, will
    not pick up dust and dirt, but rather acts as a cleansing agent.
    http://www.lubriplate.com/Products/specialty.htm
    The reason why I ask is that 90 weight smells so bad.
    pierce
  2. Have you tried it?
    I've never seen that product, but a penetrating fluid doesn't sound
    like a good thing to get onto the O-rings themselves. If you can direct
    the application toward the edges of the rollers it might clean and
    lubricate the rollers, but the application to the side plates to
    prevent rust might cause enough accumulation of whatever solvent is
    used and that solvent could soak past the O-rings...
    krusty kritter, Oct 13, 2005
  3. It is too bad one can't grease a chain from the inside out. I find it a
    bit disturbing that the lubricant behind the rings cannot be replenished.
    It would be nice if one could grease it now and then.
    Keep it greased and the chain might last for a much longer time.
    As it stands the only thing one is really lubricating is the o-rings or
    the x-rings. Maybe the rollers a little bit or do I have that wrong?
    Lubriplate makes a "Super Chain Lube" with "micro-graphite". It is made
    for high temp applications like oven chains.
    Lubriplate has been around for years BTW.
    pierce
  4. Can you imagine a chain with about 110 tiny Zerk fittings?
    The sealed-in grease just lubricates the hardened steel pins that have
    extremely high loads per square inch of surface area. Cumulative wear
    of about 0.005 per pin results in a chain that's over half an inch
    longer than
    it was when new.
    Any lube that you can apply to the inside of the link plates right
    where there's a tiny gap between roller and plate will help lubricate
    the softer steel roller and whatever lube is on the outside of the
    roller with help cushion the impact of rollers against sprocket teeth.
    Years ago, Arco Graphite was very popular. Remember that stuff? An oil
    that started oil black instead of clear and golden. One guy told me
    that he swore by the stuff, that he wouldn't use anything else.
    I filled the crankcase of my Dodge van with Arco Graphite just once. I
    had mysterious battery charging problems. I replaced the battery every
    year. I replaced the alternator once. The batteries kept going dead.
    Just before I traded the van in, I looked at the plastic alternator
    connector. it was covered with electrically conductive graphite. That
    was what was shorting the alternator out.
    And lubrication experts make public the fact that graphite helped oil
    to lubricate, but if the oil ever got low, graphite became abrasive and
    actually caused the engine to wear out faster.
    Arco quit making oil with graphite in it...
  5. Can you imagine a chain with about 110 tiny Zerk fittings?
    longer than
    it was when new.
  6. Sure but the zerks would be internal kind of. There would just be a
    depression where one could apply a needle type grease gun. A tiny ball
    bearing and a spring is all that you need. The hole would have to be
    pretty darn small. With a setup like that it would be years before a new
    chain would be needed.
    I actually tried it and it caused my lifters to get noisy. I dumped it
    and it took forever for the lifters to get that crap out of there and
    quiet down.
    That would do it.
    Yes they did and that is a good thing.
    pierce
  7. R. Pierce Butler
    John Johnson Guest
    But how much longer do you want a chain to last? I've put 12k miles on
    the chain on my '94 VFR, and adjusted it three times: one adjustment was
    me re-doing it after getting it wrong.
    AFAIK, the chain on there is the original. If that's the case, this
    chain has 23k miles on it, is 11 years old, and shows very little wear.
    I'll admit (admit? note? whatever) that I've got a ScottOiler installed.
    I've heard from plenty of folks getting 20-30k miles on a chain on the
    VFR.
    Now then, if you've got a more powerful bike (any modern liter-class
    race-replica) or a large V-twin, your chains probably won't last so
    long, but that's life.
    And (AFAIK), so long as you keep the o-rings in good shape, the grease
    stays on the inside and does its job. My understanding is that it's not
    grease breakdown that causes most wear in chains, it's loss of grease as
    a result of tearing o-rings.
    So, if the grease is doing its job, the desire shouldn't be for grease
    fittings, but for better lubricants/protectants for o-rings. Which
    brings up the question: why don't manufacturers recommend silicone
    lubricants for these? If the purpose of the external lubricant is (as
    Krusty often says) to prevent surface rust and to keep o-rings supple,
    it seems to me that spray-on silicone lubricants would be perfect. The
    only disadvantage that I can see is that silicones creep like crazy and
    might cause problems if the lube collected in the grease inside the
    o-ring.
    Comments?
    Later,
    John
    John Johnson, Oct 13, 2005
