Linux etc.?
Discussion in 'UK Motorcycles' started by harry, Feb 27, 2004.
  1. harry
    harry Guest
    Have just been given a small pc. I want to use it to discover what else
    (apart from microsoft) is out there. Running prog poss linux with anything
    else that goes
    <ducks head>
    Any ideas?
    harry, Feb 27, 2004
  2. harry
    Rexx Guest
    BeOS - weird OS that runs without the need to repartition the drive.
    Rexx, Feb 27, 2004
  3. harry
    A.Lee Guest
    What specs?
    If 350mhz+, with 256mb+ ram, then I'd say Mandrake 9.1, with KDE
    desktop.Its a dead easy install-around 25 minutes start to finish, and
    quite idiot proof (even I got it working in half an hour).A better spec
    comp would be OK with Mandrake 9.2. If you get the 3 complete install
    discs (or download them - 650mb ish each), then you'll have almost every
    application that you'll ever need, though there are virtually no games
    available apart from 2D efforts that went out with the Sinclair Spectrum.
    There are bootable OSes available just to give you an idea if your
    hardware will be supported - most of it is, with the main trouble areas
    being adsl modems and Winmodems.
    Get hold of a couple of Linux mags, who usually have various OSes on their
    cover discs.
    Alan.
    A.Lee, Feb 27, 2004
  4. harry
    Tim Guest
    FreeBSD
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm2 at dsl dot pipex dot com
    Tim, Feb 28, 2004
  5. harry
    YTC#1 Guest
    YTC#1, Feb 28, 2004
  6. harry
    YTC#1 Guest
    Or you may like to try JDS
    http://wwws.sun.com/software/javadesktopsystem/index.html
    YTC#1, Feb 28, 2004
  7. harry
    entwisi Guest
    RH8 is ancient. Even 9 is miles behind distros like Mandrake who like to
    be bleeding edge. As for not enough mileage on Fedora it was a straight
    code branch from RH9 so it has just as much 'mileage' as RH9 if not more
    due to the influx of developers into the 'new exciting' branch.
    If you don't have >128M RAM look at IceWM as a window manager.
    I personally use Suse 9.0 Pro and have updated the kernel to 2.6.1. It is
    as stable as I have ever known.
    You can decide to use any Window manager with any distro. I like Gnome as
    well although I also use IceWM on a low spec machine. The whole point of
    things like Linux is that the choice is up to you. Try a few and see what
    works however your brain is wired.
    entwisi, Feb 28, 2004
  8. harry
    dwb Guest
    dwb, Feb 28, 2004
  9. harry
    dwb Guest
    Linux requires 256mb?!!!
    If so, I will stick to my Windows 2000 installation that's quite happy with
    128 on a shite old PC.
    dwb, Feb 28, 2004
  10. harry
    Zobo Kolonie Guest
    Dunno, but FreeBSD used to run just fine in 8Mb on my old 486... and it'd
    out multitask my 32Mb P166 Win95 machine at the time.
    Zobo Kolonie, Feb 28, 2004
  11. harry
    Zobo Kolonie Guest
  12. harry
    dwb Guest
    That's what I thought - hence my reaciton to a post indicating 256mb was
    'required'.
    dwb, Feb 28, 2004
  13. harry
    dwb Guest
    Surely, it not being MS and all, you can just upgrade all your 8
    installations to 10 FOC?
    dwb, Feb 28, 2004
  14. harry
    A.Lee Guest
    No, it is still quite possible to run a server on a 386 with little ram.
    Newer versions have support for just about everything, so, just like any
    other OS,if it does more, it benefits from more ram.The current Distros
    are,IMO, vastly superior to any Windows version (with the exception of
    games support), with the added bonus that virtually all apps are free.
    There is still a problem of lack of 'Graphic User Interface' at some
    times, like when installing an app from a download (you need to type the
    commands into a console), but overall, it is quite easily learnt,and the
    use of Consoles and Command lines is limited to a few occasions.
    Alan.
    A.Lee, Feb 28, 2004
  15. harry
    YTC#1 Guest
    happened
    You were the one paying ! You should have come to me.
    Indeed, the current pace of development is staggering.
    I will be doing some laptop stuff with 10 next week.
    YTC#1, Feb 28, 2004
  16. harry
    YTC#1 Guest
    DING ... sort of.
    If he is non-commercial etc no probs.
    (and single CPU)
    Oh, and watch out for a true 64bit x86 system on AMD near you soon.
    YTC#1, Feb 28, 2004
  17. i've just rebooted mine after adding a new NIC. The hard disks said they
    needed checking as they had not been checked for 289 days, RH8.
    SimonB - South Wales. BOF#32
    email simonb@zapikdotcodotuk
    Triumph Sprint ST,
    ZXR750L2 Wazimbaki.
    Kawasaki Z1R For Sale
    eric the brave, Feb 29, 2004
  18. harry
    Zobo Kolonie Guest
    No no no no... t'was on a bunch of SunFire's, Blades, and workstations, all
    fully commercial.
    Must confess that I've never run Solaris on Intel boxen.
    Zobo Kolonie, Feb 29, 2004
  19. harry
    harry Guest
    most things I have understood. Now you are getting well ahead of me!!
    Speak english boy!
    harry, Feb 29, 2004
  20. harry
    YTC#1 Guest
    He has never run Solaris on Intel boxes.
    QED
    YTC#1, Feb 29, 2004
