Loud clunky gearchange
Discussion in 'Motorbike Technical Discussion' started by Mungo \Two Sheds\ Toadfoot, Jun 10, 2007.
  1. Gentlemen.
    My Virago XV535's down-change is, I think, louder and 'notchier' than it
    should be when the engine's hot, even when I blip the throttle during the
    change. Is this normal for a Virago or is something wrong, or have I got the
    wrong oil in it perhaps? It's also extremely hard to find neutral when it's
    hot and it runs a *lot* faster at idle than when it's cold.
    Any thoughts? I would ask in my 'local' bike group, UKRM, but it's not as
    technical as your group.
  2. This normal, really. Engine oil should be 10/40. Gear oil in the rear
    bevel box should be 85w or thereabouts.
    Try adjusting the clutch cable.
    This is normal, too.
    Oh, and yes, you hooked him, first try.
    The Older Gentleman, Jun 10, 2007
  3. Curiously, there are a number of folk on ukrm, myself included, who
    rather rate the 535 Virago.
  4. Could well do, I've only ever had two other Yams: a YB100 way back when, and
    a RS125DX shortly after way back when.
    Heh. They didn't, on the whole, because contrary to popular belief they're a
    decent bunch of blokes/ladies/unsures. Mostly. Now I've got it running
    properly they'd have no right to anyway; for a Jap cruiser it shifts along
    quickly enough when I ask it to and it's real purty too. ;)
  5. These will be checked later but I think it's got 15/40 in the engine and
    SAE80 in the drive. It *has* got car oil in the engine though, which I
    understand could cause problems. Not a super-duper car oil with extras in,
    mind, just a standard mineral oil.
    Seems ok but I will anyway.
    This explains the easy-to-adjust-even-with-gloves-on knobbly screw between
    the carbs then, for easy adjustment on the road.
    Eye thang ewe :)
  6. Thanks for the comprehensive reply. I've stripped, cleaned, and set up the
    carbs myself so they are "factory" set, though I know this doesn't allow for
    wear of jets/needles etc., and balanced them, so they're as "right" as
    they're going to get.
    Lovely bunch of fellows, even those with red noses.
  7. If it's not fully synthetic, it should be OK, but I'd still lob 10/40 in
    it, in our chilly climate.
  8. Mungo \Two Sheds\ Toadfoot
    Badger Guest
    I've only ridden a couple of 535s. Both had 'clonky' gearshifts when
    compared to my GSXF, but then most bikes do when compared to a Suzuki
    oil/air engine. Both were clonkier than I remember any of my Yamahas being,
    but not as nasty as say an ER-5.
    First off, check the clutch freeplay and set it to exactly the amount Yamaha
    specify. Next, when the bike is hot, switch it off in first gear, pull the
    clutch in and check for excessive drag. It will drag a bit, but if you can
    get the bike onto a milk crate ( just get the rear wheel clear of the
    deck ), you should be able to turn the rear wheel with the bike in gear,
    with the clutch in, by hand.
    If you can't, the clutch isn't fully disengaging. If you can, then all is
    well. There are many possibles and some probable causes there.
    If the clutch isn't fully disengaging, it can make neutral finding a bit of
    a pig. Some bike are just a pig sometimes anyways. Call it character.
    As for the oil, semi-synth or mineral that meets JASO is all the engine
    needs.
    I quite liked the 535. Went OK, was fairly comfy, went round corners in a
    not unamusing way and had brakes that worked. A nice little bike really.
    Badger, Jun 10, 2007
  9. Exactly me feeling. Lovely soft torquey engine, too. And shaft drive,
    which is unusual in such a small bike.
  10. That's reassuring.
    Will do.
    I have to do some reversing when I park it up for the night and I did notice
    some difficulty going backwards in gear, clutch in obviously. I'll check the
    adjustment, as suggested by your good self and TOG.
    Ok. I didn't really think a small variation in the viscosity of the oil
    would make a great deal of difference in the noise of the gearchange but it
    was worth checking.
    For the first couple of months it was bogging down at fairly high revs. Now
    I've cured that the difference in performance is a revelation. I still can't
    imagine how quick a litre bike must be these days though; the Viagra's quick
    enough when it spins up so a new 'blade or gixxer must push your eyeballs
    back into your skull!
  11. Mungo \Two Sheds\ Toadfoot
    OH- Guest
    I've had a couple of bikes (Yamaha TT600R and Suzuki TS125X)
    that were very hard to find neutral on. A couple of quick oil changes
    seemed to help a bit, probably flushed out the clutch fibre soup
    left there by earlier owners.
    After a couple hundred thousand miles of using car oil in relatively low
    power Yamahas with excellent results I think I can say that there is
    nothing wrong there! OTOH, I mostly use full synth and never pure
    mineral.
    The silver lining on the agricultural sounding Yamaha gear change is
    that in my experience the gearboxes are reliable and never need
    maintenance. Just be firm!
    OH-, Jun 10, 2007
  12. My bike was made in 1988 and before I got it last year it spent the previous
    *ten* years in a dry garage. I did wonder what this might do to the innards
    but the engine was fine. I changed the oil, naturally, and have changed it
    since, but I think you could be right - it wouldn't hurt to change it again.
    I've seen oils developed especially for big bore singles, v-twins, and
    opposed twins, but I'm not convinced they're necessary. I stand to be
    corrected though because if it's beneficial to the engine I won't skimp on a
    drop of oil.
    Heh! But when I slow to a stop from 5th and haven't bothered changing down
    along the way it does sound like I'm panel beating in the last few yards
    *CLONK - CLONK - CLONK etc*
  13. You have? You mean, oils developed for each engine individually, or just
    for all three?
    I've *never* seen anything like that.
    The Older Gentleman, Jun 11, 2007
  14. Morris Lubricants do a 20W/50 which they say is a heavy duty multigrade for
    single big bores, v-twins, and opposed twin engines. Apparently it has a
    carefully formulated additive package. Well, it would have, wouldn't it? Who
    wants one carelessly formulated?
    Mungo \Two Sheds\ Toadfoot, Jun 11, 2007
  15. Mungo "Two Sheds" Toadfoot wrote:
    ....And they make oils specifically for steam engines and Sentinels, which
    makes them good chaps in my book.
  16. Well, I never. Mind you, Morris does make a lot of very unusual oils,
    single grades, stuff like that. I can't see how an oil can be
    specially formulated for a particular cylinder configuration, mind....
    chateau.murray, Jun 11, 2007
  17. I agree. A V-twin I can understand due to the rear cylinder getting hotter
    than the front; perhaps it might need an oil better suited to the
    temperature variations, but opposed twins...? Still, there it is, and Morris
    seem well thought of.
  18. It works like any other clutch mechanism that uses a similarly placed
    actuation lever.
