Linked brakes
Discussion in 'UK Motorcycles' started by Hooligan, Apr 24, 2005.
  1. Hooligan
    I know not the reasons why, so "wibble".
    Actually, that's exactly what it does do, unless I'm misunderstanding
    what you mean. The 'outside' face of the wheel centre is roughly level
    with the right-hand edge of the rim, & the spokes curl inwards to
    connect to the centre of the rim, iyswim. sort of like a car wheel I
    s'pose.
    Krusty, Apr 26, 2005
    #41
  2. Hooligan
    Oh right, yeah, I guess you could do this on a cast wheel. I was more
    thinking of the bicycle ones, where the spokes must form a V shape
    from hub to rim, albeit slightly distorted, to hold the wheel
    together.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Apr 26, 2005
    #42
  3. Hooligan
    ....and not just on linked brakes.
    platypus, Apr 26, 2005
    #43
  4. Hooligan
    A car wheel is rigid; on a spoked wheel it's only the tension in the
    spokes, pulling on opposite sides of the hub, that holds it together.
    _______
    Ace, Apr 27, 2005
    #44
  5. Hooligan
    zymurgy Guest
    uhuh, that was my understanding.
    Absolutely. But I dragged the rear sometimes too into tight bends.
    For max/emergency/panic braking, both are needed, and i've locked the
    front up on hard braking with both lever and pedal. This was preferable
    to T boning a stealth White van man whilst commuting in Lunnon once.
    The only other major brakefest was in France on the way back to the
    ferry. Gave it maximum on the lever as I didn't have time to get to the
    pedal. I was too busy taking to the gravel and grass to ride around Tim
    (the only escape route)
    I like the CBS. It's a personal thang.
    Cheers,
    Paul.
    zymurgy, Apr 28, 2005
    #45
