Looks like TOG was right...
Discussion in 'UK Motorcycles' started by William Grainger, May 7, 2004.
  1. William Grainger
    Christofire Guest
    I love that noise. I've only seen them on infrequent childhood visits
    to the south, so I saw an amazing thing when all the stations clacked
    past.
    Heh.
    Christofire, May 8, 2004
  2. William Grainger
    Christofire Guest
    Actually, this is an instance where I wouldn't mind Bruce waving his
    State of *nix flag. If it's got to work 24/7, to the point where the
    effort is justified, then why not do it properly?
    While I don't believe Windows is as bad as it used to be, I'd have
    nagging reservations about using it for something that should be up
    24/7. Not many home machines fit this bill, which is why I don't see
    the point of telling people to fix their computers with format c:,
    install <whatever>.
  3. William Grainger
    mups Guest
    It really depends on what the windows software is used for. If its just
    a front end for another system then having to reboot it say one a month
    would be fine in most situations.
    The ATM network doesn't use windows on the back end systems[1] so a
    crashed ATM is not that important in the banks scheme of things.
    [1] Or Unix IIRC
    mups, May 8, 2004
  4. William Grainger
    YTC#1 Guest
    But it is in the customer scheme of things.
    Depends on the back end system, I know of a lot of Sun instalations in
    banks and financial houses.
    YTC#1, May 8, 2004
  5. William Grainger
    YTC#1 Guest
    They "use" would be no different[1] from a customer perspective.
    [1] Except no BSOD
    YTC#1, May 8, 2004
  6. William Grainger
    Christofire Guest
    Well, that was sort of my point - the ATM in your example doesn't
    *need* to be on 24/7 therefore it's not that important to use a
    specific OS.
  7. William Grainger
    YTC#1 Guest
    I won't bore you with links and stats about uptime over the various OSes,
    you are capable of finding those yourself.
    I beleive part of it has always been the "immediate" cost, ie how cheap
    something can be put in *now* as opposed to the long term cost/savings
    doing it (IMO) properly. Remember when the machines used to shortchange
    you ?
    Sun never pushed Solaris x86 properly in these arenas in the past, but now
    hopefully hat will differ (the light dawned on the Execs 2 years ago) as
    we can now put a robust, stable OS on the same cheap and cheerfull
    platforms they are using. On top of that we have security built and and
    easily added. And when people see Solaris 10 (Dec 04) they will wonder
    how we have done it all so cheaply. (You can download it now in beta for
    free)
    <G> Works for me, the only time I powercycle is when I swtich on in the
    morning and off at night.
    Admittadly we have some way to go on some gadgets (USB scanners for
    instance, that will be sorted in Sol10 when we have libusb in the OS). A
    lot of people do not realise we have USB built in for Sol9 and a fair
    number of common devices work out of the box (pen drives for instance)
    (Gosh I even steered clear of the worm/virus issue)
    YTC#1, May 8, 2004
  8. William Grainger
    YTC#1 Guest
    How often have you gone to the nearest walkable ATM and it has been down?
    Banks forget about the customer.
    YTC#1, May 8, 2004
  9. William Grainger
    Christofire Guest
  10. William Grainger
    YTC#1 Guest
    You must live in a blessed land my son.
    YTC#1, May 8, 2004
  11. William Grainger
    YTC#1 Guest
    YTC#1, May 8, 2004
  12. William Grainger
    Salad Dodger Guest
    Me either. Then again, if I did, I'd walk 20 yards up the road to the
    next one.
    | ___ Salad Dodger
    |_\_____/_| ..64741../..15361.../..3157./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:14 Pts: 270 Miles:1248
    Salad Dodger, May 8, 2004
  13. William Grainger
    [Broken ATMs]
    Quite. There are at least 14 that I can use within 200 yards of my flat.
    CT, May 8, 2004
  14. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Andy Bonwick
    Over the past couple of years, the one nearest to me has been down about
    5% of the times I've been to it. Given that I'm not at it every day,
    indeed sometimes a few weeks pass between visits to it, the actual
    downtime on it must be higher.
    Impressed - not.
    GS 850 x2 / SE 6a
    Get rid of your SOC/SOB here http://www.sparesorrepair.co.uk/
    Grimly Curmudgeon, May 8, 2004
  15. It was somewhere around Barstow, on the edge of the desert, when the
    Humph. I tried d/l it and couldn't.
    GS 850 x2 / SE 6a
  16. In uk.rec.motorcycles, Steve Parry said:
    If you could see the state of my account, you'd know how true that is.
    Whinging Courier, May 8, 2004
  17. William Grainger
    deadmail Guest
    Why would you think that your sample of the 'downtime' would be
    inaccurate to the extent that the downtime would be *higher*. Surely
    it's just as likely to be lower?
    deadmail, May 8, 2004
  18. William Grainger
    The only time I've seen, recently, the cash machines not dispensing money
    has been when they've run out of it.
    sweller, May 8, 2004
  19. William Grainger
    deadmail Guest
    I've very rarely seen cash machines not dispensing money. On occasion
    I've assumed the fault is with the comms link but I can't ever remember
    seeing BSOD type issues.
  20. William Grainger
    mups Guest
    Like that worries the bank :)
    Yep, from what I've seen probably the majority of back end systems in
    banks are on Sun kit but the ATM system is NSK stuff IIRC.
    mups, May 8, 2004
