Linked brakes
Discussion in 'UK Motorcycles' started by Hooligan, Apr 24, 2005.
  1. Hooligan
    "I've trained her to perform services one would hesitate to ask a
    professional"
    Champ, Apr 25, 2005
  2. Hooligan
    that rings a bell. Presumably your use of quotation marks indicates
    you're, err, quoting something?
    darsy, Apr 25, 2005
  3. Hooligan
    I am. It's from Dangerous Liaisons - John Malkovich referring to how
    he's "broken in" the Uma Thurman. The quote's not exact, but it has
    the gist.
    Champ, Apr 25, 2005
  4. Hooligan
    Steph Guest
    If ever you have a virgin it would probably be the last thing you'd ever
    do dear.... Unless I can have one too??
    Steph, Apr 25, 2005
  5. Hooligan
    Colonel Tupperware says...
    What a load of fucking overcomplicated bollocks. What's wrong with
    normal brakes ffs?
    Lozzo, Apr 25, 2005
  6. Hooligan
    dwb Guest
    *snort*
    dwb, Apr 25, 2005
  7. Hooligan
    Hooligan Guest
    It depends on your interpretation of the 70 - 30 thing.
    My interpretation of is that it describes the ratio of breaking effort:
    70% of the effort is at the front, 30% at the back. That doesn't mean
    that you can't put the front full on, just that the back will supply a
    little less than half the equivalent braking.
    But, Col. Tupperware's explanation indicates that even so, not all the
    braking is used...
    John (jsp)
    SV 650
    Black it is
    And Naked
    Hooligan, Apr 25, 2005
  8. Hooligan
    Salad Dodger Guest
    It doesn't leave 30% and 70% "not being used", it splits the braking
    effort 70:30.
    Not the same thing at all.
    That bit.
    | ___ Salad Dodger
    |_\_____/_| ..74326../..18420.../..3184./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 12 Pts: 220 Miles: 914
    Salad Dodger, Apr 25, 2005
  9. Hooligan
    I don't find this swapping from bike to bike but it's fairly obvious I'm
    not on a Guzzi.
    Their system is simpler. Footbrake operates the left hand side (left
    front and rear) and the hand brake operates the right hand side (right
    front only).
    This doesn't help much but allows me to say Guzzi's are jolly nice and
    were there before Honda.
    sweller, Apr 26, 2005
  10. Nowt really, I was just trying to clarify and point out it's not that
    complicated really.
    Now I've re-read your initial post, I can see where my
    misunderstanding crept in.
    Its the even less bit that got me. You implied, IMO, that, when using
    the pedal as well as the lever, that the front brake force was
    reduced. I now see what you meant.
    ColonelTupperware,
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Apr 26, 2005
  11. Hooligan
    well, yes, and I'm not aware of any cars that have brake disks on both
    sides of the wheels.
    Frag's posit would only be true with a very thin axle, or made out of
    cheese.
    darsy, Apr 26, 2005
  12. Hooligan
    And don't forget that it will make the wheel turn in that direction
    too...
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Apr 26, 2005
  13. Hooligan
    Unless it's a shaft drive, presumably.
    Krusty, Apr 26, 2005
  14. Hooligan
    Only if you've fastened the disk to the axle instead of the wheel.
    _______
    Ace, Apr 26, 2005
  15. Hooligan
    ah yes.
    He's still talking crap, though.
    darsy, Apr 26, 2005
  16. Hooligan
    Ben Guest
    I think there is a certainly element of truth in that. On bicycle
    disc brakes it's possible that if you don't do up your qr tight enough
    for the wheel to come out of the dropout on the disc brake side only
    under braking. So there must be some twisting forces happening.
    Cuased a few accidents it has and has lead fork manufacturers to alter
    the angle of the dropouts to prevent it.
    Ben, Apr 26, 2005
  17. Hooligan
    Eh? That would mean that the wheels themselves didn't line up,
    wouldn't it? Try and imagine the handling if that were the case. I
    think you've been misinformed.
    _______
    Ace, Apr 26, 2005
  18. Hooligan
    No - the disc is mounted to the hub not the wheel, & the wheel itself
    is dished. At least that's the case on the MV.
  19. Hooligan
    tallbloke Guest
    It's a nice thing to have the braking effort central, and also to have the
    unsprung mass of the wheel as close to the centreline as possible.
    Calipers and discs form a relatively high percentage of the unsprung mass
    on modern hollow spoked alloy wheels. Of course, most of the gyroscope
    effect is generated by the tyre, because it's relatively heavy and is at
    the outermost circumference of the wheel.
    tallbloke, Apr 26, 2005
  20. Hooligan
    Right, yeah. That's quite common, found on almost any
    derailleur-geared pushbike, but is more to do with weight distribution
    then alignment of braking (or accelerating) forces. In any event, it
    doesn't put the disk "in-line" with the wheel itself, as that would
    require a one-sided dish effect, leading to immediate wheel collapse.
    And it's certainly _not_ found on the front wheel of single-disked
    motorbikes.
    _______
    Ace, Apr 26, 2005
