Long Way Round continuity shambles
Discussion in 'UK Motorcycles' started by Salad Dodger, Dec 24, 2004.
  1. Learn something new every day.
    Isn't that a bit dodgy?
    Mick Whittingham, Dec 31, 2004
  2. Ever tried steering a car when the power steering's failed?
    Same difference, innit.
    Patrick Evans, Dec 31, 2004
  3. Salad Dodger
    Eiron Guest
    Yes. It's a struggle on a big car at slow speed but not impossible.
    Once you get up to 30mph it is fine.
    What do Evo brakes need apart from a bit of vacuum for the servo?
    Or does it have an electric vacuum pump so the clarksons can brake
    with one foot while feeding the turbo with the other?
    Eiron, Dec 31, 2004
  4. Ever tried steering a car when the power steering's failed?
    [/QUOTE]
    Put like that I understand. My first though was it was a total loss of
    brakes without electricity.
  5. Salad Dodger
    Yes, I've raced one.
    Not really. Mick had inferred that no electricity = no brakes. In the
    event of the the electricity supply failing you'd have no brakes. Which
    is not really a failsafe scenario.
    You'd probably be left with brakes that required greater effort to achieve
    the same retardation.... ermmm, I'm agreeing with your power steering
    analogy.
    What actually happens when Evo brakes lose their feed?
    sweller, Dec 31, 2004
  6. Salad Dodger
    rb Guest
    Power *assisted* steering - you can still steer.
    Not if Platy really means *no* brakes.
    ICBW but I thought UK construction regs required brakes and steering to
    have a physical failsafe i.e. not entirely electronic. I have googled
    but can't find anything now. I'm sure I read it many years ago in an
    IEE article on some automated wagons that could never[1] be legal in
    the UK.
    [1] Under the then current legislation.
    rb, Dec 31, 2004
  7. Salad Dodger
    Sorry, I thought this was a discussion, not a pedantry contest.
    ogden, Jan 1, 2005
  8. It was somewhere around Barstow, on the edge of the desert, when the
    Yes. Not a thing I care to try too often, tyvm.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jan 1, 2005
