LIST of +63MPH /100KPH 125s please.
Discussion in 'UK Motorcycles' started by markzoom, Oct 6, 2004.
  1. markzoom
    Donegal Paul Guest
    One prize for Mr. Muck please :)
    Markzoom, what makes you think its an auto???
    Have you looked at the T5 at all??
    Donegal Paul
    Lambretta Li186 - crashed and bashed
    Vespa T5 Millenium - Wifey's (technically)
    www.thepilgrimssc.co.uk
    www.a4c.co.uk - What are YOU doing?
    www.ailishandcharlie.co.uk
    Donegal Paul, Oct 7, 2004
    #41
  2. markzoom
    A vey small prize, obviously.
    I refer you to my comments re: use of upper case and twatness.
    I'll further refer you to earlier comments about use of repeated
    punctuation - specifically queries in this case - and twatness.
    Pip, Oct 7, 2004
    #42
  3. markzoom
    Donegal Paul Guest
    "Pip" replied to "Donegal Paul"
    ????? <ducks> or in your case <geese>
    Donegal Paul
    #43
  4. markzoom
    markzoom Guest
    Ah ok. Does it have an automatic clutch though? If it does, I don't
    think they'd permit it for the "A" test. (If anyone ever decided to
    take a test on one.....).
    markzoom, Oct 7, 2004
    #44
  5. markzoom
    Donegal Paul Guest
    "markzoom" replied Muck
    No it doesnt, it has manual gears and manual clutch.
    As for if anyone deecided to use it for the test? Theres a huge amount of
    scooterist out there that specifically seek these little beauties out
    because,
    a) its still a scooter
    b) its the only manual geared scooter that the DVLA / DSA will accept for a
    test.
    #45
  6. markzoom
    Yay! Did you get the thing I sent in the post for you by the way?
    I rather think he's presumed that all scooters are twist and go, knowing
    nothing about what makes a proper scoot.
    Muck, Oct 7, 2004
    #46
  7. markzoom
    Pip wrote:
    Oh yuss, and that medal for using a 2 year old sheet of directions to
    get to Pixiefest too. ;)
    Indeed.
    Muck, Oct 7, 2004
    #47
  8. markzoom
    Donegal Paul Guest
    <fx: Looks out the patio door at broken and twisted Lambretta :-(>
    Donegal Paul
    #48
  9. markzoom
    markzoom Guest
    That most people could be bothered with the A1 test which excludes
    anything over
    125, particularly since there's no difference between A1 and A tests
    as far as I know, beyond needing a faster 125 for it.
    But I asked first.
    ??? Now what are you on about. You HAVE TO do a CBT before you do
    either A1 or A tests.
    Me thinks you are confusing CBT with A1.
    Don't bother.
    But do you know any 125s book capable of over 100kph?
    M.K.
    #49
  10. markzoom
    I sent something via Petrolcan for you, I figured that you would like
    it, when it gets to you that is. :)
    How are the injuries now btw.
    Muck, Oct 7, 2004
    #50
  11. markzoom
    markzoom Guest
    Exactly! I've already got the appropriate CBT.
    Right. No point in buying a sub-100kph 125 if you want to take the A
    test on it.
    Thanks, I will check. Would be nice for an awful lot of learners if
    there was a list of some A test suitable 125s on the net too
    though....
    M.K.
    #51
  12. markzoom
    Donegal Paul Guest
    Heh, knowing petrolcan itll be sat in his kitchen somewhere :)
    I really must get round to going and seeing the gobshite at some point, i
    wouldnt mind its only 40 miles or so!
    All casts are off, kneecap is still in two pieces but no one seems unduly
    worried about that for some reason and i passed my renewed CBT on Monday, so
    theyre healing well :) SOooooo nice to be back on 2 wheels, even if its
    only a vespa :)
    Donegal Paul
    #52
  13. markzoom
    markzoom Guest
    Question 1):"What on earth do you want A category for?"
    Statement 2): "Do A1 then DAS".
    Answer to 1): You are obviously also unaware that the A cat motorcycle
    licence you poo-poo is the one needed to ride a bike over 125cc and is
    the one you (presumably) have.
    Reply to 2) No. Why do a CBT, a max.125 course and test and a Direct
    access course and test?
    Q3): How about you post makes of +100kph 125s and quit making a fool
    of yourself?
    M.K.
    #53
  14. markzoom
    markzoom Guest
    What you (hopefully mistakenly) believe is that one should do the CBT
    (obviously), a sub-126 course and sub-126 A1 test+licence AND a direct
    access course, test +A licence (the very A licence which you say I
    shouldn't bother with, that is required for any above 125cc bike).
    Eeer ok, thanks but no thanks.
    I'd still appreciate some makes of +100kph 125s though, which, if you
    read my question, is what this thread asks for (Like this: "LIST of
    +63MPH /100KPH 125s please")
    M.K.
    #54
  15. markzoom
    Loz H Guest
    Donegal Paul <> spewed forth the
    following...
    Well, I never knew that.
    I seem to recall my PX125 (and even my Primavera) being capable of over
    63mph.[1] In fact, I distinctly remember my Primmy doing a healthy, if
    screaming, 65+ on the A55 heading towards Anglesea. On a flat piece of land,
    before anyone says. Granted, I was a lot thinner at the time (thanks,
    amphetamines). I was quite proud of it at the time, even though it was pink.
    [1] And before markzoom gets excited, 4 gears and manual clutch also..
    Loz H, Oct 7, 2004
    #55
  16. markzoom
    AndrewR Guest
    Look, I'm sympathetic to you on the whole wrangle about which test you
    should take, but it appears that nobody here has such a list or a link to
    one.
    If you think it would make a good web-site then why not do the homework and
    put it on the web somewhere? If you can't be arsed to do it then why do you
    expect somebody else to be?
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, COSOC#9, KotTFSTR#
    The speccy Geordie twat.
    AndrewR, Oct 7, 2004
    #56
  17. markzoom
    markzoom Guest
    Not in any great detail,I'm not interested in getting a rare vintage 125 scooter.
    M.K.
    #57
  18. markzoom
    markzoom Guest
    Super... The Vespa T5 goes back on the skimpy list of suitable 125s
    instead of room 101 then (when I get around to it).
    M.K.
    #58
  19. markzoom
    markzoom Guest
    I presume that most modern scooters are twist and go. I would however
    be overjoyed if you can point out any more (preferably modern) that
    are A test suitable 125s.
    M.K.
    #59
  20. markzoom
    petrolcan Guest
    the cont known as Donegal Paul says...
    On the stairs and I'm too frightened to open it.
    petrolcan, Oct 7, 2004
    #60
