LRP and catalytic-converters
Discussion in 'Australian Motorcycles' started by Knobdoodle, Oct 19, 2004.
  1. Knobdoodle
    Folks,
    I hear that leaded petrol "poisons" catalytic converters.
    My questions are
    a) would anyone give-a-**** and
    b) is LRP safe in a catalyst-equipped motorcycle?
  2. Knobdoodle
    John Littler Guest
    No
    LRP has tin instead of lead
    JL
    John Littler, Oct 19, 2004
  3. Knobdoodle
    OK; but what does it "do"?
    (i.e. what's the problem with using it?)
    Thanks ..... Clem
    [or was that covered with answer #1?]
  4. My question is why would you want to use LRP anyway. Normal PULP is the
    same octane rating and pretty much the same price, it will reduce pinging
    the same as LRP might. Concerned about the valves in the BMW? I wouldnt
    be, they dont need LRP. besides many petrol stations are now doing away
    with LRP and supplying PULP etc in its place anyway, so its getting harder
    to get.
    Al
    Alan Pennykid, Oct 19, 2004
  5. I actually find LRP is more expensive than Pulp.
    James Mayfield
    "Insert witty comment here."
    James Mayfield, Oct 19, 2004
  6. Knobdoodle
    Conehead Guest
    Why would you want to use LRP? As far as I know it's no higher octane than
    PULP, it's scarcer and dearer, and your engine isn't designed for it.
    In any case, even if you don't care about your catalytic converter, the
    whales and orange-bellied parrots will thank you for keeping it in good
    working order.
    Conehead, Oct 19, 2004
  7. Knobdoodle
    manson Guest
    Anything that poisons cats is OK by me.
    regards,
    CrazyCam
    manson, Oct 19, 2004
  8. Knobdoodle
    It was a simple case of "No PULP". (Rare these days, I know)
    Clem
    Knobdoodle, Oct 20, 2004
  9. Knobdoodle
    Moike Guest
    but then they're not safe to eat.
    Moike
    Moike, Oct 20, 2004
  10. Knobdoodle
    Thomas Guest
    You can use regular unleaded in the beemer in cases of emergencies
    Just don't load it up or it will ping.
    Remember there is still some pulp inside the tank even when you fill it.
    As for LRP
    That stuff will wreck the catalytic converter.
    Thomas, Oct 20, 2004
  11. Knobdoodle
    Which brings me back to part(a) of my original question: "would anyone
    give-a-****"
    Am I likely to care or even know if my catalytic converter is wrecked?
    Anyone know if this is going to affect the bike's performance? (Curiosity
    only; one tankful isn't gonna' do much)
    Clem
  12. Knobdoodle
    Thomas Guest
    I think what may happen is that the lrp may affect the O2 sensor that
    resides in the cat.
    Because the stuff in the cat gets wrecked it may affect the true o2
    levels that it picks up hence performance problems.
    LRP also leaves a reddish deposit on the plugs and may lead to fouling.
    Best to remove the cat and get a flow through pipe.
    Will also sound shitloads better.
  13. Knobdoodle
    glitch1 Guest
    The bike/ engine will run fine, no probs there.
    But it'll bugger the cat, destroying the "filter elements" from what I
    understand, making the cat just a dead weight....which IS a justified
    explanation and sound reasoning to the better half to close her eyes in
    defeat and let you go ahead with the purchase of the Staintunes you wanted
    Shit, worked for me, even though the Strom never came with a cat, don't tell
    her though :))
    cheers
    pete
    glitch1, Oct 20, 2004
  14. Knobdoodle
    lemmiwinks Guest
    My (probably incorrect) understanding is that the lead in leaded fuel
    would coat the platinum inside the catalytic converter rendering it
    useless. Even though many would say they're next to useless anyway
    and supposedly take about 20kms to warm up sufficiently to do their
    job. I've no idea what LRP would do since there's no lead in it.
    Cheers,
    Ash
    lemmiwinks, Oct 20, 2004
  15. Knobdoodle
    Ha hah; CLASSIC!!
    Al Pennykid has a spare stainless system in his shed and even though I
    initially refused it my latest trip has made me think it'd be nice to have
    a full-sized left pannier and a smidge more "rort" from the pipe wouldn't
    go astray either. (I made the mistake of riding my brother's VTR1000 back
    from Pakenham Upper [my favourite suburb-name in the world] to Warburton
    and a bit of throaty big-twin pipe-rasp is pretty addictive!)
    Clem
  16. Knobdoodle
    Nev.. Guest
    The lead in the fuel might cause carbon deposits to be left in the cat
    converter which will disrupt the [free] flow of exhaust gasses through the
    exhaust, reducing performance and increasing exhaust and engine temperature.
    This may in turn cause the honeycomb material in the cat converter to melt,
    causing much greater interruption to the flow of exhaust gasses and eventually
    **** your engine. Using LRP once probably won't do much damage.
    Nev..
    '03 ZX12R
    Nev.., Oct 20, 2004
  17. Knobdoodle
    Smiley Guest
    A friend of mine is doing a doctorate at melb uni on LPG in cars. they also
    run the ford motor that they have there on petrol. one day somebody went to
    the servo to get some ULP but came back with some LRP. after one tank of the
    LRP the motor was so damaged by it they had to rebuild it. that was about 2
    years ago. they then did a test on all LRP that were available and found
    that only one did not damage the motor. cant remember which one. I am sure
    that they have improved LRP by now. IF YOU WANT TO USE IT THEN USE IT. I
    would not touch it with a barge pole myself.
    ULP is supposed to be about 92 octain
    PULP is supposed to be about 94-96 octane
    Optimax and others are supposed to be about 98 octane
    LRP is supposed to be about 92 octane. it is not the same octane as PULP and
    has not been since half lead came in years ago.
    Smiley.
    Smiley, Oct 20, 2004
  18. Knobdoodle
    Any idea what the damage was? I've heard the additive/deposits stories but
    the only actual "damage" I've ever heard of was the PULP/tolulene
    tax-evasion scandal a few years ago.
    96 (the same as PULP)
    That's according to www.shell.com.au and www.caltex.com.au
    Clem
  19. Knobdoodle
    Smiley Guest
    I will ask my friend when i can and get back to you.
  20. The tin *replaces* lead in the petrol.
    HTH.
    Postman Pat
    Pat Heslewood, Oct 20, 2004
