liquid Vs Aircooled motorcycles
Discussion in 'Australian Motorcycles' started by DJ, Feb 15, 2008.
  1. DJ
    DJ Guest
    Hi Folks,
    Is there any real advantages or disadvantages between air and liquid engines
    in motorcycles?
    I'm in the process of choosing my next bike but won't have a big budget but
    will be looking for a big bike for touring and commutting with the emphasis
    on touring.
    I'm considering bikes with aircooling rather than liquid cooling engines.
    Is this a good idea? or not?
    Some of the bikes that I have in mind are getting a little old but from many
    reports I've read,are good tourers of pre 2000.
    Bikes such as the Yamaha Diversion 900 and the FJ1200 are 2 I've had in mind
    and are aircooled.
    Are aircooled bikes too prone to overheat on a hot summers day?
    Are there any other suggestions for a bike like those above that could be
    had for around the $5,000 mark?
    I have a friend that has a liquid cooled 1200 Kawasaki and his radiator has
    become useless and said he's had to park it under the carport for a good
    while as it'll cost him $1200+ to have it replaced. Bloody scary I reckon!!
    I'll be interested in opinions about this and hopefully will help me make a
    decision either way.
    Thanks in advance.
    Cheers
    DJ
    DJ, Feb 15, 2008
  2. DJ
    CrazyCam Guest
    Yes.
    Generally, the air-cooled engines don't produce the big horsepower
    numbers that the liquid cooled engines do.
    They also have less "bits" to go wrong.
    For commuting, you don't want the peak power business, nor do you want
    the electric fan cutting in in traffic, cooking your legs, as tends to
    happen with the liquid cooled bikes.
    They are indeed, and good machines, too.
    Not really. Not any more, and probably less than a liquid cooled bike.
    regards,
    CrazyCam
    CrazyCam, Feb 15, 2008
  3. DJ
    John Dwyer Guest
    I own a Suzuki GS 500. It commutes and tours adequately for my purposes. I
    have just taken it from Canberra to Narromine and back. It has been from
    Canberra to Sydney and return on several occasions. I have ridden it on
    very hot days, about 40 degrees C with no obvious problems.
    John Dwyer.
    John Dwyer, Feb 16, 2008
  4. For my 2 cents, I'd get whatever bike is comfy for you. If you aren't
    going fo massive horsepower then either will suit. Yes, as Cam says,
    there are less things to go wrong on a liquid cooled bike, but in my
    25 years of riding (except the last two years - waahhhhhh!!) I've had
    not a single thing go wrong with the cooling systems on any of my
    bikes, and all of them have been liquid cooled.
    I'd be choosing the bike more on what suits you and not worry about
    the air/liquid cooling issue. Especially in modern bikes. I guess if
    you were going to buy a 20 year old liquid cooled bike, there is more
    of a chance of something about to give up and die.
    Kevin Gleeson, Feb 16, 2008
  5. DJ
    DJ Guest
    Thanks guys for that info.
    I've never actually heard of any major incidents with aircooled bikes but
    with most of the bikes these days going with liquid cooling,I was wondering
    if it was actually a better system and as some of you said, with aircooling,
    theres less to go wrong.
    I once had a Kwaka ER500 and it was watercooled but wasn't exactly a high
    performance bike but had no cooling or other issues with it. It wasn't a bad
    little tourer either except for the constant light buzzing vibration through
    the handlebars that sent my throttle hand to sleep after a while. It used 13
    litres for 300kms of highway speeds averaging 100-120kph (cops & Cameras
    everywhere on the New England hwy) packed to the brim with luggage for a 9
    day holiday.
    It had close on 400km range incl. reserve on a 17 litre tank.
    Another question has come to mind, some of the older tourers as the ones
    mentioned and similar have high kms on them, sometimes well over the 100,000
    mark. If bought for a reasonable price considering km's travelled,would it
    be too expensive to have the engine and gearbox overhauled if the frame and
    paneling etc is in good nick? around what would it cost to have something
    like a 900-1200cc 4 cyl bike reconditioned?
    Thanks again for your advice and imput, greatly appreciated.
    Cheers
    DJ
    DJ, Feb 17, 2008
  6. DJ
    Theo Bekkers Guest
    Squariels, and all those Harley lookalikes that insist on placing an
    aircooled cylinder directly behind another, and then trying to get max HP
    out of it.
    Theo
    Theo Bekkers, Feb 17, 2008
  7. In aus.motorcycles on Sun, 17 Feb 2008 12:54:47 +1100
    Heaps....
    Depending of course on what reconditioned means. Might get away with
    new rings if it is blowing smoke but new top end is very expensive.
    May well need a clutch. Various bearings - wheel, steering head.
    What condition are the forks in? How's the gearbox?
    So much will depend on what is wrong with it.
    Zebee
    Zebee Johnstone, Feb 17, 2008
  8. DJ
    Nev.. Guest
    Lucky me, I have the best of both worlds, an air-cooled bike with an
    electric fan which cuts in and cooks my legs. :)
    Nev..
    '07 XB12X
    Nev.., Feb 17, 2008
  9. DJ
    Assuming some sort of non-liquid oil of course!
    Knobdoodle, Feb 17, 2008
  10. DJ
    Theo Bekkers Guest
    You'll find that most in-line 45º air-cooled twins have a lower compression
    ratio in the rear cylinder. Why do you think they would do that?
    Ariel fours didn't have overheating problems? It was the primary cause of
    their demise. The TX750 was better cooled.
    Theo
    Theo Bekkers, Feb 18, 2008
  11. DJ
    atec77 Guest
    Mine certainly doesn't , do you have a cite ?
    Mine didn't unless thrashed .
    Ok I guess it often did
    atec77, Feb 18, 2008
  12. DJ
    Theo Bekkers Guest
    Not on line, but I've read it several times in different publications on
    motorcycle and other engine design. Apparently it's quite common to have
    different compression ratios in cylinders. eg, my 230S Merc has the cast
    iron straight six. Compression ratio is 10:1. If you read the workshop
    manual you find that cyl # 1 is 9.5:1, #2 is 9.75:1, the rest are 10:1. This
    is because the front end of the engine is hotter in operation to the back
    end, so they compensate by not working the front end as hard.
    Cheers
    Theo
  13. DJ
    atec77 Guest
    In the downloadable manual for the 230s it fails to mention differing
    compression , my 450Sle all has the identical compression on 8 cylinders
    but then the 230 is sorta the corolla of the breed :p and certainly all
    my Jags run the same comprssion in the six cylinder motors.
    I really would like to see a cite/manual with mention as the internal
    difference required to result in these differences would I expect
    introduce a whole new and interesting set of harmonics and strains in
    the general running of the motor would it not ? . One would think the
    right engineering solution would be to effect proper cooling rather than
    altering compression ?.
  14. Huh?
    He'll have one of the ZZ-R1200, ZRX1200 or the ZX-12R. The former two
    have radiator mesh shields from the factory, and the bare alloy
    radiator on the 12R is a bigger version of the one that's now done
    85,000km on my ZX-6R and continues to keep the coolant temp at 69deg-C
    when the bike's moving despite the patch in the bottom middle where
    the cooling grilles have been hammered flat by bouncing rocks...
    You say his radiator has been "made useless". What does that mean,
    exactly? What happens to the bike when he takes it out?
    While the $1200 replacement cost is feasible for dumb-fucks who buy
    over the parts counter at a dealership, secondhand rads can be had
    from Ebay for a couple of hundred bucks, and most radiator places will
    have a fairly successful go at reconditioning a bike radiator for a
    similar price.
    2007 is about a quarter-century too late to distrust this newfangled
    liquid-cooling stuff on motorbikes. With a five-grand budget for a big-
    bore tourer, you're gypping yourself for choice if you give preference
    to air-cooled bikes. That said, the XJ900 Diversion would probably be
    one of the better choices if you can't tolerate even a modicum of a
    bent-over riding position, such as you'd get on a bike like a ZZ-
    R1100, VFR750 (go ahead, try and kill one of those liquid-cooled bikes
    without getting a 100-foot dropoff involved) or similar.
    intact.kneeslider, Feb 18, 2008
  15. DJ
    Theo Bekkers Guest
    Ahh, sorry. I'm talking about the 60s six cylinder models, not the current
    stuff.
    I have a 230S and a 220SE Manual and they both give lower figures for the
    first two cylinders. Let's face it, it's not something you're going to make
    up.
    Theo
  16. DJ
    atec77 Guest
    Yes I know what they are being an ex owner..
    where did I say that ?
    just seems an odd way to fix a simple problem.
  17. DJ
    atec77 Guest
    Luxury . my old 57 small window didn't and made a whole 40 HP before we
    re-powered it with a Chev .
  18. DJ
    Theo Bekkers Guest
    I meant, not something someone makes up and prints in the manual. It's not
    even something most people would think of. I remember the first time I read
    it saying "What the...."
    Theo
  19. DJ
    Theo Bekkers Guest
    I thought they still had the 1100 cc 36hp motor then. My first beetle was a
    60.
    Theo
  20. DJ
    atec77 Guest
    yup 36 but heads ported and a cam , then it broke the crank :(
