LRP and catalytic-converters
Discussion in 'Australian Motorcycles' started by Knobdoodle, Oct 19, 2004.
  1. Knobdoodle
    Why I aughtta'.........
    Clem
    Knobdoodle, Oct 20, 2004
  2. Does a '97 GS have a cat? My '94 didnt. The 1150 range are all fitted with
    cats, I wasnt aware that the 11 had them fitted as standard.
    Al
    (Two-cat TDM900)
    Alan Pennykid, Oct 20, 2004
  3. Well, you'd better make your mind up Clem baby, I've advertised it and I'll
    be selling to the first that comes along with the money. The White Power
    shocks went today, that only leaves the sidecar to go and i'm getting
    nibbles on it now.
    Al
  4. Oh, and the Staintune has no cat at all.
    Al
  5. Knobdoodle
    Smeegle Guest
    yep it does
    saw it at the house looked like my cat on the r1100s
    Smeegle, Oct 20, 2004
  6. Knobdoodle
    rockit Guest
    Interesting... I recently had a conversation with a guy on one of the
    650 beemers and noticed that it had 2 mufflers????
    He mumbled something (?) to my retort that I thought the bike was
    only a single... seems I might now have an explanation.
    Rockit
    rockit, Oct 20, 2004
  7. Knobdoodle
    Umm... [puzzled look] I just sort-of thought it would.......
    I dunno.
    Clem
    (When I've unpacked enough I'll see if the handbook says)
  8. Knobdoodle
    I have no idea what you mean but there's a few 4-valve singles with two
    mufflers. (One for each exhaust outlet)
    Clem
  9. Knobdoodle
    Nev.. Guest
    please explain...
    Nev..
    '03 ZX12R
    Nev.., Oct 20, 2004
  10. Knobdoodle
    Todger Guest
    It does
    It is directly underneat the bike where the header pipes go into it.It's
    that huge thing that looks like a large can whick then trails off to the
    muffler.
    Todger, Oct 20, 2004
  11. Dont know that's necessarily a cat, I never seen any info that said cats
    were standard on R1100GS/R/RS/RT, I can remember info that they were
    optional. It could just be a collector to add more volume to the exhuast
    system, the larger the volume of the exhaust, the quieter they can make the
    bike without reducing power.
    Al
  12. Knobdoodle
    John Littler Guest
    A catalytic converter is exactly that - it creates a chemical reaction
    (Hammo translate that into the correct terms if you're unhappy with the
    explanation, just don't start trying to have an argument about it OK ?)
    In this case it helps turn the emmissions of a petrol engine into
    slightly less noxious gases.
    Well if you kill it you're going to create marginally more pollution, it
    may also reduce the efficiency of your engine (ie less HP) if it gets
    all blocked up and it can't breathe properly
    Yes
    JL
    John Littler, Oct 20, 2004
  13. Knobdoodle
    Smee Guest
    Clem's is efi but I didn't look for an oxygen sensor.
    On my S the collector is the cat converter.
    I want to get rid of it and get a flow through pipe but the cheapest
    quote was $500 which I think is a rip off for a 70 cm Y shaped piece of
    pipe.
    How much noisier does it get if you replace the collector/cat?
    Smee, Oct 20, 2004
  14. Knobdoodle
    John Littler Guest
    'Zackly. You wouldn't unless you were desperate for Juice.
    JL
  15. Knobdoodle
    John Littler Guest
    Possibly, it may reduce the amount of gas you can flow and hence the HP.
    You can fix that with a Dremel :)
    Possibly. Unlikely I would intuit but I have no empirical data on it
    One tank is unlikely to bugger it, although a tankful of leaded probably
    would (I don't think there's been any proper studies done but I recall
    reading that it didn't take a lot of leaded to screw a cat conv. fwiw.
    JL
  16. Knobdoodle
    John Littler Guest
    Naah they'll cope with a fair bit of lead (surprisingly tolerant of it
    in my experience), the cat will get clogged long before the lamda sensor
    Naah, making the cat less efficient just means more unburnt volatiles
    into the atmosphere, the o2 sensor picks up the %age O2 it doesn't care
    what the rest is afaik
    JL
  17. Knobdoodle
    John Littler Guest
    Knobdoodle wrote
    LRP should be a minimum 95 ron same as the original leaded, I coulda
    sworn there was some legislation on the matter but i can't find it now
    in the 30 second attention span i have a the moment :)
    JL
  18. Knobdoodle
    John Littler Guest
    The Yamaha SZR660 has two exhaust pipes even though it's a single - one
    off each exhaust valve. Wouldn't be surprised if the BMW and the Peg
    (shares the same Rotax engine doesn't it ?) had the same.
    JL
  19. Knobdoodle
    Richard Fay Guest
    Clogged :)
    It doesn't physically clog it up. It just poisons the precious metals that
    coat the catalytic honeycomb.
    It will also poison the lambda sensor which will lead to bad part throttle
    running (closed loop) and poor fuel economy
    You will find that tin is NOT the lead substitute in LRP. MOre likely
    potasium or phosphous compounds.
    Richard
    Richard Fay, Oct 20, 2004
  20. Knobdoodle
    Richard Fay Guest
    LRP is 96RON... please get it right. Makes me wonder about the rest of
    your "story"
    Richard
