Linux etc.?
Discussion in 'UK Motorcycles' started by harry, Feb 27, 2004.
  1. harry
    Ben Blaney Guest
    Except the fact that you were already a UNIX sysadmin professionally.
    Others may not be.
    Ben Blaney, Mar 4, 2004
    #41
  2. harry
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Phil Launchbury
    OK, let's talk a brand new user through the process of changing a line
    in smb.conf.
    Nigel Eaton, Mar 4, 2004
    #42
  3. harry
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Vic
    Which is configured and set up how?
    I run three Linux boxes here. But then I've been working with assorted
    flavours of UNIX for the last fifteen years. Linux is OK, but it's not
    The Answer To Everything. Nothing ever is...
    It's a fucking joke, for Christ's sake.
    #43
  4. harry
    Cab Guest
    On Thu, 4 Mar 2004 10:50:26 +0000, Nigel Eaton
    <> bored us all completely to death with
    wittery prose along the lines of:
    There are a few distro's now that install this by default. Try
    connecting to http://localhost:10000 or https://localhost:10000
    If not, download and install from www.webmin.com. Follow the
    instructions. It is really easy.
    Cab, Mar 4, 2004
    #44
  5. harry
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Cab
    Well, yes. But you see that's kind of the point. For the *average* user
    that's not going to be a starter. Not everyone has the time and
    inclination to spend time finding this stuff out. They want (for better
    of worse) to switch the machine on and start using it.
    They *might* be persuaded to read the "Start Here!" flyer that comes
    with the machine. Maybe even stick a CD in the drive on a good day. But
    connect to http://localhost:10000 ? I don't think so.
    #45
  6. In 1991? No I wasn't - I was a IBM S/370 assembler programmer..
    I didn't start doing support of any kind till about 95!
    I didn't start doing unix support until the late 90's.
    By which point I already had 7 years of linux experience under my
    belt :)
    Phil Launchbury, Network & Infrastructure PHB
    Triumph Tiger 955i
    "I'm training the bats who live in my cubicle
    to juggle mushrooms"
    Remove sick person to email me
    Phil Launchbury, Mar 4, 2004
    #46
  7. Installed as standard by quite a few of the current
    distros. And doesn't really need much configuring.
    Indeed. A games machine require Windows XP[1]..
    Phil.
    [1] My home network is a mixture of linuxes, Windows XP and Win2k.
    With the odd OS/2 Virtual PC image sometimes running..
    Triumph Tiger 955i
    #47
  8. harry
    Catman Guest
    Be fair. For many users this doesn't happen in Windows either.
    Installed XP on a machine on Monday (upgrade from 98). Classic
    desktop, the works. All the user data is stored on the network.
    30 secs after I walk away, he's on the phone
    'Excell is not installed'
    By the time I'd got back upstairs he'd found his spreadsheets and
    started working on them. Depsite that he *still* claimed that he
    'couldn't find anything'
    The point I'm trying to make is this. *Many* users are just that.
    They *use* computers in a monkey-see, monkey-do manner. They have no
    idea what is actually happening. Change anything even basic (remove a
    shortcut from the desktop to a spreadsheet for example) and it's
    suddenly broken.
    Typicaly users are able to work out what they need to do differently
    simply because they've been using variants of windows for 6+ years.
    Having been using *nix for pretty much the same amount of time, it is
    just as easy, simply because I have the experience.
    That is exactly what I'm talking about. They want it to be the same
    as it was before. This does not mean that Windows 'just works' out of
    the box. A little experience with alternatives and you may just find
    that for many pointing a browser at the local host becomes just about
    as taking as navigating to a network share to find their files.......
    www.cuore-sportivo.co.uk
    Catman, Mar 4, 2004
    #48
  9. harry
    Ben Blaney Guest
    Ok, but you were a nerd. Do you stand by your comment "if I managed
    it then others can"? Do you see my point?
    #49
  10. harry
    'Hog Guest
    I suppose, being pedantic for a moment, he said others (some) and not all
    others
    'Hog, Mar 4, 2004
    #50
  11. IT'S A DEFAULT INSTALL!
    Unless you specify otherwise it will be installed. Certainly on
    Mandrake anyway..
    I think you actually underestimate the sort of people that would be
    doing this - if they have the gumption to try installing linux anyway
    then I'm fairly certain that they have the ability to look at a URL..
    Phil
    Triumph Tiger 955i
    #51
  12. Yes. And yes. Sure I'm a Mensa-capable genius who lives and breathes
    technology (can you see the sarcasm here?) but most other people have
    at least a basic ability to problem-solve..
    Phil
    Triumph Tiger 955i
    #52
  13. harry
    That's a rather circular argument - "the sort of people who want to
    install linux are the sort of people who can"
    Champ, Mar 4, 2004
    #53
  14. harry
    I want to install Linux and I can install Linux, but when I did it was
    such a hassle to get it to do what I wanted so I gave up.
    sweller, Mar 4, 2004
    #54
  15. harry
    Wik Guest
    Any of the above, but my personal fave would be turn it into a pukka
    firewall.
    We run a P75 with <drumroll> 32MB of RAM and an (overkill) 500MB hard
    drive. Smoothwall'd it and it's been churning away for a couple of years
    now with nary a problem 'cept a system fan crapping out. Even /that/
    didn't actually stop it, just made it a little quieter and a mite warmer.
    | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Mar 4, 2004
    #55
  16. harry
    Wik Guest
    Mmm, agree there... Turning it into a firewall, otoh...
    Wik, Mar 4, 2004
    #56
  17. harry
    Heh... All Windows lickers say that. To be fair though, it depends on what
    you're used to.
    Muck, Mar 4, 2004
    #57
  18. harry
    Catman Guest
    G
    Catman, Mar 4, 2004
    #58
  19. harry
    dog Guest
    dixit Tim:
    netbsd is coming along.
    dog, Mar 5, 2004
    #59
  20. harry
    tallbloke Guest
    The version I heard said that the windows car would stop every few hundred
    yards, evryone would have to get out while the driver restarted it, then all
    would get back in and the car would slowly pull away again.
    Whereas the unix car would whisk you off at high speed towards your intended
    destination before inexplicably changing direction and dumping you outside
    the library...
    tallbloke, Mar 5, 2004
    #60
