I don't think we've discussed this of late.. A friend of mine has just bought a Deuville as a 'returning to biking' bike. We were talking about it the other day and he mentioned the linked brakes. Front lever applies front only, break pedal applies front and back 70% - 30% apparently. As a result, he has decided to use the pedal almost entirely. I've never particualrly thought linked brakes to be a good idea, but this idea that it leads someone to use the pedal as the primary brake strikes me as dangerous: if he swaps bikes, his initial, programmes braking response will be the back brake, after all. What do you all reckon to this? -- John (jsp) SV 650 Black it is And Naked
You have a point - when I ran Guzzis in the 1980s, I got used to just stamping on the pedal and it took a short time to adjust when I hopped on other bikes. But generally, you adjusted by the second corner, or set of lights. In short - I wouldn't worry.
[snip stuff about linked brakes] Is that because he bought a Dullsville or because he uses the pedal? No. -- John (jsp) SV 650 Black it is And Naked
Which leaves you with 30% and 70% not being used - and that 30% on the front is potentially rather a lot when you need it. I've only ridden one bike with linked brakes, a VFR - and they were noticeable. However the brakes overall were the best I've had on a bike. That said, I made full use of the front lever as opposed to using the pedal... I'd suggest to your mate he gets in the habit of using the lever as he's never going to be using the brakes as well as he could <shrug>
....and your money's on Robbo being a thick ****? -- | ___ Salad Dodger |/ \ _/_____\_ GL1500SEV/CBR1100XXX/KH500A8/TS250C |_\_____/_| ..74326../..18420.../..3184./.19406 (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4 PM#5 |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11 WG* \ |^| / IbW#0 & KotIbW# BotTOS#6 GP#4 \|^|/ ANORAK#17 IbB#4 '^' RBR Landmarks: 12 Pts: 220 Miles: 914
Well, that would definitely be worth investigating. He seemed quite certain he had it the right way round, as described by the shop he got it from, but never having ridden a Deuville, how should I know? I'll get him to make sure.... I'd hate to see him crash. -- John (jsp) SV 650 Black it is And Naked
Me 'Bird has that setup. I wasnt replying 'cos I was waiting for the post of next week, but you've spoiled it now :-(
It does? You wanna get it looked at, sharpish. -- | ___ Salad Dodger |/ \ _/_____\_ GL1500SEV/CBR1100XXX/KH500A8/TS250C |_\_____/_| ..74326../..18420.../..3184./.19406 (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4 PM#5 |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11 WG* \ |^| / IbW#0 & KotIbW# BotTOS#6 GP#4 \|^|/ ANORAK#17 IbB#4 '^' RBR Landmarks: 12 Pts: 220 Miles: 914
Okay... but I can admit to being wrong... but I'm not sure how. "applies front and back 70%-30% apparently" Now considering my understanding of (VFR) linked brakes it's a complicated system of variable piston usage - you pull the front, they don't all come on - you use the pedal, even less is applied at the front. Which means you aren't using them to full usage unless you use both and you definitely aren't using even close to the front potential if you're just the pedal. What have I got wrong in this case?
Good point. Roughly 70/30 both ways, lucky you mentioned that before my impending track day virgin fiasco :-(
They have thre, 3 piston calipers, 2 front and 1 rear. The Front lever applies pressure to 2 pistons on the front each side and 1 on the rear. The rear pedal applies pressure to 2 on the back and 1 on the front each side. As you say you need to use both brakes to get full braking effect, but on CBS machines I usually use the front only, unless really braking heavily. On non CBS, I use front and back, with front harder than back. The only bikes I can compare are Pans. 1 model has ABS, TCS & CBS, the other, nowt, just old fashioned brakes. The ABS ones brake better than the non, IMO. -- ColonelTupperware, spouting bollocks on Usenet since 1997 Usenet FAQ at http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
heh. Well, yeah, sure. I've only had one virgin, and that was when I was too, so neither of us were in a position to compare.
well, trust me on this one - they're nothing to write home about. On the plus side, they don't know what's considered normal...
